Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 05-12-2003, 12:17 AM   #1
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default What parts are needed for Headgasket change?
WHat other thean the head gaskets do I need for this change. My buddy who is a subaru mechanic said that since the heads are coming off the cam timing needs to be timed correctly as well as the belts need to be changed over too. He aslo said I was in need of main seals and other camshaft seals that I did not know of. I know that exhaust manifold and intake manifold gaskets need to be changed to but what other misc parts do i need, i.e. seals, bearings and so forth.
thank you.
John
Cusco is offline   Reply With Quote
Old 05-12-2003, 12:42 AM   #2
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
The gasket itself is the only thing that HAS to be changed. But its a good idea to replace the rest of the gaskets while its apart. If the engine has high miles you may want to have the valve seals replaced also. For my laser Mitsubishi makes a nice kit that has everything you would want to replace when you do the headgasket. Its called the upper engine rebuild kit or something like that. Maybe Subaru has something similar? Check with your local dealers parts department.
slim speedy is offline   Reply With Quote
Old 05-12-2003, 05:38 AM   #3
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default thanks
thanks
Old 05-24-2003, 02:56 AM   #4
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Shouldn't you use new head bolts too?
vrg3 is offline   Reply With Quote
2.5rs swap. what parts are needed? ILwrx Subaru Conversions 2 10-03-2005 04:58 PM
What parts are needed to turbo a MAP sensored RS? Homemade WRX Normally Aspirated with bolt-on Forced Induction Powertrain 19 12-10-2003 12:21 AM
what parts are needed for 6spd? cronic Subaru Conversions 2 09-23-2003 12:51 PM
what other parts are needed for turbo conversion halftendril Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-14-2003 12:57 AM
What parts are needed for Autometer Ultralite A/F guage install? Robmat Normally Aspirated Powertrain 4 03-03-2002 06:45 AM
