Old 09-08-2007, 12:56 PM   #301
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by andyng View Post
i'm in malaysia, and they are still trying to clear off 03 stock...sad...
...sad they cost at least double there as here
Old 09-17-2007, 10:58 PM   #302
andyng
Member#: 87884
JDM MY06 Spec C struts...
all 4...
front...
rear...
andyng is offline   Reply With Quote
Old 10-20-2007, 04:34 PM   #303
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I have 2003 WRX Wagon rear struts, but both rear springs have different codes, anyone seen this?
Both have Orange on the top coil, and one yellow dab on the bottom, but one has a yellow dab and the other has a red dab.
Anyone seen this before? They look similar, but the one with the red dab looks thinner.. LOL
aross is offline   Reply With Quote
Old 10-20-2007, 05:24 PM   #304
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Hmm... never noticed that before but yup I just pulled my 02 wagon springs out of the basement and they are different too... and they ARE different coil thickness
ORANGE over YELLOW/ORANGE... 12.5mm
ORANGE over YELLOW/RED... 13.0mm
and the YELLOW/RED feels stiffer...
unless... I used to have a set of JDM wagon springs and maybe they got mixed up... but I don't think so...
UkNuck is offline   Reply With Quote
Old 10-21-2007, 06:52 PM   #305
aross
Member#: 831
11 Blurple WRX
03 BH MBP
The question is then, as the front paint dabs are identical, which one is a left and which one is a right.
I am assuming they are different due to driver being on the left, would you assume the stiffer is on the drivers side?
LOL
Old 10-21-2007, 10:37 PM   #306
BIGSKYWRX
Member#: 7958
09 GH B+
now I'm going to have to go and look at mine
I'd be really suprised if different coil diameter was the norm-my guess is mix up, but I've been suprised before
Old 12-31-2007, 03:40 AM   #307
Ti_22
Member#: 98314
2002 WRX Wagon
Originally Posted by subysouth View Post
GGB(a) STi wagon
Right Front strut - 20310FE020
Left Front strut - 20310FE030
Right Rear strut - 20360FE020
Left Rear strut - 20360FE030
Front spring - 20330FE130 [pink above, orange and blue below]
Rear spring - 20380FE680 [yellow above, orange and red below][non-tapered, gray insulators at the top]
taken from:
http://forums.nasioc.com/forums/show...light=takeoffs
Ti_22 is offline   Reply With Quote
Old 01-02-2008, 10:58 PM   #308
skydes
Member#: 141347
2005 WRX
Can anyone help me out with the springs I have? I bought them from a member a while back. He said they are STi springs but the paint codes don't match from what I see in this thread.
The longer springs with the taper (I'm guessing front) have a green and purple dot.
The shorter springs with no taper have 2 purple dots.
What springs are these?
skydes is offline   Reply With Quote
Old 01-03-2008, 09:30 AM   #309
BIGSKYWRX
Member#: 7958
09 GH B+
you'll notice our documentation of the newer springs leaves a little to be desired , my guess is one of the newer 05+ springs
btw the longer tapered springs are the rears
would be useful if we got the 05+ guys to provide strut #'s/paint codes
Old 01-03-2008, 04:25 PM   #310
skydes
Member#: 141347
2005 WRX
woops, yeah I got those mixed up.
You might be right, I think they are 05 struts then.
Old 02-13-2008, 01:54 AM   #311
Handsdown
Member#: 29355
Anyone know what Pink over Green, Yellow is for fronts?
the rears are green green.
i heard they were from a spec c strut combo but i don't know what year, and they were on a TR so i'm guessing they were either from an STI that he got the struts for, or the TR ones and he just got them mixed up(it happens)
Handsdown is offline   Reply With Quote
Old 03-02-2008, 02:44 AM   #312
ten80
Member#: 53625
00 16' FXT
I have a set of "mystery springs," off of red V8 struts, likely JDM take-offs:
Front: purple and white, no grey spring insullator (taller spring than USDM STI purple/purple front spring by ~1", but shorter than 04-07 wrx fronts.)
Rear: green and green (same as USDM STI)
I've searched high and low and have no idea what the heck the front purple and white springs are from. I'd be grateful for any insight!
ten80 is offline   Reply With Quote
Old 03-02-2008, 11:15 AM   #313
BIGSKYWRX
Member#: 7958
09 GH B+
speculating here but the USDM STi's basically got the spec C suspension-dampers/springs/control arms- the "regular" v8 jdm STi did not- it's very possible you have "regular" v8 jdm STi springs/dampers
Old 03-02-2008, 03:05 PM   #314
ten80
Member#: 53625
00 16' FXT
Hmm, you might be onto something. It is curious that the rear spring with two green dots has three coils on the bottom which stack under full load, whereas USDM STI rear springs (purple/purple) only have two. Both springs are approximately the same length, but I wonder if the purple/purple compresses less under load. I also have a pair of rear STI springs with green/purple dots which look identical to the green/green springs. what a confusing mess!
Here are some rear STI springs:
From left to right:
USDM 07 STI / JDM V8 STI? / ? / ? / V7 STI Sedan/V7 STI wagon
The funny thing is that the dark blue/light blue spring came off a set rear USDM 04 wrx strut and was paired with a wrx sedan rear spring.
Old 03-02-2008, 03:40 PM   #315
BIGSKYWRX
Member#: 7958
09 GH B+
I'm guessing that is probably what it is- "regular" v8 STi
have you put a micrometer to any of them- just curious if they use different wire on any of them (my STi Tarmac springs have thicker wire)
there was a thread floating around that confirmed that certain (maybe all) WRX's have different springs left and right in the rear
^ that's a great collection of springs
Old 04-15-2008, 11:50 PM   #316
DinoGuan
Member#: 42233
04 WRX waGGon
So I have a set of supposedly V7 JDM STi struts and springs. The rear's match up to the color code here but I cannot find the code for the fronts anywhere. The fronts are Orange over Green Yellow. Here is a pic of them:
Anyone know what these are?
DinoGuan is offline   Reply With Quote
Old 04-20-2008, 02:16 PM   #317
E_Jay_Twenty
Member#: 124875
2002 WRX-MBP
1992 240sx coupe sr20
bump i wanna know what ^^^ these are
E_Jay_Twenty is offline   Reply With Quote
Old 05-30-2008, 12:03 PM   #318
Handsdown
Member#: 29355
more mystery springs... pm me if you can identify these!
Old 04-08-2009, 12:30 PM   #319
thejaredhuang
Member#: 86206
2006 WRX Wagon
Nevermind. Bump for OEM parts.
thejaredhuang is offline   Reply With Quote
Old 05-04-2009, 10:33 PM   #320
mywaganiswhite
Member#: 150586
2084 Wagin
19x7 Krew
Hey guys I have jdm sti pink springs (v7) that have a color combo I cannot find here.
front: no color dots?
rear: red top, yellow bottom, grey insulator on bottom.
I may be missing dots, but I don't think so.
Any help would be appreciated, as I am trying to sell and everyone swears by the dots.
mywaganiswhite is offline   Reply With Quote
Old 08-01-2009, 12:15 PM   #321
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So it's been a couple of years, I've pulled a couple of USDM STi suspension off (all with different paint codes), and I still haven't seen this pattern repeated.
Does anyone know what springs have two purple marks both front and rear like this:
Old 08-24-2009, 10:44 AM   #322
Daedalus
Member#: 29049
2007 WRX Wagon
On the topic of WRX Inverted Struts, I've possibly run into some more part numbers depending on type (version?).
Can anyone confirm these? (Also, does type = revision, or maybe car version?)
NOTE: It looks like I might have front and rears all mixed up... trying to find the proper info now.
GGB (Sti Wagon)
Type A:
Front ? = 20310FE020
Front ? = 20310FE030
Rear ? = 20360FE020
Rear ? = 20360FE030
Type B:
Front ? = 20310FE320
Front ? = 20310FE330
Rear ? = 20360FE320
Rear ? = 20360FE330
GGA (WRX Wagon)
Type C:
Front ? = 20310FE820
Front ? = 20310FE830
Rear? = 20360FE820
Rear ? = 20360FE830
Type D:
Front ? = 20311FE221
Front ? = 20311FE231
Rear ? = 20360FE721
Rear ? = 20360FE731
Type E:
Front ? = 20311FE220
Front ? = 20311FE230
Rear ? = 20361FE320
Rear ? = 20361FE330
SOURCE
Daedalus is offline   Reply With Quote
Old 08-24-2009, 02:25 PM   #323
BIGSKYWRX
Member#: 7958
09 GH B+
I can verify the revision C part #'s, those are the ones I had previously and they were indeed inverted (they also were more firmly damped than the oe USDM MY04 WRX wagon non inverted dampers)
part#'s are listed as FR,FL,RR, RL
I can also verify the GGB rev A's as I had a set of those as well (I think they are still available through the dealers as the SPT kit for the 02/03 WRX wagons- comes w/ dampers and springs)
Old 12-01-2009, 05:39 PM   #324
25rsti
Member#: 166324
bump for a good thread
Old 03-18-2010, 11:55 AM   #325
erikkellison
Member#: 67412
2013 WRX
Default Which are these?
So I've searched high and low, and I can't ID these springs for sure. I have seem some mentions of people having the same color combo (including the fact that the L & R are different), but everyone either has yellow on top, or doesn't specify.
If someone can definitively ID these for me, I'd appreciate it!
Orange on top, orange and yellow on bottom of one
Orange on top, red and yellow on the bottom of the other one (installed upside-down)
erikkellison is offline   Reply With Quote
Any 06 STI with a perrin 30r, please read Dana Daray Southern California Impreza Club Forum -- SCIC 4 04-09-2010 07:42 PM
$425 JDM GC8 WRX sti suspension takeoffs COMPLETE 4 corners supermoose Private 'For Sale' Classifieds 12 06-29-2006 02:57 PM
please post pics of wrx with sti suspension 04wrx555 Member's Car Gallery 10 03-30-2005 03:35 PM
JDM V8 STi suspension takeoffs (long) Jeff_DML Car Part Reviews 19 08-20-2004 03:09 PM
Everyone with a modded car, please read. jimb Tri-State Area Forum 17 10-24-2003 06:25 PM
