Old 06-13-2003, 12:49 AM   #51
StormCrow
Member#: 33572
2001 2.5RS Coupe
Silverthorn
2001 2.5RS Silverthorne
Suspension
20mm sway bar off a donor WRX
Kartboy Endlinks
KYB AGX Struts
Prodrive P1 springs
STi strut mounts (front and rear)
SS Brake Lines
WRX Front/Legacy Back Disc Upgrade
Appearance
Clear sidemarkers
Clear corners
Trunk Light
Rubber Subaru Floor Mats
Replica mesh fog light covers
StormCrow is offline   Reply With Quote
Old 06-13-2003, 05:28 PM   #52
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Default it's a small list......
drivetrain:
'93 Legacy 2.2L closed deck turbo motor (used part)
'95 JDM WRX tranny (used part)
Clutchmaster stage III clutch
S.S. clutch line
hydralic clutch assembly from some Subaru (used part)
'01 RS rear LSD & axles (used part)
STi motor mounts
light weight crank pully (used part)
K&N cone filter (with homemade air box)
Greddy FMIC (almost finished installing)
Forge DV (used part)
manual boost controller
custom 2.5" exhaust from downpipe back...no muffler
Opitima battery in trunk (this weekend)
Autometer EGT gauge (used part)
ISSPRO boost gauge 15psi (used part)
Autometer gauge pod
Kartboy shiftknob (used part)
Kartboy short shifter (will be installed when I can change out shifter linkage) (used part)
Impreza gauge cluster w/tach (didn't have tach originally) (used part)
custom catch can (used part)
Link+ ECU
Suspension, etc:
DMS 40mm coilovers (used part)
STi rear strut tower bar (used part)
STi rear top hat (used part)
generic front strut tower bar
20mm FHI rear sway bar (used part)
RS endlinks (used part)
MRT adjustable rear lateral links (used part)
Cusco front camber plates (used part)
Legacy 2pot front brakes w/EBC green (used part)
rear disk brake conversion from '02 WRX (used part)
SS brake lines & Motul 600
exterior:
'00 RS hood, bumper & headlights (from 2 different cars) (used part)
Version V replica grill
RS side skirts (waiting for clips) (used part)
MRT intake scoop
'01 RS 16x7 wheels w/AVS S1 (used part, yes both)
'93 Legacy 15x6 wheels w/Falken Azenis (used part, just wheels)
ADR 16x7 wheels w/all season tires
need 15" wheels for Kumho V700s
Team ARG!
Scoobyslack1 is offline   Reply With Quote
Old 06-23-2003, 11:47 PM   #53
Hondakilla
Member#: 13610
2001 2.5 RS Sedan
2001 Aspen White RS Sedan: This is what is done so far in my process of converting it to a WRX STi Version VI and a couple other goodies!
Painted side skirts
painted bumper vents
clear lenses all around
STi clear tails
98 5spoke Gold wheels
Authentic STi Ver. VI wing
Authentic STi Ver. VI trunk lid
STi Ver. VI front and rear seats
STi Ver. VI Steering Wheel
Next in line!!!!
STi Ver. VI RA suspension
20mm Rear sway bar
Group N mounts and bushings
WRX swap w/ scoobysport exhaust or STi Version 6 RA exhaust
Hondakilla is offline   Reply With Quote
Old 06-24-2003, 12:25 AM   #54
NimrodBoz
Member#: 18500
2005 OBS
Additions:
New head gasket, spark plug wires (NGK), water pump, and oil pump.
Going in tomorrow :
NGK GP Platinum spark plugs
KYB AGX struts
maybe new wheels and also maybe 2002 WRX seats
painted scoop cover (red)
painted calipers (red again)
painted new STi badge (also red)
im running a Silver/Black/Red theme.
NimrodBoz is offline   Reply With Quote
Old 06-24-2003, 02:48 PM   #55
powelldl
Member#: 20215
1999 impreza 2.5 rs
silverthorn
93 octane...it's the good stuff
powelldl is offline   Reply With Quote
Old 06-24-2003, 10:32 PM   #56
NimrodBoz
Member#: 18500
2005 OBS
i was recently told (as in today) by a reputable subaru fanatic that using 93 octane fuel is better for all engines, regardless of type. ill try out some 93 in the ol' sube next time i fill the tank and we'll see whats up.
Old 06-25-2003, 09:00 AM   #57
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You guys running 93 are wasting money. Unless you've raised your compression through forced induction or high C/R pistons or are running a very aggressive timing curve there is absolutely no benefit to using 93. The RS was designed to run on 87, 89 might get you 1 or 2 degrees extra timing advance but 93 is most certainly slowing you down... remember octane is the resistance to detonation (proper and pre). You want to use the lowest octane that doesn't knock, period.
Old 06-26-2003, 12:02 AM   #58
NC2.5RS
Member#: 19313
2007 Scion tC
Black Sand Pearl
2000 Impreza 2.5RS Blue Ridge Pearl Coupe
Suspension
JDM Version 5 STi struts
5Zigen springs
Cusco adjustable camber pillowball mounts
Engine/Exhaust
MRT headerback exhaust w/ gutted stock cat
Magnaflow straight through muffler
Cobb Tuning Cold Air Intake
Motul synergie 6100 oil
Interior
A-pillar mounted Autometer Air/Fuel Ratio gauge
A-pillar mounted boost gauge (for forced induction that will occur in the future)
Exterior
DIY hoodscoop grille
DIY bumper grille
STi pink "I" badge
Stock 2000 RS wheels wrapped in 205/50/16 Kuhmo Ecsta Supra 712s
Soon to be Purchased
STi red/white tail lights
clear corners and sidemarkers
upgraded rear swaybar
NC2.5RS is offline   Reply With Quote
Old 06-26-2003, 10:28 AM   #59
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Originally posted by Jaxx
hmm havn't done one for this car so
1993 L AWD
suspension
RS front breaks
rear disc conversion
sway bar added 20mm
kyb agx
sti RS springs
cusco front cradle brace
rear strut tower brace
mrt front castor camber plates
metal master brake pads
sti group-n a-arm mounts
whiteline steering rack bushings
sti motor and tranny mounts
About how long does it take to do the rear disc conversion? and I take it you got the rear disc's from a legacy?
SubaruImpreza_power is offline   Reply With Quote
Old 06-26-2003, 10:32 AM   #60
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
took 2 of us about 3-4 hours including SS lines all around
Old 08-02-2003, 01:24 PM   #61
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
1998 "2.2 RS"
-Black 2.2 L coupe
-Clear corners/front turn signals, smoke/clear sidemarkers
-Subaru windshield banner
-Blue painted front badge
-99 RS wheels
-RS sideskirts
-RS coupe spoiler
-Debadged "Impreza" from trunk
-Rebadged "Impreza" on steering wheel over Subaru
-K&N cone filter with MAF adapter
-Engine grounding
-20mm FHI rear sway bar
-MOMO Air Leather knob (half aluminum)
-short shifter with stock bushings, cut 3/4" shorter too!
-WRX Leather shift boot
-1998 Legacy GT CD Player (that lights up with blue LEDs! )
-Kenwood speakers all around, rears powered by Alpine amp
-Tweeters in doors
-two 10 in MTX subs in a bandpass box powered 300 watts a piece
-Dynamat Xtreme in floor pans
twizzstyle is offline   Reply With Quote
Old 08-02-2003, 03:18 PM   #62
spriteman14
Member#: 40937
1996 Impreza (coupe)
Savanna Green Metallic
i got a CB deck in the console with a bullhorn under the hood. no antenna for the radio, but the PA system is fun! not expected in a scooby.
painted the hubcaps gloss black. i'll try to get a photo up later.
spriteman14 is offline   Reply With Quote
Old 08-04-2003, 01:30 PM   #63
Keshav
Member#: 1654
1998 GC8 Unicorn
MV Agusta Brutale S
This won't change much until the house is purchased...
1998 Arcadia Green Impreza RS
In order of appearance...
Plastic bug shield on hood removed - previous owner had questionable taste
20mm WRX rear sway bar
JDM clear corners
leather shift boot (98's came with amazingly tacky rubber one)
cruise control kit (still in box)
Yokohama AVS Intermediates in stock size
Kartboy shifter bushings
Keshav is offline   Reply With Quote
Old 08-09-2003, 02:45 AM   #64
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Hey spriteman . . . how much was ur PA and was it easy it install? I always wanted one to screw around with. you know make blow of valve noises when shifting next to *******s and maybe hook up an F1 sound to it as I pass people.
2.5RSMatt is offline   Reply With Quote
Old 08-12-2003, 12:47 PM   #65
RSmatt
Member#: 8039
94 v2 STi RA - RHD
'01 Blue Ridge Pearl RS
Performance/Handling
'96 L intake pipe with cone filter
MrJosh lightened crank pulley
Borla header
2.25" Hi-flo cat
Rallispec 2.25" single piece cat-back
Falken Azenis 205/55 on stock rims
M2 DMS 40's
STI strut tops
Whiteline 18-22 rear sway bar
Whiteline heavy duty sway bar mounts
Whiteline endlinks f/r
Kartboy short shifter w/bushings
Appearance
Ver 5/6 lip
Rear spats
Painted sideskirts
Ver 6 spoiler
Complex Morette's
Custom painted corners lamps w/DIY clear
Clear bumper signals
Clear fender signals
STI tail lights
Snowman bumper vent mod
STI Ver 5/6 seats F/R
Hella supertones
RSmatt is offline   Reply With Quote
Old 08-13-2003, 09:43 PM   #66
DragonRM
Member#: 14365
Default updatzors!
2000 Silver Sedan:
Cobb Tuning Stage1 Suspension
(Cusco F/R Tower braces, rear sway)
Cobb CA Intake
Stromung Dual Tip Exhaust with racing midpipe
F/R Drilled/slotted rotors
Prodrive RB-5 wing
Ociari Front lip
STI Rear Spats
Some brand, might be bomex replica grill
Carbon Fiber Tail lights (Please no flames for these, I hate altezza style lights but these look good on the silver )
17inch Millias with Kuhmos (got all seasons and hp summers (whee :P )
Hella Dual Tone air horns
Some misc blue painted engine bay parts
Tinted Windows
Smoked sides and clear corner lights
Smoked Foglight Covers
Xenon lights/foglights/corners
Painted Brake Vents
Some small misc decals (rs25.com )
New windshield with a different tint bar... old one was cracked but I'll list it anyways
Pro Ecm Chip
Kyb AGX's with Prodrive Springs
Painted Calipers
Paranoid Fab Grounding Kit
Lightened Pulley Set
Cobb Equal Length Headers w/high flow cat
might be more but I can't think of what right now
Interior:
Carbon Fiber Interior (not the dealership one)
Carbon Fiber Bezel trim
Reverse Indiglo Gauges
Panasonic Mp3 stereo
20 gig player
RF 400 watt amp with 18inch sub
Infinity Interior speakers
Next Mods: SS Brake Lines, Tranny Upgrade hopefully with some type of sport shift (I drive stick but mine's an auto, long story ), and Turbo/SC or swap... leaning towards s/c since Hamfist is nearby and I might be able to afford that first
DragonRM is offline   Reply With Quote
Old 08-14-2003, 11:10 PM   #67
Kennis
Member#: 39870
1995 Impreza
Metallic Green
1995 2.2 LX
Carbon Fiber Hood (TC SPORTLINE)
CUSCO scoop and vents (1 piece)
Weapon-R Dragon TRUE Ram air intake (hooked up to scoop)
Mr. Gasket Hood Locks
Custom Front Strut bar
Projector Head Lights (PIAA blubs H7)
All Lenses Cleared
Perrin Light weight Pulley
Denso Iridium Spark Plugs
Sprint Lowering Springs
PIONEER DEH-7300
4 PIONEER 6.5 in. 220 watt max speakers
Cobra Eyes (on a 50 AMP switch so I dont get pulled over)
AND MY REAR SEATS FOLD DOWN!!!!
I need some new Rims and Wheels
Any suggestions?
Please email me with suggestions or offers.
Kennis is offline   Reply With Quote
Old 08-15-2003, 03:05 AM   #68
BROCKSPENCER
Member#: 41809
02 2.0 wrx
BLUE
all stock
aftermarket stereo
PLANS
cutom intake
greddy muffler 2 1/4 in tubing cat back
gauges and gauge pods
if i can find a turbo kit i will turbocharge it
c-west body kit
BROCKSPENCER is offline   Reply With Quote
Old 08-16-2003, 10:47 PM   #69
Tats
Member#: 5692
WTF? YES! I am
better than you!
MY01 BRP RS Coupe:
Performance:
Garrett GT 25 BB Turbo
HKS SSQ BOV
AVO Bar and Plate TMIC
AVO Up and Down Pipes
Custom 3" Catback w/ Magnaflow Muffler
Urethane Hangers
Link Engine Management
N1 Lightened 3 Pully Set
Exedy 13lb Flywheel and Clutch
Kartboy SS w/Bushings
Whiteline Front and Rear Strut Bars
Whiteline Front and Rear Endlinks
Whiteline 18-22mm Rear Sway Bar
STi Motor and Tranny Mounts
Eibach Pro Kit
KYB AGX Struts
STi Front and Rear Strut Top Mounts
Sti 4-Pot Front Calipers w/DBA Gold Rotors and Hawk Pads
Legacy Turbo Rear Calipers w/DBA Rotors and Endless Pads
Front and Rear SS Brake Lines
Exterior:
22B Hood Vents
STi Fog Light Covers
Pink "I" Badge
CF P1 Lip (In the mail)
CF STi Sized Hood Scoop (In the mail)
Version 5 Spoiler
Interior:
CF Instrument Cluster Bezel
E*Speed Racing Seats
Sparco Harness
WRX Steering Wheel
STi WRC Titanium Shift Knob
E-Brake Leather Boot Mod.
Valentine 1 Radar Detector w/Remote Display
Defi Center Console Pod w/Defi-Link 60mm Oil Pressure, Boost, and EGT
Dual Pillar Pod w/Defi-Link 52mm Oil and Water Temps.
Autotechnic A/F Gauge in Pod on Steering Column.
I Think that's it.
Tats is offline   Reply With Quote
Old 08-23-2003, 06:15 PM   #70
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Got some new mods so I'll go again:
Suspension:
5zigen springs
KYB AGX struts
Cusco 21mm rear sway bar
Performance:
Tanabe Hyper-Medallion cat-back exhaust
COBB CAI
Other:
Kartboy SS
Clear parking lights and turn signals
Pink stars badge w/ gold stars (true JDM baby)
momo shift knob
WRX stock cd changer
18" Prodrive P1's w/ 215/40 P7000's
JewPac42 is offline   Reply With Quote
Old 08-23-2003, 10:48 PM   #71
DragonRM
Member#: 14365
Old 08-24-2003, 12:50 PM   #72
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Well, here's my OBS... nothing speial
MY99 Outback Sport
Awaiting installation of...
H&R Springs
Kartboy short shifter with bushings
Hawk front pads
ATE super blue racing brake fluid
Upcoming mods (by November 1st)
Cat-back exhaust
Borla header
KYB AGXs with STi Upper Mounts
World Rally Blue paintjob
RS front end conversion
Replica STi wing
Sooner or later mods
LudeSpeed Stage 2 turbo (by December)
Rebuilt block
LINK PEMS
10+psi
(in that order)
Soon2BturbodRS is offline   Reply With Quote
Old 08-24-2003, 07:30 PM   #73
shiseiji
Member#: 42258
1993 Impreza L sedan
Agean Blue
Wow, some of you guys went nutz on yours. Some long lists on here. Mine will be much shorter. Nothing too special.
93 Impreza L sedan 2wd 1.8
Have done:
Modded intake(removed airbox, using universal cone filter at the end of the stock tube)
Upgraded tires(185/70R13 now)
WRX shifter knob will be on it's way soon.
Want to do:
Modded exhaust(not sure how just yet)
WRX or RS wheels
Rear sway bar
Front links(maybe)
Window tint
Hotter coil, wires, plugs
Clear lighting all around
Hella driving lights
Hood protector
Kinda on a budget....
J
shiseiji is offline   Reply With Quote
Old 08-25-2003, 08:27 PM   #74
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Time to re-post,The list has grown.....
Engine:
Rallispec Intercooler
HKS Blow off valve
HKS Mega flow intake
IHI VF-22 Turbocharger
Unique motorsports up and downpipes
RC engineering 440cc Injectors
Link plus engine management
Exedy street clutch
Exedy Flywheel
Tanabe Hyper medallion backbox
Kartboy exhaust hangers
Suspension,brakes,wheels etc.....
SPt springs
20 mm rear sway bar
WRX wheels,Falken Azenis tyres (street)
RS wheels,Falken tyres (215 45-16,auto-x)
Legacy 15inch alloys,Falken Rallye tyres,(winter)
WRX front brakes
Legacy rear brakes
STi V4 typeR seats
STi V2 typeR steering wheel
(yes those last two are suspension related)
Stainless brake lines
Drift alignment.
Dress-up
STi Ver5 rear spoiler
Sym's Grille
STi hoodscoop
STi6 lip spoiler
STi6 spats
painted skirts
RS-t badging
STi foglamp covers
STi exhaust garnish
STi taillamps
Clear corners
Ben,
Old 08-31-2003, 03:12 AM   #75
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Default Basically stock but not for long
Car...
'99 Impreza Outback Sport
Color...
Silver/tan... soon to be world rally blue
Engine...
Stock ej223
Engine...
Removed intake "snorkus"::no noticable increase in power... engine is louder, deeper, and much more throaty from 4k to redline.
GReddy 1.3bar radiator cap::I know, I know... but I had to drive the car from Milwaukee, Wisconsin, to Portland, Oregon, in the dead heat of summer and needed some insurance to keep my mind on driving and off of overheating.
Drivetrain...
Stock
Suspension...
H&R Sport springs::Lowered car significantly (noticable if you saw the car often), improved cornering abilities exponentially, almost non-existant body roll, all good things
Wheels/tires...
Stock 15" Alloy Wheels
Stock BFGs
Brakes...
Hawk HPS Front Pads::Noticable braking performance increase, lessoned fade, same brake pedal feel
Exterior...
Debadged trunk::Much much cleaner looking arse.
Removed 'Outback Sport' decals from sides::I was bored.
Interior...
Stock...completely
Mods to be done before January 1st...
AVO Turbo Kit
AVO Boost Gauge
Exedy Clutch
Rallitek 2.75" Turbo Exhaust
Bridgestone RE750s
MY98 2.5RS 16" Wheels
Triple-gauge Pod with EGT, Air/fuel, Oil Pressure Gauges
In-dash CD Player
I know it is a lot but it IS GOING TO BE DONE... but don't quote me
PS: Sorry for all the writing but it makes it look like I have more mods than I do
Post your mods on your Legacy Legacy05 Legacy Forum 27 06-03-2012 09:46 PM
Who's had a Piston Failure? Which one? Post your mods. Scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 180 01-09-2007 03:39 PM
please post your mods on your 05 legacy SubieSky Legacy Forum 14 08-04-2005 11:00 PM
