Old 05-14-2003, 03:39 AM   #1
wlelandj
Member#: 15127
Default WRX Manual-to-Automatic?
I hope this is in the right place. It was a toss-up between here and the trans forum. Anyway, I was wondering what would be needed to do this. I figure the transmission (obviously), auto trans mount, Computer for auto equipped WRX's..what else? I was considering having one "built" plus I've never endeared myself to the manuals performance/operation.
-Leland
wlelandj is offline   Reply With Quote
Old 05-14-2003, 07:16 AM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
* short propshaft
* new rear differential (4.111 if you go to WRX 4EAT)
* new transmission crossmember
* starter
* wiring (new speed sensor path through TCU, neutral sense, etc.)
* inhibitor switch (shifter) assembly and cable
* new brake pedal assembly
* possibly a new ECU (jury is still out on this one)
* engine drive plate (flexplate)
* torque converter
I'm currently going in the opposite direction.
/Andrew
Kha0S is offline   Reply With Quote
Old 05-14-2003, 09:47 AM   #3
wlelandj
Member#: 15127
Thanks for the info. Man, I had no idea! Maybe I'll rethink that Gimmie Gears gear set
-Leland
Old 05-14-2003, 10:06 AM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Heh, certainly, going from AT to MT is easier than the other direction, and even that is shaping up to be a really big project. So far, I have the old drivetrain ripped out, and I have the local driveline shop working on the rear differential.
Tomorrow is a trip to the junkyard to find lots of little odds and ends to keep the project rolling. Two decent days of work just to remove the old driveline components... it's amazing how many of those bolts seize up over time.
If you don't do the labor yourself, expect at least 20 hours of pro labor, up to 40. The only reasonable route is to go through a shop with a "large job" flat rate. Parts are going to be deep into the thousands for new parts. still $2k or so even if you buy used/junkyard.
/Andrew
Old 05-17-2003, 12:52 AM   #5
alvyman
Member#: 35581
02 WRB WRX
96 protege DX!
Post
Hey guys. That sounds really good but one of my friends who went through that swap (AT to MT) said it caused so many problems. Also when he was trying to sell his car, he had to sell it for not even half of kbb price since the transmission didn't match the vin # info. This is what I heard so I think you might have to do some research on resell value or what it might cause.
alvyman is offline   Reply With Quote
Old 05-17-2003, 07:09 PM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
If you're interested in an MY00 RS AT, then I'm selling everything you need for pretty cheap. The only thing you'll need to find is the rear diff. Email me if you decide to do that.
garface is offline   Reply With Quote
Old 05-18-2003, 11:18 AM   #7
Kha0S
Member#: 8808
2011 WRX
DGM 5D
I'm not planning on reselling my WRX.
/Andrew
Manual Climate control to automatic? mysticmicman Electrical & Lighting 15 07-20-2014 05:14 PM
02 wrx manual to automatic.... turbo_wagon Subaru Conversions 2 07-22-2008 11:26 PM
Need Help.. Not allowed to drive Manual, Hate Automatic!! fb1907 Transmission (AT/MT) & Driveline 16 02-27-2007 06:47 PM
converting manual to automatic? quest Transmission (AT/MT) & Driveline 2 09-28-2003 06:10 PM
"Manual" automatics abound, BUT "automatic" manuals? uncleho General Forum Archive 5 09-15-2000 12:44 AM
