Old 05-13-2003, 11:36 AM   #1
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default question for built motor/stroker motor people
Obviously, all of us have some form of engine management or another. My question is, how noisy are your motors? Running the UTEC, I've been desensitizing the knock control system severely in order to get it to not pick up stuff like piston rock, slap, etc.
I got a someone stable 93 map, but would get knock picked up on transient acceleration, tip in, and (get this) 1st gear and partial second gear romps... But.... 3rd gear (go figure) runs quiet to even the knock link..
So...... I figure, I have a decent 93... if it IS knock, then a healthy tank of 100 octane would fix it.
It didn't... it still "knocks" in all the same places, at all the same rev ranges, so I can only assume (and have been dialing it back accordingly) that it's all engine and valve train noise.
I just wanted to know if this is similar to what others have experianced. The knock link also starts to glow all the way up to the yellows. as well (full sensativity)
Before I start turning THAT down, I'd like to hear what the general concensus is.
Thanks,
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-14-2003, 03:27 AM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
forged pistons make noise...
MJU1983 is offline   Reply With Quote
Old 05-14-2003, 03:31 AM   #3
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Default get some det cans!
You need to get/buy some det cans my friend. I made mine with a pair of ear defenders, some fuel hose, and some copper water pipe flattened at one end then drilled/slotted.
You need to be able to hear the engine for yourself to determine what the knock is, you will be surprised at what you can hear. You can pick out the injectors firing, noisey followers, pistons and detonation. You will also hear the start of detonation before the knock sensor, and may pick up some det that you don't hear in the cabin, and the UTEC doesn't pick up at all.
Paul
Pavlo is offline   Reply With Quote
Old 05-14-2003, 04:43 AM   #4
mlambert
Member#: 13831
That is top notch advice pavlo!
mlambert is offline   Reply With Quote
Old 05-14-2003, 09:57 AM   #5
hotsam
Member#: 3862
Water Injection
hotsam is offline   Reply With Quote
Old 05-14-2003, 10:34 AM   #6
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Isn't the factory knock sensor tuned to ignore false knock or be less sensitive at certain frequencies? By building it, and changing the resonances and rpms where the motor makes noise, your factory knock sensor is no longer effective.
Kevin
Red Rocket is offline   Reply With Quote
Old 05-14-2003, 11:48 AM   #7
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Default Re: get some det cans!
Paul
Yeah, I was borrowing TXS's for a while, but had to give it back. But we're working that one out, so I'll have the headphones on again, soon!
For now, I've been doing a test with 100 octane to see what's what... I had the 93 map "close", the 100 map did the same thing, so I've been logging my rear off with the deltadash (watching knock sensor activity), and have been slowly dialing back the knock system to compensate for the noise. I finally got it, and realize that I can now run a LOT more timing then I was a day before.
Also swapping out plugs helped a LOT. The coppers didn't even last 3k miles before freaking out.
IK22's are a huge difference.
More soon.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 05-14-2003, 01:35 PM   #8
savka
Member#: 12737
MY02 wagon 325/300
black, no blue, no black.
Paul
can you explain how to make one, please.
thanks
sav
savka is offline   Reply With Quote
Old 05-15-2003, 05:21 AM   #9
Pavlo
Member#: 23015
95-> GC8
I will post some pics.
Paul
What would be the best option for a sti stroker motor, sleeved stock block or stroke? silver07sti Built Motor Discussion 29 02-06-2008 09:30 PM
em question for built na block atech_rallyrs Normally Aspirated Powertrain 7 01-22-2007 09:19 AM
Question for all you Plano/frisco people Manoxide069 Texas Impreza Club Forum -- TXIC 14 04-14-2006 11:21 AM
question for plano and nearby city people yamez Texas Impreza Club Forum -- TXIC 13 09-13-2004 10:10 PM
Question for the Radio Controlled Car People Corn-Picker Off-Topic 10 07-01-2004 10:39 PM
Message Board Statistics All times are GMT -4. The time now is 11:04 AM.
