Old 05-06-2003, 09:07 AM   #1
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Default If you are considering a Perrin Rear Sway bar or End links *IMPORTANT*
It is vital that you make sure you buy both the new versions of the rear swaybar AND endlinks.
The new swaybars have washers on them to prevent them from moving side to side and the endlink's bearings are more secure.
I unfortunately just purchased the older versions of both items and the bearings on the endlinks have just popped out. My car is unusable until I reinstall the stock endlinks or wait for a replacement pair.
Perrin has been very helpful, though, and are sending me both the clamp kit to fix the swaybar movement and the new versions of the endlinks.
BeavisNuke is offline   Reply With Quote
Old 05-06-2003, 12:03 PM   #2
smash0r
Member#: 9676
2005 Impreza WRX STi
Crystal Gray Metallic
I've got a slightly different problem, I have the old style Perrin bar with Kartboy endlinks (I'd purchased the endlinks a while before the bar)
I'm getting a clunk in the rear of the car, anyone else experienced this?
smash0r is offline   Reply With Quote
Old 05-06-2003, 01:07 PM   #3
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
I had the clunking too when I first installed the swaybar.
Take a look under the car again and you will see that just above the muffler the swaybar is close enough to the chassis to thump against it over bumps. (when the suspension compresses)
All you need to do is loosen the mounts a bit and shift the swaybar towards the driver's side of the car more. Give it about an inch of space between the swaybar and the chassis tub.
Old 05-06-2003, 02:06 PM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
it should still be usable... you don't NEED a swaybar to drive it... just be careful... it's not really unsafe if you drive like a normal person. It'll feel different, but it won't fall apart or anything...
mrbell is offline   Reply With Quote
Old 05-06-2003, 05:49 PM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Yeah I drove all last week with no rear sway, it's FUN!
djerickd is offline   Reply With Quote
Old 06-04-2003, 02:56 PM   #6
FLEX
Member#: 19402
Angry
I have the sway bar and the end links but my problem is I have the eibach springs so I get a clunking sound every time I go over a bump, big or small. I have been unable to fix this no matter what setting hole I put the sway bar on. I do have the washers that Perrin sent out to me but this dosent help anything, the problem is that the new brackets are too long and they bring the sway bar too close to the muffler.
-Nate
FLEX is offline   Reply With Quote
Old 06-04-2003, 04:14 PM   #7
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Did you try re-positioning the swaybar a little to the right or left? Mine was clunking against the chassis and this fixed it.
Old 08-25-2003, 06:39 PM   #8
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
can you take some pics. i have this problem and its very annoying. can you show me where this was happening and what to do?
D-I-Z-Z-L-E is offline   Reply With Quote
Old 08-25-2003, 07:08 PM   #9
nate49509
Member#: 22452
2016 WRX
I have kartboy endlinks with the FHI 20mm and eibach springs with no clunking.
nate49509 is offline   Reply With Quote
Old 08-25-2003, 07:22 PM   #10
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
thanks?
Old 08-25-2003, 10:26 PM   #11
Bolster
Member#: 22290
2002 WRB WRX Wagon
Hairpin Racing carries a set of collars for those of us with this particular swaybar/endlink problem.
Bolster is offline   Reply With Quote
Old 08-25-2003, 10:49 PM   #12
nate49509
Member#: 22452
2016 WRX
Originally posted by D-I-Z-Z-L-E
thanks?
Your welcome?
Perrin Rear Swaybar w/ endlinks ('04 STi) PRODRIVEN Suspension/Brakes/Handling 4 09-04-2006 05:20 PM
New in Box Perrin Rear Swaybar and endlinks jcdeng Private 'For Sale' Classifieds 9 03-30-2006 12:35 AM
Perrin Rear Swaybar And Endlinks?? Your thoughts NORCAL STI Brakes, Steering & Suspension 6 12-09-2004 01:07 AM
Finally got one, super indepth impression, MUST READ if you are considering a STi. JDM nut STi Forum Archive 8 08-18-2003 12:54 AM
Perrin rear swaybar and endlinks? SoLiDbReAkZ Brakes, Steering & Suspension 13 01-06-2003 02:33 AM
