Old 03-02-2004, 04:47 PM   #226
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I think the Rev D is different by one digit in the PNs. It also has the holes in the spring perches that the Rev C and earlier do not.
ss
subysouth is offline   Reply With Quote
Old 03-02-2004, 05:04 PM   #227
BriDrive
Member#: 21801
2013 Jacked Up T4R
roger that....I was referring to the rev d. I didn't think there was any difference in pn's between the US sti and the JDM rev d that, say the type-c spring set would be mounted on.
Any clarification on this subysouth ? Or...are all rev-d's the same PN regardless of whether its JDM or USDM?
BriDrive
BriDrive is offline   Reply With Quote
Old 03-02-2004, 05:17 PM   #228
StevieD
Member#: 14029
BriDrive
Fitment of the springs is more of a V7 vs V8 issue. If the Spec C springs are V8's they will work on GDB C or GDB D (USDM)
StevieD is offline   Reply With Quote
Old 03-02-2004, 07:23 PM   #229
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
BriDrive
Its a good question and I dont know. I hope theyre the same cause it would sure simplify things. But they could be the same struts but different PNs for the 2 markets or they could be different struts because the USDM version has a different engine. Most of my info unfortunately is for the JDM takeoffs.
ss
Old 03-05-2004, 11:24 PM   #230
StevieD
Member#: 14029
Originally posted by subysouth
And because TTINWP, here we go:
I am 99% positive this is a pic of the Rev A "regular" STi sedan spring/strut set. I believe the Rev. B setup is identical to this except for strut PNs.
ss
The GDB A and B's have those colors, the GDB C's have purple dots up front, the GDB D's have purple and red I think
and as for the S202's. They are the same as the spec C's. I've had three sets of these and are due in more soon.
Old 03-08-2004, 11:32 AM   #231
calworld
Member#: 5711
2004 STI
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2465462754
So is this the real s202 suspension???
calworld is offline   Reply With Quote
Old 03-08-2004, 01:06 PM   #232
StevieD
Member#: 14029
Yup.. the real deal.
Old 04-09-2004, 09:47 PM   #233
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
This is an incredibly detailed post- I vote sticky
MK19_ is offline   Reply With Quote
Old 04-13-2004, 05:09 PM   #234
nekard
Member#: 12927
2002 Impreza WRX
Did you guys ever figure out the spring rates?
nekard is offline   Reply With Quote
Old 04-14-2004, 06:06 AM   #235
Maicca
Member#: 29143
2000 IMPreza
Camo
Originally posted by StevieD
The V8's are complete, struts, springs and tophats.
Are those going to just drop into either a 2003 or 2002 WRX, with no other adjustments?
Maicca is offline   Reply With Quote
Old 04-14-2004, 07:06 AM   #236
StevieD
Member#: 14029
Yes, there's several sets on EBAY if you do a search under:
STI Suspension
Old 04-14-2004, 08:38 AM   #237
Maicca
Member#: 29143
2000 IMPreza
Camo
Does the same go for the v8 Spec C suspension?
Thanks!
Old 04-14-2004, 09:51 AM   #238
nekard
Member#: 12927
2002 Impreza WRX
Spring rates? Did we ever figure out the 2003-2004 complete strut codes?
Old 04-14-2004, 10:18 AM   #239
StevieD
Member#: 14029
Thanks!
Does what go the same?
If you mean do the Spec C's fit the WRX directly then the answer is yes... I get those from time to time.
Old 04-14-2004, 10:19 AM   #240
StevieD
Member#: 14029
The 2003 GDB-C and GDB-D have different PN#'s I believe. I have a few sets at home I'll post them later on.
Old 04-14-2004, 11:16 AM   #241
Maicca
Member#: 29143
2000 IMPreza
Camo
Exactly- you hit the nail on the head
I had thought that the v7 and v8 sets were completely plug and play with both the 2003 and 2002 USDM Imprezas; just wanted to appease the paranoid/anal retentive portion of my brain
I can't wait to receive mine
Thanks for your help!!!
Old 04-16-2004, 11:28 PM   #242
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Default Some more data points...
Tested some Spec-C springs today vs USDM STI springs. They were identical in every way: coils, dot colors (2x purple front, 2x green rear), wire diameter and spring rate.
Here's a pic of the fronts side by side:
Here is a pic of the rears:
Spring rates were tested by a local Porsche race prep shop. They tested both fronts and rears, with the following results. Note that the accuracy of the machine is plus/minus 10lbs, which means that the actual numbers may have that much error. However, the readings were identical between the USDM and Spec-C springs.
Front: 200lbs linear
Rear: 130-200lbs two stage progressive
Jon Bogert is offline   Reply With Quote
Old 04-17-2004, 12:25 AM   #243
nekard
Member#: 12927
2002 Impreza WRX
So are the struts different part numbers?
Old 04-17-2004, 01:00 AM   #244
BIGSKYWRX
Member#: 7958
09 GH B+
Could they have about 12 lbs of error in front . Everything points to the v8 spec C as running 188/173 (progresive rear) and it appears the USDM v8 uses the same- makes sense- there also 10mm lower as well.
This is a departure from the v7 RA which ran 217/192 (no lowering), less caster and many other susp differences.
Big Sky
Old 04-17-2004, 07:26 AM   #245
StevieD
Member#: 14029
Default Re: Some more data points...
Where did you get the "Spec C" springs you are using to test against the USDM springs? The JDM Spec C springs are blue/green up front to the best on my knowledge, while the regular JDM STI springs are purple for GDB-C and Purple with a red dot for GDB - D
I have a set of GDB-C and GDB-D in my garage. I'll take some pics and list the strut PN's later on.
Old 04-17-2004, 07:27 AM   #246
StevieD
Member#: 14029
Default Re: Re: Some more data points...
That might be because the JDM Springs with the purple Dots are not Spec C's. The Spec C's have Green / Blue dots.
The JDM springs with the purple dots are regular STI ones.... No?
I have a set of v8 Spec C's due in soon from Japan (Green / Blue dots up front). You can test those if you wish.... or I can see if there is a shop in the Dallas area that can test them. It sure would be interesting to see if Subaru has departed from their paint code identification of the past.
Old 04-17-2004, 09:17 AM   #247
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Where did you get the "Spec C" springs you are using to test against the USDM springs? The JDM Spec C springs are blue/green up front to the best on my knowledge, while the regular JDM STI springs are purple for GDB(c)-C and Purple with a red dot for GDB(c) - D
I have a set of GDB(c)-C and GDB(c)-D in my garage. I'll take some pics and list the strut PN's later on.
Hey Stevie, too many letters.
It would be GDB(C) and GDB(D).
Please do post the strut PNs and pics.
ss
Old 04-17-2004, 10:52 AM   #248
BIGSKYWRX
Member#: 7958
09 GH B+
Personally I'd like to see this mystery solved once and for all. If the v8 spec C has different paint dabs than the JDM v8 STi, there is better than a fair chance they are different.
However, everything I've been able to dig up shows the v8 spec C w/ 188/173 springs
here:
http://www.subarumembers.com/showroo...ra/spec_03.htm
http://www.ayutaya.com/home/knaka/bb...00600_00_6.JPG
In this pic you'll see the RA rates listed 38.0 front (217) and 33.4 (192), the right column is translated as 13% decrease in the front for v8 spec C equates to 33.06 or 188 ft lbs- same as the other site shows. Go to the rear springs show the v7 RA w/ 33.4 (192) decrease by 9% you get 30.394 which equals 173 ft lbs- exactly what the other article shows as well.
Interesting stuff.
Big Sky
Old 04-17-2004, 11:06 AM   #249
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
I got the springs from Myles. Chaste has also apparently been selling the identical springs as in this thread: http://forums.nasioc.com/forums/show...hreadid=526678
Both Myles and Chaste say that their source is impeccable and that the springs are defintely off of Spec-C cars. So, assuming there isn't massive willful fraud going on it seems likely that all Spec-C's are not the same.
I think this debate should no be, "Is it Spec-C or isn't it?" but instead, vendors need to start specifying paint codes, no matter what the sticker on the trunk lid of the donor car says.
StevieD, please do test the springs when you receive them. Please test them side by side with USDM springs, since ALL the spring rate numbers are suspect. I, for one, just want a near-stock ride height with 10-15% stiffer springs, no matter what they came off of.
Old 04-17-2004, 11:50 AM   #250
StevieD
Member#: 14029
Jon - I know about that thread.... Anyways, here's the images I promised:
If you see red x's please click
HERE
GDB-D STI (JDM)
Any 06 STI with a perrin 30r, please read Dana Daray Southern California Impreza Club Forum -- SCIC 4 04-09-2010 07:42 PM
$425 JDM GC8 WRX sti suspension takeoffs COMPLETE 4 corners supermoose Private 'For Sale' Classifieds 12 06-29-2006 02:57 PM
please post pics of wrx with sti suspension 04wrx555 Member's Car Gallery 10 03-30-2005 03:35 PM
JDM V8 STi suspension takeoffs (long) Jeff_DML Car Part Reviews 19 08-20-2004 03:09 PM
Everyone with a modded car, please read. jimb Tri-State Area Forum 17 10-24-2003 06:25 PM
