Old 04-13-2003, 04:08 AM   #1
smew
Member#: 22524
Default radiator fan switch
Is it possible to run a switch off the radiator fans that would allow me to turn them on any time i wanted? I looked at the fans, theres four wires going into each, Yellow, Black, Blue, and Green (I think). I would also like to maintain stock function as well, so they turn on automatically, but i can also turn them on whenever.
smew is offline   Reply With Quote
Old 04-13-2003, 10:55 AM   #2
Austin
Member#: 7089
2016 STi
Turn your AC on.
Austin is offline   Reply With Quote
Old 04-13-2003, 08:40 PM   #3
smew
Member#: 22524
I guess thats what i'm looking for... Doesn't that also turn the A/C compressor on? I'd prefer to have just the fans runnning to avoid extra draw on the engine... and I'm trying to avoid using the A/C with the hopes that after this summer i'll be willing to get rid of it completely. Unfortunately, i don't think that i'll make it, I live in oklahoma (d'oh).
Old 04-13-2003, 10:36 PM   #4
smew
Member#: 22524
anyone know what the four wires are? aka how to splice into them to create a switch... If it was just three, i could probably figure it out on my own, but i have no clue what the fourth one is...
Old 04-13-2003, 10:45 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The fans have high and low speeds and are controlled by relays. Any manual switching should be done at the relay side, not directly at the fan motors. You should get the wiring manual for the car and it will have all the info you need, you can order just the wiring volume of the service manual and it won't be that expensive.
Old 04-14-2003, 01:59 AM   #6
smew
Member#: 22524
excellent, thank you
Old 05-16-2003, 08:27 AM   #7
bigjohnknob
Member#: 36498
That is what I looking to do turn them on high when ever i want and still able to have the ecu run them when I leave the switch in the off pos.
bigjohnknob is offline   Reply With Quote
Old 05-16-2003, 08:37 AM   #8
bigjohnknob
Member#: 36498
Old 05-16-2003, 09:21 AM   #9
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I'm curious why you would want to do this?
lstepnio is offline   Reply With Quote
Old 05-16-2003, 10:04 AM   #10
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I've installed Hayden's adjustable fan controller in line with the stock fan controller system. I need to snap some pics tommorow and do the DIY. That should have everything YOU would need to know to just wire up a manual switch.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-16-2003, 12:09 PM   #11
Austin
Member#: 7089
2016 STi
To keep the fans on/keep airflow across the radiator when you're sitting still.
Do a nice 120mph 18psi 4th gear pull, then stop quickly on the side of the road to make some adjustments... see how quickly you heat up to 96C.
Old 05-16-2003, 12:11 PM   #12
lstepnio
Member#: 10972
2004 Forester X
I'm just a little suprised you guys are doing this. Shouldn't the thermostat just automaticly kick on the fan?
Old 05-16-2003, 04:36 PM   #13
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
The reason is the water thermostat is set at 176 iirc and the fans don't kick on until ~205 or so. I would be nice to have the fans come on at 185 or 180. I wonder if the fan kick-on is ecu driven? If so it could probably be reset with deltadash, ecutek, etc....
mr2guru is offline   Reply With Quote
Old 05-16-2003, 05:30 PM   #14
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Default I Have your Answer!
If you want the fans to come on without A/C then you just need to pull the relay under the hood in the fuse box(to your right while looking at the car). I have done this several times when at he drag strip and it works pretty good. All you do after you remove the relay is turn on the car like you were running A/C and the fans will come on but the compressor will not. Very easy to do and will not hurt the car. Just make sure you remove it and put it back in while the car is OFF.
-Matt
ShaggyGT is offline   Reply With Quote
Old 05-16-2003, 07:23 PM   #15
WRXBob
Member#: 12455
02 WRX
I put an auxlilary relay and wires the fan #2 to come on around 180F. Sound complicated but there is only two wires hook up. One to ground and one to the relay. The relay is a thermal switch and does not requires power to run. It grounds the ECU fan #2 signal wire (green with white stripe in engine compartment fuse box) and turns on the fan when temp reach a preset level. Temperature goes up fast, as soon as I drive, the fan turns off, but I can just pull in the drive way and 30 seconds later the fan comes on. Only fan#2 can be overide. Fan #1 overide gave me a check engine light. BTW, pulling AC relay is a good idea, may be the AC wire signal can be route and control by a switch inside the car.
WRXBob is offline   Reply With Quote
FS: New Mishimoto Aluminum Radiator, Two 12" Slim Fans, Cap, Fan Switch, 02~07WRX/STI wrx_limited Engine/Power/Exhaust 12 04-03-2009 07:44 AM
sti radiator fans vs. wrx radiator fans GrimmSpeed Subaru Conversions 2 12-21-2007 01:23 PM
How to properly wire a radiator fan with a switch? Kwyjibo Electrical & Lighting 0 08-26-2005 07:16 PM
Anyone here built a FAN bypass switch for Radiator fans? Valhakar Electrical & Lighting 23 06-06-2005 09:25 AM
radiator fan / engine cooling fan vvk Normally Aspirated Powertrain 2 05-15-2002 10:05 AM
