Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 05-10-2003, 04:28 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default Need injector pulse width help...
Yesterday I was out tuning with RiftsWRX and found that stock injectors on an RS-T say 100% duty cycle at 7.3ms at ~4800rpm (4-5psi boost). Now this goes a bit against what I've been reading for equation-wise. Normally the rpm/ms equation goes like this:
rpm/2/60=x
1000*(1/x)=ms available/rotation
So at 4800 rpm
4800/2/60=40
1000*(1/40)=25ms
What? how could it possibly be reading 100% duty cycle with only 7.3ms of injector on-time when there is 25ms available?
I thought it was a software glitch, but I began to believe it as we were testing and watched the A/F's [edit] rise rapidly after hitting that 100% duty cycle point.
Does this seem a little odd to anyone else? Is there a flaw in my numbers somewhere?
8Complex is offline   Reply With Quote
Old 05-10-2003, 10:00 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
I agree with your calculations.
For any particular 4-stroke cylinder:
Revolutions per Minute / 2 (ignitions per minute) / 60 = x (ignitions per second)
1000 / x = milliseconds interval between cylinder firings.
I thought it was a software glitch, but I began to believe it as we were testing and watched the A/F's drop rapidly after hitting that 100% duty cycle point.
If you saw your "A/Fs drop rapidly," then I presume you saw your A/Fs drop from, say 12:1, to 10:1, which I agree is a substantial drop. But I don't see a problem with this.
Jon [in CT] is offline   Reply With Quote
Old 05-11-2003, 01:21 AM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
He meant rise.
from 11.1 startup shooting up fast to the 12's and 13's
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-11-2003, 04:10 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, my mistake. For some reason I always think it opposite direction even though I know better reading it. They rose very rapidly... within about 5-800rpm they rose from a nice 11.0:1 up to low 13.x:1's.
So if there is no error in my math, I wonder why the ECU is telling me that 7.3ms is 100% duty cycle at 4800rpm...
Old 05-11-2003, 04:55 PM   #5
Z1 Performance
Member#: 9327
Could be your fuel pressure trailing off...have a guage hooked up?
Ada,
Z1 Performance is offline   Reply With Quote
Old 05-11-2003, 05:24 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hmmm... there is a mechanical gauge underhood I might be able to extend and tape to the window, but the car has a Walbro 255 in it.
I'll check that out as soon as the weather clears up a bit (damn 40mph winds here today), though I'm still wondering why the ECU says it's gone 100% duty cycle at such a low opening time.
Re-analyzing the math here...
rpm/2/60=x
That formula isn't correct now that I look at it. That shows amount of time of all 4 cycles for a single cylinder. Obviously you aren't going to be spraying during the latter stages of compression (depending on overlap, of course), not at all during ignition, and most of the exhaust cycle (depending on overlap as well). So realistically if we want to narrow it down to 2 of the strokes of the 4, we're talking about actual rpm's, not half. So the corrected equation would be :
rpm/60=x
1000*(1/x)=ms/true rpm
What this means is that the previous possible opening times have now been cut in half to [email protected]
So now, I suppose, if the ECU really wants to use strictly the intake stroke to fire the injectors, it will really only be seeing a 6.25ms opening window. This seems much more likely to me... I will have to re-read into the logs to see exactly when it starts to fall off as the previous [email protected] was estimations off the top of my head and could have been another factor in odd numbers.
So now in the end, we're almost looking at a calculation like this:
rpm/60*2=x
1000*(1/x)=ms/single stroke
Old 05-11-2003, 07:03 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
rpm/2/60=x
First, if by ECU you mean the stock ECU, then the ECU doesn't actually report "duty cycle." It does report RPM and injector pulse width for the #1 cylinder. Some software in your PC is calculating injector duty cycle from those two variables.
100% injector duty cycle does, in fact, mean that the injector is continuously open, through all 4 engine cycles.
Old 05-11-2003, 09:13 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
No, it's running a Haltech E6K with staged injection, which I believe is basically sequential injection with secondaries.
Old 05-12-2003, 01:06 PM   #9
Z1 Performance
Member#: 9327
There's part of your problem...Haltech's only allow max IDC of 80% from what I remember.
Adam
Old 05-12-2003, 02:37 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Thats fine though, this car will never see all 830cc's of injection at the same time when the secondaries kick in. I just need to get them plumbed in and move the crossover point to starting up the secondaries lower and it should be fine. My only problem at this point is the tiny budget that I'm under... looks like it's going to be twin fuel systems. WRX pump for the stock injectors and Walbro 255 for the 550cc secondaries.
Old 05-12-2003, 04:23 PM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Sounds like party time
You need my pump then?
Jorge (RiftsWRX)
www.ProjectWRX.com
No injector pulse?! Please help! JordanHoudek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-22-2009 03:04 AM
Need help with injector pulse width settings LiquidForce Commercial ECU Reflashes 2 08-13-2006 03:21 PM
Injector Pulse Width Change qhatherly Engine Management & Tuning 1 06-11-2005 01:16 PM
How to extend the injector pulse widths by cylinder john banks Engine Management & Tuning 16 09-16-2003 02:16 PM
Injector Pulse Width to Injector Duty Cycle SonicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2002 10:36 AM
