Old 05-07-2003, 04:56 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default Bar to PSI conversion factor?
My Greddy Turbo gauge is in BAR ... what is the conversion factor to PSI?
Should I get a PSI gauge ... is it easier to get more precise reading with one?
Right now I'm getting a good 1.1 bar with my EcuTek re-flash =
makofoto is offline   Reply With Quote
Old 05-07-2003, 05:00 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
1 Bar = 14.5 PSI
1 PSI = 0.06895 Bar
zaxrex is offline   Reply With Quote
Old 05-07-2003, 05:01 PM   #3
sonicsuby03
Member#: 36060
03 Rex Cobb Stg2
Ltd Ed. Sonic Yellow
14.7 PSI = 1 BAR.. YOUR CRANKING OUT JUST OVER 16 PSI. DEPENDING ON YOUR MODS I WOULDN'T RECOMMEND RAISING BOOST ANY HIGHER.
sonicsuby03 is offline   Reply With Quote
Old 05-07-2003, 05:12 PM   #4
Thumper23
Member#: 11571
Thumper23 is offline   Reply With Quote
Old 05-07-2003, 05:14 PM   #5
makofoto
Member#: 25243
2006 Legacy Outback
"I WOULDN'T RECOMMEND RAISING BOOST ANY HIGHER." Because .... ?
With my EcuTek re-map ... not getting any knock ... even with 91 octane (I usually use 94+ octane)
What is the limit on the EJ20 engine ... and why?
Not planning to ... just wondering? And looking for an excuse to get a larger TMIC
Old 05-07-2003, 05:16 PM   #6
Thumper23
Member#: 11571
The stock turbo starts to lose efficiency around 17 psi, I think. The big thing with turning up boost is obviously engine management, but that's already taken care of. You still have your stock uppipe in?
Old 05-07-2003, 05:27 PM   #7
makofoto
Member#: 25243
2006 Legacy Outback
APS up-pipe ... Stromung down-pipe back exhaust system
OK ... turbo inefficiency ... got it ...
Old 05-08-2003, 02:12 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Originally posted by zaxrex
1 Bar = 14.5 PSI
1 PSI = 0.06895 Bar
this man is correct, bar is commonly mistaken for 14.7psi it is 14.5(repeating)
jeremy
Old 05-08-2003, 10:05 AM   #9
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
i run 20 psi on my STG 4 car daily. no knock, no prrblems
wrxtuner02 is offline   Reply With Quote
Old 05-09-2003, 01:59 AM   #10
clamdip
Member#: 18709
i have a question. on my OEM boost gauge and peak boost (bar) on my blitz turbo timer, i'm reading about 1.42 bar, however, my boost controller (HKS EVC IV), i have it set to 1 bar max and have a safety boost cut (which in times of over boosting, it defaults back to the stock boost) set to 1.15 bar, which hasn't happened yet. i'm guessing that i'm getting vacuum reading from different locations. my boost controller is hooked up directly from the stepping motor to the turbo. in other words, all vacuum lines are going straight to the turbo, except one to the blow-off valve. either my boost controller is contributing to some bad boost spike, or my boost controller is reading the correct vacuum and the OEM gauge and turbo timer is off. any suggestions as to what i should do. i've turned the boost down to about 10 psi at the moment because i know for a fact that the stock turbo isn't very efficient after 16psi, and i'm trying to prolong my turbo as long as i can. or maybe i should blow it and upgrade. hmmmmm . well, any opinions, flames or suggestions are welcome, thanks guys.
clamdip is offline   Reply With Quote
Old 05-09-2003, 02:57 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
get the stock intercooler out of there and you'd be amazed how much less pressure lose there is.
jeremy
Old 05-09-2003, 03:06 AM   #12
makofoto
Member#: 25243
2006 Legacy Outback
How does adding a larger IC, which has more volume then the stock IC, create less lose of pressure ... ?
Old 05-09-2003, 04:06 AM   #13
clamdip
Member#: 18709
thanks for the info guys, but i don't think it deals with pressure loss, i could be wrong though. i think it may have something to do with the vacuum readings. i'm just wondering which should i trust in terms of accurate readings, my boost controller or the OEM gauge? to put it simple, my boost gauges (both on turbo timer and OEM mech. gauge) read about 1.42 bar, where as my boost controller is set to only 1 bar max, with a 1.15 bar boost limit. got a bit of a problem here.
Old 05-09-2003, 04:41 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
because the stock core loses approx 3 psi where as a larger higher flowing core may have only a 1.20 psi pressure drop
Old 05-09-2003, 01:14 PM   #15
KJR
Member#: 16879
KJR is offline   Reply With Quote
mPa to psi conversion scoobie1 Newbies & FAQs 13 03-26-2013 04:26 PM
mPa to PSI conversion? SMUwrx34 Texas Impreza Club Forum -- TXIC 15 07-27-2006 02:19 PM
Does anyone have the Bar to PSI conversion formula??? wrx_in_efx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-20-2001 11:31 AM
KPA to PSI conversion Typer202 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-10-2001 07:42 PM
