Old 05-12-2003, 07:58 PM   #1
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default Exhaust leak or paranoid?
How obvious would an exhaust leak be? Did my up pipe and down pipe finally and everything seems fine but...
I can hear all the airflow better but there is this ever so slight whine/whistle that I can sorta hear over the intake as boost comes on under POT and then dissipates or is drowned out by 4k rpm. Under WOT it is just pretty much the nice rumble I would expect with no whine.
I have removed the snorkus and have a velocity stack routing air from the fender to the stock airbox.
I think it is just hearing the turbo and airbox better and that I am being paranoid with all the exhaust leak horror stories.
turboICE is offline   Reply With Quote
Old 05-12-2003, 11:20 PM   #2
doogdog
Member#: 29308
2005 Outback XT LTD
Champagne Gold Opal
You're paranoid, think about it... You've removed 2 cats and have most likely added a huge bellmouth downpipe. I was the same way but you will get used to it. An up-pipe leak is truly distinctive, kind of sounds like a machine gun, if it's slight it will be only under boost usually. Good luck.
DD
doogdog is offline   Reply With Quote
Old 05-13-2003, 12:12 AM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Exhaust leak or paranoid?
Originally posted by jehcpa
I can hear all the airflow better but there is this ever so slight whine/whistle that I can sorta hear over the intake as boost comes on under POT ...
You likely are hearing the turbocharger more clearly, but what is this POT business?
Jon [in CT] is offline   Reply With Quote
Old 05-13-2003, 12:17 AM   #4
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
I would definetely recommend staying off the POT and the sounds your hearing should go away
STR8OUT is offline   Reply With Quote
Old 05-13-2003, 01:05 AM   #5
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
POT = partially open throttle
I agree stay off of it - just go wide open.
Thanks hope I am being paranoid and trying to imagine something that isn't there. I have never had an exhaust leak, but never did work on a turbo exhaust before this either.
any one hear a exhaust leak or high resonance ?? gentzleon Baja Forum 7 12-06-2004 09:00 AM
Exhaust Leak or Boxer Engine Sound DILLIGAF Racing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-16-2004 10:29 AM
Exhaust leak? Or am I paranoid BurtonCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-16-2004 10:32 AM
Exhaust Leak or Blown turbo?? ScreaminFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-16-2003 03:39 PM
Exhaust leak or what? lestion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-14-2002 01:26 AM
