Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 05-01-2010, 03:14 AM   #326
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
How about updating the first post with spring rates and ride heights?
chimchimm5 is offline   Reply With Quote
Old 06-14-2010, 12:25 PM   #327
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Has it been mentioned what the spring rates and drop are for the MY04 JDM STi springs?
Superorb is offline   Reply With Quote
Old 06-21-2010, 08:41 PM   #328
shiux
Member#: 246821
Sedona Red Pearl
My sti springs are 2 purple, and 1 purple 1 green. Did I miss something?
shiux is offline   Reply With Quote
Old 06-22-2010, 07:01 PM   #329
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
I am being offered a set of spring that wont lower the car much but will be as stiff as STI's. This set is for the GC body. THe only problem there is no part number to check the spring rate... So here is a picture of them...
Anybody knows how to de-code the paint marks?
Elliot is offline   Reply With Quote
Old 06-24-2010, 09:22 AM   #330
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
bump!! for help needed
Old 08-22-2010, 07:38 PM   #331
Rick Schumacher
Member#: 210864
1998 impreza 2.5rs
black on gold
ive looked through this entire thread
what are these
SPRINGS
1-pink over 1-blue
1-yellow over 2-green
and
STRUTS
LK14
20360FA242
LK16
20360FA252
E8 STAMP w/1-blue dab, and 2-white dabs
LK17
203LOFA842
w/1-blue dab, 2-pink dabs
LK17
20310FA852
springs rates and what is this ?
Rick Schumacher is offline   Reply With Quote
Old 08-23-2010, 06:53 PM   #332
Rick Schumacher
Member#: 210864
1998 impreza 2.5rs
black on gold
anyone? ^
l
please!
Old 09-09-2010, 07:43 PM   #333
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by williaty View Post
So it's been a couple of years, I've pulled a couple of USDM STi suspension off (all with different paint codes), and I still haven't seen this pattern repeated.
Does anyone know what springs have two purple marks both front and rear like this:
Ever get an answer to this?
I know that on my '04 it's purple/purple front and green/green rear.
Web Foot STi is offline   Reply With Quote
Old 09-09-2010, 07:44 PM   #334
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Nope, still wish I had an answer.
Old 09-09-2010, 07:55 PM   #335
Web Foot STi
Member#: 39086
2004 STi
Hmm.
Your post #295 said they came off a '05 STi and post #314 says the purple/purple rear came off an '07 STI.
Could Subaru have done one of their infamous running changes in '04-'05?
I don't remember anything about a rate change in the rear.
Old 12-04-2010, 10:08 AM   #336
chockrl
Member#: 265528
2004 WRX STI
I know this thread has been going on for years, and some patterns seem to have formed in the various dots on the springs. But one of the first things that came to mind, was that the dots are just assembly checks. One guy on the line installs his part, and puts a dot on a certain coil. The next guy installs his part, and then adds a dot. When the car reaches the end of the suspension installation, they check that all the dots are present, and the car goes on to be completed. I would assume the suspension is such a safety concern that insuring everything is installed, and torqued would be a priority.
This could explain different dots for different versions, separate assembly lines and different workers. Each worker may have a different color. And it could explain cars that are the same model having different dots, worker A is sick one day, worker B takes his place and puts his different dot in the same place worker A would have.
Just an idea.
chockrl is offline   Reply With Quote
Old 12-04-2010, 10:23 AM   #337
BIGSKYWRX
Member#: 7958
09 GH B+
or they have lots and lots of iterations of springs (and bushings) on hand and need a way to correctly identify what is what
Old 12-11-2010, 08:59 PM   #338
chockrl
Member#: 265528
2004 WRX STI
Just got done changing out my stock struts, and there were quite a few pink, purple, etc. lines here and there on different components.
Maybe they do use the dots to designate different springs in the factory, I didn't see any part numbers or anything on my stock ones.
Old 08-02-2011, 08:37 PM   #339
Board junkie
Member#: 276538
2003 Wrx Wagon
306awhp/277awtq-EWG/FMIC
Question what do I have?
So I've searched high and low for a set of 04' struts for a set of springs i bought, ended up I could only get a full set so I took it.
Here's what I got, the seller claimed these are a JDM STI Pink set..
He laughed when I said, those are stock springs not "Pinks"
Either way my cars in pieces and not being driven, so I bought em just to get it back on the road, and me happy again.
Front struts-
RA RH - 20311FE300
RA LH - 20311FE310
as seen in pic below both front have a "purple, purple" blot marking on the third coil up
Rear Struts-
20360FE852
20360FE842
also as seen below paint markings are "green, purple"
I noticed the struts do have KYB stamped on them.
going off the first post... This what I assume to have...
GDB(d) STi spec C
Right Front strut - 20311FE300
Left Front strut - 20311FE310
Right Rear strut - 20360FE840
Left Rear strut - 20360FE850
Front spring - unknown
Rear spring - unknown
What set is this? Is it still unknown, and what's it expected or normal "used" price?
TIA
Board junkie is offline   Reply With Quote
Old 10-13-2011, 09:31 PM   #340
sip
Member#: 170475
1995 GF8 WRX Wagon
GC8 STi RA ver. II
I noticed no GC8 STi take off info so here is mine:
WRX Sti Sedan Version 4
Positon .......Part number... Paint mark on spring
Front Left.... 20310FA610 ...Orange dot/ Red dot
Front Right... 20310FA600... Orange dot/ Red dot
Rear Left .....20360FA252.... Pink dot/ Pink dot
Rear Right.... 20360FA242 ....Pink dot/ Pink dot
Feel free to add it to the first page.
sip is offline   Reply With Quote
Old 11-21-2011, 08:59 AM   #341
darkness16
Member#: 133498
2007 2.5i
grey
Just picked up a pair of 07 STi takeoffs and they have the same purple/purple markings on both the front and rear springs.
darkness16 is offline   Reply With Quote
Old 07-01-2012, 02:50 PM   #342
slintux
Member#: 320058
2005 Impreza 2.5RS
Did anyone ever figure out what the rear 1 purple 1 green springs are?
I have two sets of STi springs, one set has 2 purple markings on both the front and rear springs. These were sold to me as '05 STi springs. The other set has 2 purple dots on the front and 1 purple 1 green on the rear. They were sold to me as part of '04 STi takeoffs.
I'd like to know the specs on the rear springs so I can figure out which ones to use. I'm guessing the purple/green springs have a higher spring rate due to the extra dead coil? Any differences in ride height?
slintux is offline   Reply With Quote
Old 07-01-2012, 11:34 PM   #343
Web Foot STi
Member#: 39086
2004 STi
On ebay someone one was selling a set of springs off of an '06 STI recently and they were purple purple front and rear.
slintux, Dead coils per se don't add to to the spring rate all other things being equel. It's the number of active coils.
K=(W^4)*G/*8*N*(D^3)
K=spring rate lb/in
W=wire diameter in
G=120,000,000 for steel
N=number of active coils
D=diameter of the coil at the center of the wire.
Old 11-06-2012, 11:33 AM   #344
eph
Member#: 83120
1992 Legacy Sport
Did anyone ever run into white, green, green for front springs?
eph is offline   Reply With Quote
Old 07-30-2013, 01:46 PM   #345
trueno92
Member#: 111755
this thread has been infinately helpful to me, so thanks guys for putting this together.
Do you guys know the ride height differences between v7 sti take offs and 04 sti suspension?
I searched and I see that 02-03 MY01-02 wrx's are about 10mm taller than the STI springs but I cannot see WHICH STI is being referenced. the v7? or v8 models?
I have V7 sti fronts and the mythical V7 GENOME rears and I have read that the GENOME rears are 20mm shorter than stock.. but stock compared to WRX's..
I am a bit confused as to what I'd end up with in installing these to my 02 wrx..
Thanks for help, if any..
trueno92 is offline   Reply With Quote
Old 07-30-2013, 01:48 PM   #346
trueno92
Member#: 111755
Is there any ride height differences between v7 and v8 sti suspension?
Old 12-05-2013, 10:50 AM   #347
couchforester
Member#: 372262
I picked up a set of sti springs yesterday that were both the front and rear are purple/purple. Granted He pulled these out of a pile of springs so not sure if they were all off the same car. The only ting I am certain of is the coil count is correct.....I think I know in the picture its hard to see the purple on all of them but they all have it. Some are just rubbed off a little more
couchforester is offline   Reply With Quote
Any 06 STI with a perrin 30r, please read Dana Daray Southern California Impreza Club Forum -- SCIC 4 04-09-2010 07:42 PM
$425 JDM GC8 WRX sti suspension takeoffs COMPLETE 4 corners supermoose Private 'For Sale' Classifieds 12 06-29-2006 02:57 PM
please post pics of wrx with sti suspension 04wrx555 Member's Car Gallery 10 03-30-2005 03:35 PM
JDM V8 STi suspension takeoffs (long) Jeff_DML Car Part Reviews 19 08-20-2004 03:09 PM
Everyone with a modded car, please read. jimb Tri-State Area Forum 17 10-24-2003 06:25 PM
