Old 05-07-2003, 06:58 PM   #1
SubaruPreza
Member#: 21579
2000 Forester
Default 00 RS gauge Cluster in a 94 L
I am getting a 1.8L to 2.5rs swap done on my car soon and i was just wondering if the 2000 RS gauge cluster will fit into my 1994 L. Or can my94 gauge pod be modified so it will fit. Any info will help.
thanks
Aaron
SubaruPreza is offline   Reply With Quote
Old 05-07-2003, 08:42 PM   #2
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
The '00 RS had a digital odometer, while your '94 would be mechanical, correct? I'm no expert, but I suspect you'll have to keept the '94 cluster and dash wiring harness. I know from experience that 97+ Imprezas have different dash harnesses and AC systems than '93-96 Imprezas had, so the swap may be easiest if you figure out how to stick with the '94 set-up.
annointed is offline   Reply With Quote
Old 05-07-2003, 09:26 PM   #3
SubaruPreza
Member#: 21579
2000 Forester
i will still have to use my old one if i have the complete wiring harness and ECU from the EJ25 engine? Does anyone know if the 00 RS gauge cluster will fit physically into my94L?
Old 05-07-2003, 09:31 PM   #4
annointed
Member#: 5960
Imprezas have 3 main harnesses, the engine harness, the dash harness, and the interior harness. Again, I'm no expert, but usually with a swap, you only change out the engine harness. If you change out the dash harness, you may need to also change out your '94 dash to a '97+ dash, and then your doors might not close like one friend of mine who did this with a '95 L that got a Ver 6 swap that included the dash. So then he had to source Ver 6 door moldings to make it all fit. It turned into a massive headache for him. Another guy I know did a '94 WRX motor swap into his '97 Impreza, and his dash was considerably different from the '94, yet that '94 motor had previously been in a '93-96 style US Impreza.
So just be prepared for headaches. The less things you change over, the better.
Oh, and yes, the cluster will fit physically, so if you're not afraid of wiring, you can probably make it work.
Old 05-07-2003, 11:46 PM   #5
Aspen
Member#: 145
Banned to
Housework for Summer
You can make it work if you have enough of the wiring harness from the RS. But also depends on whether your swap involves the new RS tranny also since the newer instrument cluster reads its speed from a speed sensor mounted on the trannys. Your '94 is currently cable speedo operated and not electronic.
Aspen is offline   Reply With Quote
Old 05-08-2003, 09:00 PM   #6
SubaruPreza
Member#: 21579
2000 Forester
The engine also comes with the 2000 tranny and rear diff.
Old 05-12-2003, 12:17 PM   #7
Aspen_2.5RS
Member#: 3310
Post
I've seen where someone had put a 02 wrx gauge cluster in an L. I remember seeing that things needed modifying in order to fit.
I'm considering going this route, but I'm not sure. I'm getting a wrx tranny so I need some way to monitor the r'spm.
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 05-12-2003, 03:01 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I had a thread on this a little while back about the compatibilities of the speed sensors between model years.
As for fitting in the new gauge cluster, Eby put a WRX cluster in his L. He said that he needed to create a custom mount for it and had to do some bondo work to get it to look right. I do not know if the RS gauge cluster would fit any better than the WRX one. I can't remember what the RS cluster looks like compared to my L's cluster.
-Jon
JDM STi gauge cluster in 2000 RS? Smillim7 Electrical & Lighting 2 09-11-2006 02:40 AM
FS: 00 RS Gauge cluster jnorth85 Private 'For Sale' Classifieds 4 02-23-2006 10:02 AM
USDM STi gauge cluster in a 01 RS? Desslok Subaru Conversions 3 06-12-2004 01:56 PM
'04 TS gauge cluster in '00 RS? p1fan Interior & Exterior Modification 2 02-12-2004 07:49 AM
99 RS Gauge Cluster (white face) imdiaw Private 'For Sale' Classifieds 2 10-29-2003 10:13 PM
