Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 05-10-2003, 07:22 AM   #1
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default Will this work? MY99 Block w/ MY00-01 RS or 02+ WRX DOHC head swap???
I have a MY99 RS and I wanted to change over to the MY00-01 DOHC heads and rear LSD. I was wondering how feasible it was to change the heads on the engine. I am running a TEC2 so engine management isn't and issue. I was guessing that all you had to do is replace the heads, get new timing belts, set timing correctly and run engine? I may be thikning in to simple of terms but I thought the only issue of going from SOHC to DOHC was that the MY99 ECU was not compatible with the MY00-01 ECU since both ECU;s are programmed to run differnet engines. Since I am running the TEC2, timing as well as all Engine management is controlled by the TEC 2, right? As long as the engine it self is built right and the timing is correct the engien should run?
The second question is if it is feasible to add the WRX heads on a MY99 EJ25 short block. DO they even match up? The reason I want to do this is so that I have heads that are capable of revving higher then the 6400RPM rev limit on the MY99 SOHC engines. I know the heads are not built for revving over 6500RPM max on stock head internals.
I guess my quesiton is which is better swap for flow and high revs, the MY00-01 DOHC RS head or the 02+ WRX DOHC. Do I swap or is it cheaper to just go with aftermarket valves, valve springs, and retainers?
If aftermarket is the way to go which is best? COBB? Any suggestions?
Thank you so much.
John
Twin-turbo EJ25 (aka ej25sett) @10 psi
blown headgaskets...
Cusco is offline   Reply With Quote
Old 05-12-2003, 12:52 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the cam position sensor is not a big deal as you are using the tec 2 which does not use it ..
Old 05-12-2003, 03:26 PM   #3
OBSbug
Member#: 4274
2011 Legacy 2.5i
Hot Tamales Red
Not to nit pick, but the DOHC heads were only on the 98 RS as far as imprezas go. As far as WRX Heads vs DOHC 98 Heads vs Upgraded SOHC heads, it depends on what you want to do. Not 100% sure about WRX heads matching up with EJ25 shortblock. If you want to go high revving then you're going to have to upgrade the cams as well as springs, retainers, and possibly valves on the SOHC and DOHC GC8 heads. Again, I have zero experience with WRX heads so I cant comment on how high you can go.
Hope I helped a bit.
-Aaron
OBSbug is offline   Reply With Quote
Old 05-12-2003, 07:07 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What you need to do is hunt down the old posts by Trey Cobb regarding their EJ25 in their Conebasher. They used a built EJ25 shortblock and then bolted all the other Ej20 components back on. If I remember correctly, they had to massage the quench area on the heads to get them to mate up properly to the larger bore of the EJ25.
-Jon
stimpy is offline   Reply With Quote
WTB MA: Swapped 98-01 RS or 03 WRX KSE25rs Private 'Wanted' Classifieds 5 04-28-2008 08:11 PM
WTB: 99-01 RS or 02-03 WRX Fogs & brackets Phx, AZ JapCarRealGood SWIC Private Classifieds 2 03-16-2007 04:12 PM
WTB: 99-01 RS or 02-03 WRX Fogs & brackets Phx, AZ JapCarRealGood Private 'Wanted' Classifieds 5 03-15-2007 11:57 AM
WTB: 00-01 RS or 02-04 WRX Rear Differential sbrcr267 Private 'Wanted' Classifieds 0 04-07-2004 03:49 AM
