Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 05-09-2003, 09:51 AM   #1
ShzSTi
Member#: 36478
2011 Ex-0wner WRXSTi
ex-owner of 99wrb 2.5rs
Default 2.0 STi vs. 2.5 STi motor
so which one is better?
ShzSTi is offline   Reply With Quote
Old 05-09-2003, 11:24 AM   #2
Austin
Member#: 7089
Austin is offline   Reply With Quote
Old 05-09-2003, 11:46 AM   #3
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
The 2.0 is a time tested design. The 2.5 has 25% more displacement. You be the judge.
I, for one, can't wait for the 2.5 to be put in the Legacy!
Stanley is offline   Reply With Quote
Old 05-09-2003, 11:54 AM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
where are you... what are you running for gas... what do you want out of it....
im staying with a 2.0 or a 2.2 for my daly driver, and a 2.5 for my sleeper L wagon... why? no reason.. just becasue.
Old 05-09-2003, 12:46 PM   #5
STEALTH-WRX
Member#: 7822
Multi layer snot green
2.5 all the way. then you can build it to a 2.8. those are my next plans after i am bored with this motor.
STEALTH-WRX is offline   Reply With Quote
Old 05-09-2003, 06:10 PM   #6
OzWRX
Member#: 15150
2015 WRX
What about a 3 litre 6 cyl H6 Outback engine..they are only 20mm longer the the 4cyl..and they will fit into the WRX engine bay..
Rebuild the H6 to suit turbo application add a nice turbo and ECU.
That would be a weapon
OzWRX
OzWRX is offline   Reply With Quote
Old 05-09-2003, 07:56 PM   #7
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
There is no way to compare a newly designed motor with one that has been around for years. The only thing you can say is the 2.5 has more displacement, everything else is speculation. After people start modding and beating on the 2.5 we will find out how strong it is.
On another note, I have heard reliable rumors, if there is such a thing. That the legacy will have a turbo 3.0 H6 in a couple of years. Who knows if that will actually happen or not, but it would be pretty sweet.
slim speedy is offline   Reply With Quote
Old 05-10-2003, 03:00 AM   #8
stilesg57
Member#: 30670
1992 MR2 Turbo
Sure miss my old WRX
Interesting, I've heard the Legacy will carry over the 2.5L STi's turbo engine, tuned a little differently of course.
stilesg57 is offline   Reply With Quote
Old 05-10-2003, 05:01 AM   #9
oldmansan
Member#: 17877
Midnight Pearl
Default Heard the same
from my friend who works for Subaru.
San
oldmansan is offline   Reply With Quote
Old 05-10-2003, 03:05 PM   #10
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
We dont know yet. Thats the correct answer. We will have our STI in just 2 short weeks. When it arrives and after a few months of tuning we will have a better idea.
Facts right now:
In current motors going to a 2.5 is a backwards step due to the head castings. Major head work is needed to make the added displacement worth while. If the 2.5 uses the same STi head castings this new motor "might" not be the best thing since sliced bread.
The 2.5 STi is a US only motor and that scares the hell out of me. Japan still gets the 2.0's.
A 2.0 that spins to 8500 rpm with a short stroke and lighter rotating mass has a much higher power potential then a 2.5 ltr motor with long stroke and heavy rotating mass that is limited to 7k rpms. The new 2.5 has the writing on the wall to be that motor. Man I hope its a gem and thats all we can do right now is hope.
Its clear that Subaru gave us the 2.5ltr in the STI because they had to. 91 octane fuel really limits the power you can make with forced induction and as a result the turned to displacement to get the power to compete with the EVO.
CT
AZScoobie is offline   Reply With Quote
Old 05-10-2003, 03:57 PM   #11
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
clark-
in terms of modding.. which is a better purchase? the 4G63 EVO or the 2.5 USDM sti? i think the EVO is the better choice what do u think?
thanks
-mike
MJU1983 is offline   Reply With Quote
Old 05-10-2003, 05:12 PM   #12
Yungimoto
Member#: 14940
Originally posted by MJU1983
clark-
thanks
-mike
4g63 is a proven engine.... as was said before no one knows what the 2.5 can do yet.
Yungimoto is offline   Reply With Quote
Old 05-10-2003, 06:06 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
ya well... so it the ford big blocks but that doesnt mean there not out dated.
Old 05-10-2003, 10:25 PM   #14
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
The 4G63 is outdated? You think that a 2 liter motor that can push over 400 hp on stock internals is outdated? Ok if its outdated name a better 4 cylinder motor. The EJ20 is a great motor, but so far no one has proven its as strong as the 4G63.
Old 05-11-2003, 10:07 AM   #15
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
I love the R/S Rod stroke ratio of the EJ20s, it is ultimately better for power production and reliability at high hp levels. But the 2.5 should be just fine for a street or race motor. Neither is better, both represent two combinations of compromises. Some parts won't cross over as well as others.
Why is a longer rod set up better? The better r/s ratios produces lower piston speeds=Less cylinder side loading, Cooler running,cooler combustion temps(Run more timing Scotty!).
DeliciouSpeed is offline   Reply With Quote
Old 05-11-2003, 10:16 AM   #16
Jerry Hong
Member#: 6513
The turbo EJ25 is almost eh same as the NA 2.5 except for stonger webs, and semi decking.. the fisical size of an ej25 is the same as an ej20.. the new EJ25 is just stronger for boosting.. how can you bore a 2.5 to a 2.8???? or better yet.. why??? the most people do is a 2.6..
jerry
www.twr-racing.com
Jerry Hong is offline   Reply With Quote
Old 05-11-2003, 07:58 PM   #17
stilesg57
Member#: 30670
1992 MR2 Turbo
CT
This is exactly the case: remember that the Evo is getting knock right off the boat in California, and that's with 180whp (shiv's dyno - WRXs tend to hit around 160). Displacement is a very easy way to make more power - if two engines have different displacement but are otherwise the same making and making the same amount of power the one with more displacement is going to be less stressed. There are exceptions, but generally this is correct.
When a 2L turbo motor is getting knock on Cali gas only pushing 273hp, you either need to get that state some better gas or up the displacement if you want more reliable push
I think that should tell you about the 4G63: it's going to be easier to make more power on the STi's 2.5L. Whether or not the strength of the engine can hold it is another matter, but somehow I've got a good feeling about the STi engine...
Old 05-11-2003, 09:39 PM   #18
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
clark-
thanks
-mike
We dont know. I am like the others. I hope and pray the STi2.5 is the engine to beat. 4G63's have been around for a while. We all know what they can do. I dont think people are going to get much more out of the EVo's then they did the older 4G63's. I think history will repeat itself on turbos used and times run with the eclipse and Talon.
CT
Old 05-11-2003, 10:44 PM   #19
AEA-1919
Member#: 18768
I hear that the 4g63 has a problem with "crank walk". How does that factor in, considering we don't know for sure what problems arise in the STi's EJ25T?
Chris
AEA-1919 is offline   Reply With Quote
Old 05-11-2003, 10:52 PM   #20
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Chris
Chris, The older 4g63 motors did not have this problem. Only the newer versions in the later eclipse. This issue was supposed to be fixed with the EVO's updated engine. Time will tell.
CT
Old 05-12-2003, 12:39 AM   #21
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
CT
Oh well that sucks... I guess there will be a bunch of 9 second Evo's around then. Pretty damn slow huh?
Old 05-12-2003, 01:24 AM   #22
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I would hope so. Thats been done 10 times over.
CT
Old 05-12-2003, 02:51 AM   #23
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
Maybe we should declare Cali it's own country. Then they can have all there detuned, water/gas cars. Then the rest of us can get the good cars that can run crazy power on 94 octane. Sounds good to me. Let's take a vote. Call your congressman!
PAWRX is offline   Reply With Quote
Old 05-12-2003, 04:14 AM   #24
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
400hp on stock internals? I know the 4g63 is a strong engine, but didn't the EVO VII and VI have forged pistons? I know the US Evolution has cast pistons, and running 19psi on cast internals it seems like a pretty high state of tune. After cleaning up the fuel map and holding full boost to redline I'm sure the EVO will have more power than the stock STI, but in my opinion after similar tuning on the 2.5, it will yield a healthy increase in power. I think with equal mods the EVO will just be a step behind due mainly to the displacement of the STI engine.
I'm curious to find out what difference there will be changing the massive downpipe cat for a catless version! (The WRX has a 2L downpipe cat and the STI has no cat in the up-pipe so the downpipe has a 3L one!)
StealthWagon is offline   Reply With Quote
Old 05-12-2003, 09:47 AM   #25
Alleggerita
Member#: 8281
1967 Alfa Romeo GTA
Facts right now:
CT
Can you elaborate on the above statement and be more specific?!?
As this thread seems to be moving into an Evo vs. STI thread with regard to ultimate hp after modding, there is no doubt in my mind that the Evo with the right gas and pistons has ultimately more power potential due to its cast iron block. Remember the old 4 cyl BMW cast iron block in Formula 1! I don't believe that the Subaru blocj has the same strenght for ultimate boost. But I also suspect that it will always be the nicer street engine for the fuel we have here.
Alleggerita is offline   Reply With Quote
2.0 WRX vs. 2.5 WRX SS/GNX Newbies & FAQs 40 07-20-2013 04:20 PM
2008 sti engine 2.0 JDM vs 2.5 WM (World Market) Ferraz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-13-2008 07:16 PM
02 2.0 wrx vs 06 2.5 wrx mator Off-Topic 50 12-12-2007 11:00 AM
Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines TooSlow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 01-24-2005 12:14 AM
When motor goes...JDM 2.0 or US 2.5??? Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-03-2004 10:40 AM
