Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 05-06-2003, 06:58 PM   #1
lushboy
Member#: 16360
2002 Legacy LTD OBW
Black Granite Titanium
Default Diff question
Probably a noob question here, but for our outbacks, how many diff's are there? 3 or 2? I know the center diff is of viscous type (or is it?), what kind is in the rear? Do we have one in the front? If so, what kind?
Thanks..
lushboy is offline   Reply With Quote
Old 05-29-2003, 05:08 AM   #2
samtheblur
Member#: 21164
1998 Legacy Outback
Default Depends
That depends on the type of transmission. 4EAT's have 3, 5MT's have only two.
samtheblur is offline   Reply With Quote
Old 06-24-2003, 04:49 AM   #3
sebberry
Member#: 38617
2005 Outback XT
GRP
On the new Outbacks, the setup is as follows:
All have a front "open" differential
All except for the VDC have a "Limited Slip" rear differential
The VDC has an "open" rear differential. (Limited-slip like action supplied by the VDC braking system)
VDC uses a planetary gearset and a clutch pack to transfer up to 100% of the torque to either axle.
4EAT models (Non VDC) have a center clutch pack that distributes torque to the rear wheels when one or both front wheels starts to slip, and also under accelleration.
5MT modelt have a center "viscous" differential that, when the front axle spins faster than the rear, it shears the fluid in the diff which almost locks the front and back axles together.
I know that is more than you asked for, but it explains each system.
sebberry is offline   Reply With Quote
Old 06-30-2003, 03:21 PM   #4
lushboy
Member#: 16360
2002 Legacy LTD OBW
Ah, thanks for the clarification!
I was wondering because I got stuck in a mud ditch and my front wheels where just spinning and I had the clutch smoke coming out of my hood. I was able to slowly backup, but won't go forward.
Anybody put in a front LSD?
Quick rear diff question for hybrid diff iluvdrt Transmission (AT/MT) & Driveline 3 04-12-2010 09:26 PM
Viscous limited-slip diff. question SubaruImpreza_power Transmission (AT/MT) & Driveline 6 05-28-2002 02:53 PM
center diff question davewrx Transmission (AT/MT) & Driveline 11 03-11-2002 04:42 PM
center diff question/problem? twlai Transmission (AT/MT) & Driveline 2 02-01-2002 03:31 PM
New Center Diff Question gumby647 Transmission (AT/MT) & Driveline 18 12-14-2001 09:04 PM
