Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-06-2003, 02:09 AM   #1
wrxxxappeal
Member#: 33216
02 wrx sportwagon
WR Blue
Default Help Me! Help Me Please!
my car just one day decided not to work. I can't build boost for nothing. Gauge stays in vacuum. Checked all my vacuum lines, and FMIC hoses, didn't find any leaks. Dont really have a clue to what may have happened, or why. Anything ideas? Please help.
Mods.
Injen CAI
Blitz FMIC
Blitz SBC-id set @ 15psi
power i-d
Blitz BOV
Blitz cat back Nur spec exhaust
wrxxxappeal is offline   Reply With Quote
Old 05-06-2003, 02:22 AM   #2
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
Check the BOV check the MAF sensor.
Oo DaRk StAr oO is offline   Reply With Quote
Old 05-06-2003, 11:21 AM   #3
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
oh snap, try talking to it.. Maybe you need to reset the ecu.. Try petting the dashboard, i do that to and the car seems to like it.
03WRX83 is offline   Reply With Quote
Old 05-06-2003, 04:03 PM   #4
[email protected]
Guest
Member#:
I used to have an SBC-ID in mine and it would occasionally check out on me. Try initializing it. That would usually cure mine. Good luck.
M
Old 05-07-2003, 12:48 AM   #5
wrxxxappeal
Member#: 33216
02 wrx sportwagon
WR Blue
mike..
how do you initialize it?? Also hear like a clunk when I release the throttle cable while im under the hood. Sound like something from the wastegate isnt working. Like its not closing, maybe its stuck open, which is not letting me build any boost. Also I was told to check some kind of clip the is on the wastegate, it may have fallen off..
Old 05-07-2003, 01:46 PM   #6
[email protected]
Guest
Member#:
Inintialize is an operation you can choose from the settings menu I think. Look around it's in there somewhere. As far as the wastegate goes that's a definate possiblity. You want to check to see if the arm coming out of the wastegate is secured(otherwise there will be no pressure on it) and that the clip that secures it is in place. Try opening and closing the wastegate manually to see if it is actuating with out sticking. @ 15psi it should hold just fine if everything is in order. Other things to check, The vaccum lines from turbo to boost controller and to wastegate. Check for leaks or disconnection. Double check for boost leaks, loose intercoolerpiping. Is it making any boost? Should still make 8 psi or so even if the wastgate is blown open. Less than that and I would say your compressor is having issues. Let me know if I can help any more.
M
Old 05-10-2003, 02:13 AM   #7
wrxxxappeal
Member#: 33216
02 wrx sportwagon
WR Blue
M,
I checked the actuator rod , and its still in tact, the c clip is also there. Pushed the actuator rod manually, and feels like its still good. When i put me ear next to the wastegate, and release the throttle, I hear this click, or clunk sound. Im pretty sure its something inside the housing, maybe the door is broke. Hesitant to take it to the dealer, because they will take one look at the mods, and send me away without any warranty coverage.
I'll let you know what i find out, Thanks.
Gerald
Old 05-10-2003, 11:15 AM   #8
willysaki
Member#: 25077
Happy to help. Let me know if there is anything else I can do. And keep me posted. Would like to know what the outcome is. Thanks.
Mike
willysaki is offline   Reply With Quote
Old 05-10-2003, 12:14 PM   #9
Akiata
Member#: 297
Sounds like its time to take your turbo back off and have a look at the wastegate door.
Akiata is offline   Reply With Quote
FBI is coming for me, help me OT....please MotorolaBizz Off-Topic 15 05-07-2010 06:12 PM
Tech help HID HELP PLEASE give me some info Evolved8 Electrical & Lighting 11 02-12-2010 05:15 PM
Urgent: HELP Needed! Brembo Owners Please Help Me Out. soulska Southern California Impreza Club Forum -- SCIC 16 02-05-2010 10:01 PM
What is thise hose please help me driveing me nut's Jkmaynard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-24-2009 09:59 PM
Help me Tornonto folks please MichiganRS Canada Region Forum 4 02-14-2001 09:10 AM
