Old 10-20-2000, 06:59 AM   #1
Silver2000RS
Member#: 857
Question Block Heater
Has anyone installed a block heater in their RS? Do you have any helpful tips?
Besides the drain plug on the radiator, is there also a drain plug on the engine block?
Silver2000RS is offline   Reply With Quote
Old 10-20-2000, 07:12 AM   #2
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
um aren't block heaters only really needed on diesel motors?
rpone605 is offline   Reply With Quote
Old 10-20-2000, 06:15 PM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
We have the block heater on our Outback. In order to install it you have to remove the coolant plug in the engine block. First you'll have to drain the coolant obviously The plug unscrews using a very big allen wrench (14MM? I forget) Then you screw in the heating element. If you want to get an idea of what the plug looks like check out this page: http://www.azscooby.com/
And look for the OEM subaru oil cooler. I had to remove the same plug but on the opposte side to install that. I now have the proper allen wrench so it would have been a lot easier with that.
We don't live in a real cold climate so we have never used the one on the outback it came standard on the Limited.
Peaty is offline   Reply With Quote
Old 10-21-2000, 09:04 AM   #4
Rickd
Member#: 323
1999 Impreza RS
Rally Blue
Post
Block heaters are a way of life up here in Canada. I designed them for a living for 3 years, including the OEM heater for Subaru
If you are having trouble finding a 14mm allan key, or any big one for that matter, just take a bolt with a 14mm head on it, put two nuts on it, jam them together, and use a wrench on the bottom nut. That will work most of the time.
If the nuts keep slipping, take your little assembly to anyone that has a welder and get the nut welded on.
Rickd is offline   Reply With Quote
Block Heater Question Scoobie Newbie Canada Region Forum 7 01-21-2002 01:39 PM
Burping the cooling system-Block heater install wild wild west Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-02-2002 12:53 AM
Block heater question mr2guru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2001 06:10 PM
Subaru engine block heater install - need HELP! Peaty Normally Aspirated Powertrain 2 11-17-2000 12:42 AM
Subaru Engine block heater tomrichardson Normally Aspirated Powertrain 5 11-11-2000 12:30 AM
