Old 05-14-2003, 01:10 AM   #1
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Question Any performance gain from an improved radiator?
I saw a C&R radiator posted at kastle's and want to know what benefits it would give a NA RS?
joubtt is offline   Reply With Quote
Old 05-14-2003, 02:23 AM   #2
Basshead
Member#: 112
2011 Jetta TDI
not really necessary unless your boosted and running much hotter engine temps that require the more effecient and faster cooling properties of that radiator....
Basshead is offline   Reply With Quote
Old 05-14-2003, 08:11 AM   #3
kickin_81
Member#: 16679
2004 Forester XT
If you notice your radiator fan is always kickin in, then that's a suspicion that you're going to need a better cooling radiator. You should always check the thermostat first before considering the radiator... unless it's leaking.
kickin_81 is offline   Reply With Quote
Old 05-14-2003, 02:53 PM   #4
joubtt
Member#: 33901
04 04 STI
Thanks for the info. My baby is fine but I'm trying to compound my knowledge.
Peace
Old 05-15-2003, 01:23 PM   #5
Mike&Michele
Member#: 2252
2000 2.0 Swapped RS
Sedona Red Pearl
I have a '00 RS and just put the C&R radiater in the car this January. Reason for the change was one of the seams in a plastic coolant tank cracked and I was loosing coolant. I picked up the C&R because I am planning for an engine swap and a larger radiater won't hurt (wife also let me), also it is repairable if there are additional problems. The differences are that the C&R is larger, the fans are more effective, and louder and it looks great. Since you also have an RS a couple things to remember are that you have to bend the lower AC line on the driver side, and if C&R didn't do it already, trim some extra aluminum off the side of the bracket holding the overflow tank. As for benefits, the car runs cooler.
Mike&Michele is offline   Reply With Quote
Old 05-16-2003, 08:16 AM   #6
kickin_81
Member#: 16679
2004 Forester XT
Is there any looseness of the piping and radiator after fitting it? Overflow tank? So how does it look like installed? You'll probably guess my next question... How about some pictures with it installed?
Old 05-16-2003, 01:11 PM   #7
Mike&Michele
Member#: 2252
2000 2.0 Swapped RS
Sedona Red Pearl
After the mentioned modifications the fit is fine no problems at all. I did fail to mention two points: The harness for the fan is different from stock but that is minor. Also, the line running to the overflow tank is a different size. It looks great installed, I just wish the front was not obstructed by the AC...can't see the C&R logo on the front. As for pictures, I have to get some but it will have to wait, leaving for vacation in a couple hours. Planning to swing by Teague's Auto for headers and cat.
Meth on an RS? ANY performance gains? shanemono4 Water/Methanol Injection, Nitrous & Intercooler Cooling 2 07-06-2008 10:23 AM
Anybody have any power gains from an Invidia G200? Moshpit552 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-14-2005 02:23 AM
Performance Gains from a BOV Blackscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-24-2002 08:59 PM
Performance gains from sti hood scoop? IndyRacer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-12-2002 10:46 PM
Performance gains from a true duel exhaust? g6 Normally Aspirated Powertrain 17 06-26-2001 11:02 AM
