Old 05-16-2003, 08:33 PM   #1
wrigh003
Member#: 13997
Question TiVo question
So, to have TiVo, do I HAVE to have a phone line? Or can it use my cable modem to get programming updates and whatnot?
wrigh003 is offline   Reply With Quote
Old 05-16-2003, 08:37 PM   #2
philip_g
Member#: 32906
you can use the network, sure.
www.dealdatabase.com click on forum..
philip_g is offline   Reply With Quote
Old 05-16-2003, 09:25 PM   #3
Xander1281
Member#: 5916
2002 WRX Sedan
I just ordered a TurboNet card from www.9thtee.com
It gets here on Tuesday, so I can't comment on it just yet.
Do you have a Series 1 or Series 2 TiVo? If you have a series 1, the TurboNet seems to be the best way to go for broadband updates. From what I have heard the series 2 TiVo's have a USB port that you can use to plug in a USB network card.
Once you have a connection to your TiVo on your network you can install TivoWeb and control settings, recordings, and season passes remotely from the built in web browser.
-Alex
Xander1281 is offline   Reply With Quote
Old 05-16-2003, 09:54 PM   #4
charles s
Member#: 35935
2006 OBS 99 Forester
Steel Grey & Silver
ReplayTV > TiVo
charles s is offline   Reply With Quote
Old 05-16-2003, 09:55 PM   #5
wrigh003
Member#: 13997
Still getting some mixed signals, though. It seems to suggest in some places that it requires an initial setup with a phone line, which we do not have, nor do we intend to get. (One phone bill a month is quite enough, thanks.)
Does anyone know an 800 number for TiVo customer service, or has anyone actually set their Tivo up initially like this (without ever attaching to a phone line?)?
Old 05-16-2003, 10:00 PM   #6
IgotWRXed
Member#: 14868
2002 wrx
i have direcTivo with two lines instead of one. awesome awesome awesome awesome. if you are reading this, and do not own Tivo, get it now!!!
IgotWRXed is offline   Reply With Quote
Old 05-16-2003, 10:34 PM   #7
philip_g
Member#: 32906
the directivo uses the directv channel guide for it's data. Different animal. the standalone tivo has to download it.
Old 05-16-2003, 10:47 PM   #8
Xander1281
Member#: 5916
2002 WRX Sedan
TiVo will get its listings by dialing out using your existing phone line. It will dial out late at night or early in the morning. You do not need a second phone line just for TiVo. Or, you can get a series 2 TiVo and a USB network adapter. You will then be able to connect your TiVo to you existing home network (if you have one) and it will get its listings from the internet.
In either case you will still need to pay the monthly fee or the one-time subscription for the service. Go to www.tivo.com All the basic information is there.
-Alex
Old 05-16-2003, 10:55 PM   #9
BlackBeastie
Member#: 11846
I maybe need
a break
Originally posted by charles s
ReplayTV > TiVo
why the sour grapes, pal? love the one you're with.
TiVO 2 you just hook up a USB->ethernet adapter or a wireless USB (I have the Linksys one, works seamlessly).
The series 1 you need to add a turbonet card (http://www.9thtee.com/turbonet.htm). I haven't done it, but it seems like a reatively simple installation process.
If you have to go via phone line, make sure you phone have a line protector.
BlackBeastie is offline   Reply With Quote
Old 05-16-2003, 10:59 PM   #10
Johnny Knoxville
Member#: 18508
i have PVR with Dish network. it rules
Johnny Knoxville is offline   Reply With Quote
Old 05-16-2003, 11:02 PM   #11
wrigh003
Member#: 13997
-Alex
Maybe I haven't been clear. I don't have an existing phone land line at all, we use our cells for everything. Can Tivo use the internet only to update its schedules, or will I need to get a line installed just to get the programming schedules?
Now, anybody know the answer to that?
PS- thanks, OT. You guys rule.
DUH- I didn't read that closely enough. Maybe I'm a little drunk.
Old 05-16-2003, 11:27 PM   #12
m750
Member#: 2278
8Sti | 07 allez
White | Comp
series I or II?
Series II doesn't require a phone line. IF you set the dial # to something, I don't recall the exact setting, and the tivo forum is down, but there is a string you can put in. I'll get all the info from the net. If it's a series one, you've got to get a turbo net.
Post your version, and I'll post the next step.
AO
m750 is offline   Reply With Quote
Old 05-17-2003, 12:02 AM   #13
BlackBeastie
Member#: 11846
I maybe need
a break
Just reading up on it. It seems that with the series 1 you need to do the initial setup via phone line. As long as you are in the same cable zone, it doesn't matter where the phone line is. It just needs to get the listings for your area. After that you can enter in the special code and use the ethernet.
Old 05-17-2003, 06:31 PM   #14
Xander1281
Member#: 5916
2002 WRX Sedan
Ahh. You use a cell phone for all calls, gotcha.
Yes, you can get a Tivo and set it up with out ever needing a phone line. You can get a series 1 and add the TurboNet card or you can get a Series 2 and a USB ethernet adapter. Both will work over the internet from the start.
As M750 said there is a setting that you enter in your dialing prefix that tells the TiVo to use the network cards for communication.
There are other instructions on getting those internet updates working on your network, It would be a good idea to read the instructions and tips that apply to the route that you are going to take. Like some have said, the TiVo Community forum is down but here is a link to the smaller temporary version http://www.avsforum.com/avs-vb/forum...php?forumid=58
-Alex
Old 05-17-2003, 08:51 PM   #15
Erudition
Member#: 7560
If you buy a new one (Series 2) then it will most likely come with software version 3.xx. If it does, you need to use dial-up untill it updates itself with software version 4.xx, then the networking option will work.
With the networking option, just plug (as others have said) in a usb ethernet adapter in to your home network, and it will download the guide data and software updates from net.
I have a 95 hour version. Check out this site:
Here
Erudition is offline   Reply With Quote
Old 05-19-2003, 08:59 PM   #16
wrigh003
Member#: 13997
Went and bought the thing today, and am now trying to get it to work. It doesn't want to recognize the frakking modem, despite the fact that it's going straight into the back of the box.
Looks like I might have to go to somebody's house and plug the damn thing in for a minute or twenty, just so's I can get the stupid thing working.
At any rate, thanks for all your help, OT. You guys rule.
It's a series 2, so hopefully after it gets working it'll stay that way. Back to engineeering the living room around these stupid cables...
Old 05-19-2003, 11:50 PM   #17
Erudition
Member#: 7560
I think you need a router. Linksys should work fine.
Tivo question urgewrx Off-Topic 12 08-22-2008 04:48 PM
Stewpit Tivo/Cable question Strider Off-Topic 7 03-05-2008 10:49 AM
Tivo Series 3 HD Tivo subarugt Off-Topic 30 10-01-2006 06:46 AM
Tivo question. earshot Off-Topic 2 08-13-2006 10:40 PM
HT people: DVR/Tivo Questions... jacobsen1_ Off-Topic 10 03-16-2006 02:21 PM
