Old 05-07-2003, 02:00 PM   #1
slowme
Member#: 12235
2006 WRX Limited
Red
Question Mid Pipe Question
Does anyone know if I install a prodrive back-box on my GC and later on install a mid pipe made by another manufacturer, will they fit up or not?
Bill
slowme is offline   Reply With Quote
Old 05-07-2003, 02:10 PM   #2
watcher in the sky
Member#: 3513
1997 Legacy Outback
If the prodrive fits up to the stock mid, then the Stromung mid will.
watcher in the sky is offline   Reply With Quote
Old 05-08-2003, 02:51 PM   #3
Charge
Member#: 3313
In all honesty, I'd have a local shop just fab you a mid-pipe. It seems so much cheaper, especially for a pipe that no one will see. As far as performance, there isn't much to the bends Just have someone mandrel-bend you one if you are concerned. That way, you can be sure it will mate right up to whereever your aftermarket muffler starts.
Charge is offline   Reply With Quote
Old 05-08-2003, 03:19 PM   #4
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
2.25" piping is almost impossible to have mandrel bent by an exhaust shop... I called all over and finally found out nobody in Texas does it... Most only will mandrel bend 3" and up iirc...
DanzBorin is offline   Reply With Quote
Mid-pipe questions. Lightsped Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-17-2002 11:51 AM
Mid-pipe Questions- Custom or Aftermarket? Ryan24 Normally Aspirated Powertrain 1 04-01-2002 07:54 AM
mid pipe question flent Normally Aspirated Powertrain 8 12-16-2001 04:57 PM
Pulleys and Mid-pipe questions RacerX Normally Aspirated Powertrain 22 03-24-2001 06:03 PM
stromung(?) mid pipes, question Silver_Fox Normally Aspirated Powertrain 8 01-25-2001 11:34 AM
