Old 05-12-2003, 10:26 PM   #1
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Default VF-22,good idea?Bad idea?
I currently have a TD-04L unique pipes a rallispec intercooler,Vortech,map clamp,and J&S.I recently acquired a VF-22 for a good price,I plan on upping the management soon to either Wolf or link,my question is if I continue to run 5psi on this setup will it still be safe for now? I have not had any detonation to date and am running a bit rich (WRX pump and RRFPR) I think the 22 will be a bit more efficient on the car,Just wanted other input.
Thanks,
Ben,
Old 05-13-2003, 08:19 AM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
How do the compressor maps and flow rates compare? Or is that what you are asking?
Brad
MY99 2.5GT is offline   Reply With Quote
Old 05-14-2003, 01:18 AM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
We got 202WHP out of a VF22 at 5.8 psi (approx 270 flywheel), so it seems to do pretty darn well at low boost. When i switched from a RHB52 (VF11) to the VF22, it felt like 5 psi on the VF22 was just like 7-8 psi on the smaller VF11. It was great.
I run the VF22 as high as 14 psi which seems to be about 270whp on race gas based on qtr mile speeds and keeping up with a Z-06 at 6000 feet and with the Z-06 at 300whp up here they have the same wt to hp ratio as my car. The VF22 has been known to make as much as 275whp on pump gas at sea-level, and one person reports 300whp on race gas out of one.
Anyway, the VF22 is not at it's best efficiency at only 5-6 psi, and it really starts to sing at 10-14 psi and above (320-360hp at the fly max)
ImprezaRS dot com is offline   Reply With Quote
Old 05-14-2003, 01:17 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
ben, I should have your vf22 on saturday and I might be able to make it up the weekend after that. but suggest you look into a link plus, haltec or some type of ecu to tune the sucker.
DoctorNick is offline   Reply With Quote
Old 05-14-2003, 10:43 PM   #5
Hondaslayer
Member#: 4562
1995 Legacy LSi
Something will be bought,I just could'nt pass up such a good deal.
Old 05-15-2003, 03:27 AM   #6
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
i was thinking about getting a turbo upgrade eventually, righ tnow i got a ej20 in my classic impreza. if i had the vf-22 what kind of upgrades would i have to get? upgraded fuel system, what kind of IC?? would the STi be enough? or should i go larger?? how much power can be had with the 22?? (to the wheels) is there much lag? is it a good turbo for daily driving and road cursing?
scoobyimpreza is offline   Reply With Quote
Old 05-15-2003, 10:52 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
So where can a link plus with P&P harness be purchased?
Old 05-15-2003, 11:27 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
www.carmodifications.com. Andrew runs the place. He is a good guy.
As far as the VF-22, I say go for it. The only thing I would be weary of is not knowing the wastegate spring pressure on a turbo made for the high boosting WRX. I would imagine that its internal wastegate opens somewhere in the neighborhood of 8 psi. This may be more than you want and I have NEVER found (or anyone else that I know for that matter) where to get new internal wastegate springs.
Just to let you know, with engine management and a good tune you are safe up to around 10-12 psi on the WRX turb on the RS. I am running the RHB5 on my with a Link at 10 psi and I make 240 HP at the crank and 302 crank HP (wheel= 170 and 226). So, don't be afraid to take the TD04 a bit further.
Graham
Graham is offline   Reply With Quote
Old 05-16-2003, 04:18 PM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
I will have for sale, and ready to ship in about 3-4 weeks, parts off my own car
(1) personal VF-22 (24K miles, well treated with cool downs)
(2) jet hot coated up-pipe (with EGT bung and O2 sensor bung just before the turbo)
(3) stainless steel downpipe in 3" twindump style with no cats (has a removable track section to insert a cat later), with O2 sensor bung just behind the turbo and another at the end of the track pipe.
(4) air intake inlet with vacuum nipple and BOV return for 2000-2004, but without cone filter.
PM or email me to make offer?
Larry
Old 05-16-2003, 11:33 PM   #10
Hondaslayer
Member#: 4562
1995 Legacy LSi
Graham,
I bit the bullet and bought a link.
Any chance anyone has a base map for me to use?
Ben,
Old 05-16-2003, 11:59 PM   #11
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Originally posted by hondaslayer
Graham,
Ben,
I think we should do a dyno day at godspeed I wanna get a dyno reading and mabye we can make a weekend of it and you can install the link and get it tuned. Just an idea. btw, I should get it this weekend. i'll update you via pm when it all goes down.
-Neal
Old 05-17-2003, 12:03 AM   #12
Hondaslayer
Member#: 4562
1995 Legacy LSi
Kewl,Sounds good,
I wont be able to install it and the Link for another month though. Waiting for my laptop,(Dads old work computer)
Ben,
Old 05-17-2003, 12:33 AM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
yeah, I bought brians old gheto laptop. It will be enough for those "emergency" tunes. Besides, I get out of school in 2-3 weeks. So mabye we can do something for when I get out and when you get your laptop.
Old 05-17-2003, 01:06 AM   #14
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Ben, your running a WRX turbo right?
If so, your in luck. Wait, what size injectors are you running? I have a professionally tuned map for 10 psi with a TD04 or the very similar in size RHB5 (I'm running the RHB5). It cost me quite a bit of money, but it is an awesome map for the Link. Although, if your not running 440's you may run into some problems. A fuel pressure of around 50 psi would help to.
Anyway, I can send it to you, just need an email address.
Graham
Old 05-17-2003, 01:41 AM   #16
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Oh, forgot you were putting in the VF-22. My map will not be what you are looking for then.
I'll send it anyway.
Graham
Old 05-17-2003, 01:42 AM   #17
Hondaslayer
Member#: 4562
1995 Legacy LSi
Cool,
Thanks
I just wanted to see what a RS-t map might look like.
Ben,
Old 05-18-2003, 12:46 AM   #18
Hondaslayer
Member#: 4562
1995 Legacy LSi
any other places sell Link? Carmodifications only takes paypal..
A game of good idea, bad idea in the Phillippines wolf8314 Off-Topic 1 03-10-2005 06:41 AM
Good Idea, Bad Idea pittspilot Political Playground 28 12-11-2004 05:07 PM
Utec Ems Good Idea? Bad Idea? YOPIVO02 Engine Management & Tuning 5 08-12-2004 08:42 PM
Good Idea, Bad Idea MattDell Off-Topic 18 05-04-2004 09:45 PM
