Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 05-10-2003, 12:08 AM   #1
Member#: 12863
2002 2.5RS
Default Amsoil vs. K&N
Which is the better of the two. I did a search and to my surprise didn't find much info at all.
Which has the best performance with the safest and most reliable filtering capabilities. I still worry that some contaminant will pass through a non stock air filter.
mike270 is offline   Reply With Quote
Old 05-10-2003, 08:46 AM   #2
Member#: 13486
06 Legacy GT wagon
I think the Amsoil might filter better, but just maybe the K&N might flow better, despite Amsoils claim to be better at everything. I have the Amsoil with PDM intake on my 2002 OBS, and a friend has an identical setup, except for K&N. The sound from his was a more audible whooshing hiss if he blipped the throttle from idle. Mine sounds more dampened or muffled. Could be that the thick Amsoil foam dampens the sound better is all, without affecting flow.
The Amsoil definitely filters effectively. I bought it in December and just washed it, after a winter of several muddy rallycrosses and a rallyschool. There was a noticeable spatter of mud where I ingested water to the filter, but all clean on the other side. Much better power now with a clean filter, so it definitely did what it was supposed to.
codger is offline   Reply With Quote
Old 05-10-2003, 09:43 PM   #3
Member#: 32241
1998 Impreza L Coupe
Just put an Amsoil on my 98 L Coupe with 2.2 engine. Am disappointed with Amsoil's quality compared to K & N. The Amsoil filter flange that seals the filter to the housing is thin foam and arrived bent and distorted. I hope I got it in correctly and that it is not bypassing dirty air. K & N filters with their OEM type rubber sealing flange do not have this problem.
My 2 cents,
Roy is offline   Reply With Quote
Amsoil vs Mobil 1: wow, what an improvement Amsoil is over M1 scooterforever Service & Maintenance 30 07-03-2007 09:43 AM
redline Vs. amsoil Vs. mobile1 OREnative Normally Aspirated Powertrain 8 10-19-2005 05:58 PM
Amsoil or K&N? CrazyMike13 Off-Topic 8 12-28-2003 05:01 PM
Amsoil VS K&N allwheeldrive Normally Aspirated Powertrain 9 07-23-2002 01:34 PM
K&N vs. Amsoil vs. ITG Yebisu69 Normally Aspirated Powertrain 4 01-04-2002 08:22 AM
