Old 05-12-2003, 12:27 PM   #1
scrappy doo
Member#: 36215
2002 impreza outback
dented to hell
Angry crap what happened to my engine?
ok so i was driving my car around on friday night in 3rd gear and all of the sudden this loud metal clanking sound came from my car and it lost all power. i pulled over and looked for any visible damage but found none. so i try to start it again and theres this loud clank when i try to turn it over and the engine wont start. the cylinder was replaced once and i'm guessing the repair guys f*d something up. could a valve have broken inside? any thoughts? 01 2.5 RS with 4,000 miles
scrappy doo is offline   Reply With Quote
Old 05-12-2003, 12:58 PM   #2
dorikin
Member#: 30640
2013 WRX 5dr
ouch, seized?
how's the oil look? (if there's still any in there!)
timing belt still where it should be?
dorikin is offline   Reply With Quote
Old 05-12-2003, 02:58 PM   #3
scrappy doo
Member#: 36215
dented to hell
nah it's not seized, and the timing belt still looks ok, i took it to the dealership and they're checking it out...they think the timing belt may have something to do with it though, might have slipped a couple teeth or something. ugh.
Old 05-12-2003, 03:16 PM   #4
IMPREZA619
Member#: 24289
hope your speed over
the Rival.
sounds what happend to my 00rs a couple months ago. does it still start up? did you hear a tapping or knocking sound? it could be a bad rod or bent valve. hope you sill have your 60k warrantee. i had to replace the whole shortblock assembly, luckily it was free.
IMPREZA619 is offline   Reply With Quote
Old 05-12-2003, 04:50 PM   #5
scrappy doo
Member#: 36215
dented to hell
uh no it wont start, when i try it makes a metal clanking sounding noise...not good. when it broke it sounded like that machine gun sound you can make with your mouth, just a lot less cool sounding. hopefully it's covered under the warranty though. wont find out until they figure out what's wrong with it.
Old 05-12-2003, 06:08 PM   #6
scrappy doo
Member#: 36215
dented to hell
just got word back from the dealer... dun dun dun.....he told me the tensioner bolt for the timing belt broke, which f'd up my timing which f'd up my valves, so now they have to pull apart the heads and check to see what valves have been f'd. yippee. about 1500 bucks in labor, not including parts. check your tensioner bolts!
Old 05-12-2003, 06:23 PM   #7
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
So Im guessing its not under warranty? Why not?
DDMan is offline   Reply With Quote
Old 05-12-2003, 07:27 PM   #8
scrappy doo
Member#: 36215
dented to hell
salvage. damn theives.
Old 05-12-2003, 09:17 PM   #9
obyone
Member#: 16523
Your car has a salvage title?
obyone is offline   Reply With Quote
Old 05-12-2003, 11:27 PM   #10
ilan3
Member#: 27235
2000 Impreza RS
Red
What is the tensioner bolt, where is it, and how do we check it???
ilan3 is offline   Reply With Quote
Old 05-13-2003, 11:44 AM   #11
scrappy doo
Member#: 36215
dented to hell
yea it has a salvage title due to theft. a-holes. so this tensioner bolt...uhm yea i dunno where it is yet i'll find out when i get the car back. i'm sure it's by the flywheel that holds the tension on it. i'm just gonna make sure they arent trying to sell me on some shat like exhaust bearings or piston return springs.
Old 05-13-2003, 05:09 PM   #12
RawCode
Member#: 3115
2002 Impreza 2.5RS
The tensioner bolt
Wouldn't be near the front of the engine, near the timing belt? Maybe it holds in the tensioner for the timing belt?
RawCode
RawCode is offline   Reply With Quote
Old 05-13-2003, 09:17 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Edit: read above about waranty info.
Honestly, if it won't turn over a full rotation and keep going, something big is stopping it, and a valve is most likely not it. Pull the motor and start looking into it because it's not going to be a simple problem unless you consider replacing the short block simple.
What happened to my engine? LuntzsSTI Newbies & FAQs 3 09-25-2009 10:39 PM
Holy crap, what happened to our dollar?! steve Vancouver Impreza Club Forum -- VIC 29 02-01-2009 12:22 AM
crap what happened to 76.com? no race gas station locater!!! pio!pio! Southern California Impreza Club Forum -- SCIC 20 10-01-2006 07:36 PM
Help me guess what happened to my broken engine!! (long) Daveish Normally Aspirated Powertrain 12 04-14-2004 10:05 AM
Holy Crap! What Happened To 2000? NightmareOnSubySt Hawaii Impreza Club Forum -- HIIC 10 01-04-2001 02:39 PM
