Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 05-09-2003, 10:17 AM   #1
joefocker20
Member#: 13745
2015 STI
Default TB Bypass
I tried to do this earlier, but couldn't figure out how to disconnect the hoses since there's little room to work. Any suggestions?
joefocker20 is offline   Reply With Quote
Old 05-09-2003, 10:42 AM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
elbow grease, and some needle nose pliers
Old 05-09-2003, 12:48 PM   #3
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
I suggest taking the air box off, if you havenít already this will give a little more room. You need some needle nose pliers or small pliers. You gotta squeeze the hose clamps and slide the down the hose. What I like to do in order to get the houses of is to take the pliers and squeeze the top of the hose. Then twist the hose back and forth and it should come off. Do the same for the other side.
AndyM is online now   Reply With Quote
Old 05-09-2003, 01:14 PM   #4
joefocker20
Member#: 13745
2015 STI
Yeah, I finally got the bright idea to take the airbox off, now I'm just going to wait about an hour and a half for my coolant to cool down since I just got home.
Old 05-09-2003, 01:26 PM   #5
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
That would have been a good time to put on the Cobb intake...
DanzBorin is offline   Reply With Quote
Old 05-09-2003, 01:28 PM   #6
joefocker20
Member#: 13745
2015 STI
Danzborin, thats ironic that you said that, I'm looking for a used one right now as we speak Also, while I'm waiting for my car to cool down, is it ok to use a plastic vacuum connector for this? I was going to buy a brass one, but autozone didn't have any.
Old 05-09-2003, 01:46 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
plastic is fine just be careful next time you're working around it as the plastic gets kinda brittle from all the heating/cooling.
Old 05-09-2003, 01:50 PM   #8
joefocker20
Member#: 13745
2015 STI
Cool, thats what I thought, I'll just put it on there and keep my eyes open for a brass connector next time I'm in a auto parts store or Home Depot.
Old 05-09-2003, 01:52 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I wouldn't even bother with the brass connector, just be careful next time you're working in that area.
Old 05-09-2003, 02:00 PM   #10
DanzBorin
Member#: 7131
2015 Outback - Croc
If I see one I'll let you know...
Old 05-09-2003, 02:23 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Make sure you dont bypass the IDLE controller, only the throttle plate portion.
Old 05-09-2003, 03:17 PM   #12
joefocker20
Member#: 13745
2015 STI
I just connected the two hoses on the sides of the throttle body, is that what you're supposed to do? I imagine I did it right, my car didn't have a fluctuating idle on the way home, and it seemed like doing this made a noticeable difference. I did have to buy a new fitting though, the 1/4" plastic fitting was too small, but a 1/4" brass one fit just right.. Odd..
Old 05-09-2003, 04:54 PM   #13
AndyM
Member#: 3219
WR Blue Pearl
Yeah just connect the hoses together. I would also cover up the sides of the throttle body, where the hoses used to be.
Here is a pic of mine its kinda hard to get a good pic of it, such a small space to get too, for a camera
Old 05-09-2003, 06:19 PM   #14
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I had my TB off when I did mine....so it was easier....but yeah...take the air box off, that should give you some more room.
Legacy777 is offline   Reply With Quote
Old 05-09-2003, 10:27 PM   #15
orndog
Member#: 34670
2013 No gears!
Saltine American
What exactly does this accomplish - and at what cost?
orndog is online now   Reply With Quote
Old 05-10-2003, 09:51 AM   #16
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Pros and Cons
Accomplishment:
It is supposed to allow cooler air to flow through the head since the coolant isn't heating up the throttle body 'valve' itself. Some people notice quicker throttle response.
Cost:
Well, it's a free mod unless you have to purchase a piece to connect the hose where it used to connect to the throttle body. You could just cap it off.
Cost: If you are in a cold climate, your throttle body valve could freeze up and not open (or close) due to ice forming where the 'coolant' heated it up.
I think that may sum things up. There are some older long threads on this here.
Kevin Thomas is offline   Reply With Quote
Old 05-10-2003, 05:14 PM   #17
orndog
Member#: 34670
2013 No gears!
Saltine American
Thanks, I think that covered it. The "cost" I was referring to was your last point. I didn't mean money, I just figured those lines were where they were for a reason.
TB bypass observation IggDawg Normally Aspirated Powertrain 18 11-16-2002 03:08 PM
Another darn TB bypass thread HamFist Normally Aspirated Powertrain 46 09-28-2002 12:56 PM
TB Bypass ImprezaRSX Hawaii Impreza Club Forum -- HIIC 2 09-28-2002 12:15 AM
Did the TB bypass mod today ImpreziveRS Normally Aspirated Powertrain 15 09-22-2002 09:56 PM
Just did the TB bypass mod... IggDawg Normally Aspirated Powertrain 46 09-19-2002 10:00 AM
