Old 05-06-2003, 08:47 PM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default changing PCV valve
is there a straight and simple way to change this, & how often should it be done?
dingo dave is offline   Reply With Quote
Old 05-06-2003, 09:09 PM   #2
JohnP555
Member#: 20355
99 RS
Rally Blue Pearl
The PCV valve on the RS is very simple to change. Very straight forward. Just take a pair of pliers and unscrew it. As far as changing it, I think subaru reccommends that you change it every 30k miles. I have about 46k on my car and haven't changed it yet . As long as you put your finger over the top of it and it clicks while the motor is running then it still works. But, a replacement valve is only like 10 bucks at the dealership so you might as well change it.
Hope this helps
JohnP555 is offline   Reply With Quote
Old 05-06-2003, 09:10 PM   #3
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
very easy. just take the hose off, unscrew with wrench and then put the new one on tighten and put hose back on. your manusl tells about replacment. they are still good if you can shake it and here it rattle inside.
aj's25rs is offline   Reply With Quote
Old 05-07-2003, 01:13 AM   #4
Basshead
Member#: 112
2011 Jetta TDI
i just changed mine at 60k and the ball wasn't rattling too good, yet still moved...i'd say changing it around 45k, cause at 30 it was still fine but at 60 it wasn't moving too freely...
Basshead is offline   Reply With Quote
Old 05-07-2003, 07:13 AM   #5
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Poppa smurf is offline   Reply With Quote
Old 05-08-2003, 12:32 PM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default PCV change
Take the hose off the PCV, unscrew it out of the intake manifold, attach the tube back to PCV and start the engine. You should be able to put your finger over the tip of the PCV and you should feel it sucking and clicking. Also, after removing the PCV, shake it. If it doens't rattle replace it, or do what I do, just clean it Carb/Throttle Body Cleaner. Just make sure that you don't overtighten it when putting it back in. The PVC does not bottom out with the intake manifold. Just take a look at how much of the threads are showing before you remove it. I put a little teflon tape on the PCV threads just for a little insurance of sealing.
-Charles-
ImprezaVA is offline   Reply With Quote
Changing PCV valve and may have screwed something up subaruwrx420 Service & Maintenance 19 05-21-2007 02:43 PM
PCV Valve Changed sanders Normally Aspirated with bolt-on Forced Induction Powertrain 14 09-03-2004 10:48 PM
How do you change the pcv valve? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-27-2004 03:25 PM
PCV valve changing interval Flexy Service & Maintenance 21 04-10-2003 06:22 PM
want to change PCV Valve and fuel filter, how and where are they, and steps? joostin420 General Forum Archive 6 12-13-2000 11:35 AM
