Old 05-12-2003, 01:13 AM   #1
303
Member#: 21323
2003 Impreza WRX
Default black strip by wrear wheel wells
anyone know how to take these off(vertical strip of black plastic in front of rear wheel wells)? im planning on painting them, and i went to pull it off and something snapped. i thought they were just clipped on, but it looks like thers more than that. anyone know how to take them off?
303 is offline   Reply With Quote
Old 05-12-2003, 01:44 AM   #2
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default Re: black strip by wrear wheel wells
I tried to take mine off to paint them. Broke one off. Really the only way to get them off is to break them. The back sides are sealed in the fender, and you can't get to the clips from the front.
I ordered replacements from the dealer, but they didn't get here in time to be painted with the rest of my stuff
fragment is offline   Reply With Quote
Old 05-12-2003, 11:37 AM   #3
303
Member#: 21323
2003 Impreza WRX
how did you end up putting them back on? double sided tape? thanks for your reply
Old 05-12-2003, 03:04 PM   #4
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
You have to buy new clips (not included with the strips ) Then you just push them back into the mounting holes.
Old 05-13-2003, 01:23 AM   #5
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Got a part number(s) for my lazy arse?
CirrusWRX is offline   Reply With Quote
Old 05-13-2003, 01:34 AM   #6
303
Member#: 21323
2003 Impreza WRX
id like those part numbers also(im lazy too)
Old 05-13-2003, 11:06 AM   #7
kenchan
Member#: 15106
i would just mask it and paint it on the car...
kenchan is offline   Reply With Quote
Old 05-13-2003, 11:21 AM   #8
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
When the parts guy at Subaru lets me know they're in, I'll get the numbers and post them. I don't have them right now.
Old 05-13-2003, 11:22 AM   #9
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Problem with that was the "booth" in my buddies garage wasn't big enough; parts size only.
Old 05-14-2003, 12:09 AM   #10
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
much appreciated - thanks in adavnce
Old 05-14-2003, 01:28 AM   #11
syncros
Member#: 30032
2005 Impreza wagon
black
I snapped mine off; both peices came out with the upper mounting posts intact, but the retaining peices broke off inside the fender well. To get them back on after I had them painted, I applied a bead of automotive silicone sealant/adhesive all around the inside edges of the peices. They're contoured to fit the body of the car; I just used the upper posts as a guide when putting them back on, applied some pressure for a few minutes, and the silicone did the rest. They stay on just fine. No need to order new ones.
Thanks,
Syncros
syncros is offline   Reply With Quote
Old 05-16-2003, 10:09 PM   #12
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default Part Numbers
Ok, just got the parts, and have installed them.
Protector Quarter panel LH: 91022FE010
Protector Quarter panel RH: 91022FE020
Clips (4): 909140023
Old 05-17-2003, 01:28 AM   #13
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
THANK YOU!
Black rubber strip over rear wheels Ryan314 Interior & Exterior Modification 10 09-25-2009 11:21 AM
[art number needed, little black thing by rear wheel well above side skirt jimtweet Interior & Exterior Modification 20 05-13-2006 09:53 PM
Removing rubber strip on rear wheel wells 1BadEJ20 Interior & Exterior Modification 6 10-28-2004 03:23 PM
help me remove mirrors and black strip by wheel well 303 Interior & Exterior Modification 7 05-01-2003 06:30 PM
Is the rear wheel well smaller? 8Complex Technical Forum Archive 10 06-22-2000 08:53 AM
