Old 05-15-2003, 02:27 AM   #1
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
Default 30k tune up list?
can someone compile a thorough list needed to complete a 30k tune up? i did a search and came up with one list but while searching came up with other little things such as brass crush washers for the radiator when flushing the coolant. also what parts need to be picked up at the dealer if any. thanks.
imprezey is offline   Reply With Quote
Old 05-15-2003, 10:05 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
do a search under my name, probably no more then 3 months back
i listed what i did and also problem areas, parts, how some other tidbits
vile is offline   Reply With Quote
Old 05-15-2003, 01:01 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
What's this about? I didn't notice any washers on the plastic radiator drain spigot or on the radiator cap when I drained and refilled my radiator.
Old 05-16-2003, 12:18 AM   #4
imprezey
Member#: 17178
2001 2.5RS Coupe
i read when you are flushing your coolant there is a brass crush washer that should be replaced.
Old 05-16-2003, 01:24 AM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You might be confusing the brass crush washer on the oil drain plug, which should be replaced after every oil drain.
Old 05-18-2003, 01:30 PM   #6
dorifto88
Member#: 17684
1989 pathfinder
rusted red
you ever get that list?
dorifto88 is offline   Reply With Quote
Old 05-19-2003, 01:56 AM   #7
tdxflex
Member#: 13634
i got my checklist from subaru.com in the owners tab. off the top of my head 30k is:
replace:
air filter
engine oil
oil filter
tranny oil
rear diff oil
pvc valve, i mean pcv valve
fuel filter
coolant (might just be an inspection, i forgot)
inspect:
brake lines, fluid, pads
clutch fluid
actually all fluids
rotate tires
only the oil drain plug has a gasket, don't remember anything on the tranny or diff plugs (i know the diff plugs have some sort of thread sealer on thema lready, not sure about the tranny plug). pvc you should use teflon tape. coolant there is no gasket, the drain plug at the bottom doesn't have anything but i used some teflon tape just in case. also unbolt the coolant overflow tank because junk usually accumulates at the bottom of that (the hose just comes right out, and then the two 10mm bolts).
tdxflex is offline   Reply With Quote
Old 05-19-2003, 12:43 PM   #8
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
I know brake fluid is supposed to be flushed @ 30K
cavymeister is offline   Reply With Quote
Old 05-19-2003, 01:51 PM   #9
vile
Member#: 32371
'02 t-rex wagon
platinum
hehe, he called it pvc, i thought i was the only one that miss typed it.....it's pcv
anyways, don't forget your air filter as well
and yes, brake fluid needs to be flushed, according to the manuel
Old 05-19-2003, 02:08 PM   #10
tdxflex
Member#: 13634
every single time
Old 05-20-2003, 09:01 AM   #11
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
... according to the manuel
(cough) manual
BlueTDimly is offline   Reply With Quote
Old 05-20-2003, 11:23 AM   #12
WaldorfSalad
Visiting NASIOC Timeout
Member#: 35398
2002 WRX Wagon
replace:
air filter
engine oil
oil filter
tranny oil
rear diff oil
fuel filter
inspect:
clutch fluid
actually all fluids
rotate tires
Reading from my warranty book:
Inspect:
Drive Belts
Camshaft Drive Belt
Transmission / Diff. oil
ATF
Brake pads & rotors
Front & Rear Axle Boots & Axle Shaft Joint Portions
Brake lines
Clutch Operation
Parking & Service Brake Operation
Steering & Suspension
Cooling system hoses & connections
Fuel lines & Connections
Replace:
Engine Oil & Filter
Coolant
Air Cleaner Element
Spark plugs (non-turbo engines)
Brake Fluid
Fuel Filter
Rotate Tires
That's a brief once-through. Check your warranty manual for intervals for severe driving, cold weather etc. etc. etc. Interestingly enough, the PCV valve isn't mentioned. Seems funny, since it's such a cheap part.
I'm having my 30k service done today, and I'm also having an alignment done (and a clutch replacement if the dealer can duplicate the shudder problem). They (Burt Subaru in Littleton, CO) also recommended a dose of BG additives in the rear diff, trans, and oil. I remember good ol' BG 44K from my days of playing with aircooled VW's, so I let them go ahead with it.
-joe
WaldorfSalad is offline   Reply With Quote
Old 05-21-2003, 12:05 AM   #13
six6sicks
Member#: 28876
2000 Impreza 2.5 RS
Blue Ridge Pearl
Just curious,
I've done a few of the tune up stuff myself, how much does it usually cost to have some one do a FULL tune up on your car? like swapping fluids and fliters with new stuff.
six6sicks is offline   Reply With Quote
Old 05-26-2003, 04:20 AM   #14
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
here's the link for calif spec vehicles:
calif_spec
here's the link for federal spec vehicles:
fed_spec
my apologies, didn't realize the original poster has a my01. anyways, the site has the list for cars going pretty far back.
yuletak is offline   Reply With Quote
30k Tune Up lb05wrx Southern California Impreza Club Forum -- SCIC 9 09-07-2008 06:53 PM
30K Tune-Up Time~ $700 ? Jokoso Newbies & FAQs 41 05-26-2006 02:32 PM
30k tune up AspWhtRex Service & Maintenance 10 02-24-2004 06:46 PM
30k miles tune up. RotarFreak North West Impreza Club Forum -- NWIC 5 02-04-2002 04:41 PM
Please Advise: 30K Tune Up plugs and fluids your suggestions subenutt New England Impreza Club Forum -- NESIC 5 02-28-2001 02:23 PM
