Old 05-12-2003, 08:59 PM   #1
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Default confirming fitting.
can anyone everyone confirm the fact that a 98 subaru impreza 2.5 engine will PHYSICALLY bolt right into a 98 subaru outback wagon 2.5. the local garage here doesnt think it will so they need confirming so if as many of you that KNOW can confirm it here so i can print this thread out thanks alot
cindergarden is offline   Reply With Quote
Old 05-12-2003, 09:10 PM   #2
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
The EJ18, EJ20, EJ22, and EJ25 engines all have the same mounting points to the chassis. The 98 Outback Wagon came with an EJ25, right? So it's the same engine as the one in the 98 Impreza, with some changes internally.
fellfrosch7 is offline   Reply With Quote
Old 05-12-2003, 11:02 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
an EJ series engine will pretty much mate up to any other model with an EJ. a EJ18, EJ22, EJ25 should fit in the 98 outback no problem. engine mounting points and where it bolts to the trans are identicle. If you are going 2.5 from impreza to a legacy that originally had a 2.5 then its a no brainer. there may be slight differences between the engines and ECUs. but as far as fitting in, youde enver be able to tell the difference.
Hawk296 is offline   Reply With Quote
Old 05-13-2003, 11:36 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thats kinda scary .... that they think it won't fit ...
Old 05-13-2003, 04:18 PM   #5
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Outback Sport?
Are you taking about an MY98 outback Sport? If so I plan on doing an MY97 2.5 into a MY97 2.2 impreza L which is the same as the MY98 engine. They are 100% interchangeable and the 2.5 ecu will plug right in to the 2.2 harrness.
Joshua
yebokmj is offline   Reply With Quote
Old 05-13-2003, 05:54 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
From what, '97 and newer, all Outback's had the EJ25? The Impreza started out with an EJ18, then EJ22, then EJ25, (and also EJ20) all with the same chassis. Legacies have had both the EJ22 and the EJ25 in them. The '98 EJ25 from an RS should actually be no different from the EJ25 in the '97 Legacy (both DOHC). The MY99 EJ is where they went to SOHC.
If this garage is the same place that would be doing the swap, I think you need to find a different garage.
-Jon
Borla Header Question - how to confirm fit if seller does not know info kero Normally Aspirated Powertrain 11 06-30-2008 11:43 PM
Can anyone confirm fit of Cusco front strut brace with TurboXS TMIC? Detroit wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-30-2006 12:21 PM
Confirmed fit 6.5" woofer, 2.75" deep in a 2000 2.5RS w/no door mod (CDT EF-61CFi) AcquaCow Car Audio, Video & Security 24 06-01-2005 09:44 AM
Can anyone confirm WRX struts fit '02 TS Wagon? MrJaemz Brakes, Steering & Suspension 1 05-02-2002 10:45 PM
ATT Girl, Please confirm that the HA's fit the wagon with out modifications. WRBLUEWAGON Brakes, Steering & Suspension 18 03-21-2002 05:21 PM
