Old 05-10-2003, 05:52 PM   #1
nogger
Member#: 17797
Default Replacing the oilpan
My younger brother punctured the oil pan on my 1993 impreza L (1.8L). Is it possible to replace the oil pan without pulling the motor? Some of the bolts looks really hard to get to, because of the crossmember. Also, would I have to get a new oilpan, or could I have the punctured one welded? (it is a 1/8" slit)
~~Quentin
nogger is offline   Reply With Quote
Old 05-10-2003, 08:26 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you can get to the rear bolts with a 10mm 1/4 drive swivel socket, its a pita but can be done.
or you can unbolt the motor mounts and jack the motor up to get to them easier.
Jay
Old 05-11-2003, 12:02 AM   #3
nogger
Member#: 17797
so a full motor pull isn't necessary . thanks, very much.
~~Quentin
Old 05-11-2003, 08:39 PM   #4
MattDell
Member#: 16803
Q, try logging out next time.
-Matt
MattDell is offline   Reply With Quote
what all to replace while replacing the clutch? prometheum Transmission (AT/MT) & Driveline 18 11-21-2008 10:45 PM
Anyone ever replace their oilpan? D_Block Mid Atlantic Impreza Club -- MAIC 8 09-07-2005 10:05 PM
Replacing stock downpipe - what bolts do I need to replace the spring bolts? ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-22-2004 01:33 AM
what's a replacement boost gauge to replace the oem one? ldivinag STi Forum Archive 4 06-25-2003 01:17 AM
replaced the T and the hose and the restrictor now the check engine light comes on scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2002 10:21 PM
