Old 05-15-2003, 02:33 AM   #1
RChampion
Member#: 21481
99 2.5RS
14 Impreza STI
Default high flow cat vs $$
where can i pick up a high flow cat thats worth the price? is there such a thing? so far i havent found one for under 300 bucks, and thats quite a lot for only a couple hp
RChampion is offline   Reply With Quote
Old 05-15-2003, 09:38 AM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
get a universal cat and have a local exhaust shop weld on the piping and flages... you should be in the $100 range...
DanzBorin is offline   Reply With Quote
Old 05-15-2003, 04:47 PM   #3
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Ditto, I ended up spending 150 though but well worth it.
Buster
EvasionOfTruth is offline   Reply With Quote
Old 05-15-2003, 05:07 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Catco brand high-flow cats are under $100 from Summit Racing (http://www.summitracing.com) and worth every penny. There are more designs variations than I can count and you're sure to find one that's gonna fit your setup. Install at any muffler shop (weld in) should be ~$50 but you may have problems if your car is under 50,000 miles. What the muffler shop needs to realize is the 2 cats on an Impreza are doing different functions (each one scrubs different gasses) and a single replacement cat will take the place of both.
Old 05-15-2003, 05:26 PM   #5
DanzBorin
Member#: 7131
2015 Outback - Croc
Do these cats have metallic or ceramic cores?
You might be able to get them to make you a pipe as long as they don't let you drive out with it. Just tell them it's for when you go to the track. <wink, wink> Then swap it out when you get home...
Old 05-15-2003, 05:52 PM   #6
wistful
Member#: 745
2004 STi
Java Black Pearl
wistful is offline   Reply With Quote
Old 05-15-2003, 09:01 PM   #7
Basshead
Member#: 112
2011 Jetta TDI
i'm sure the catco cats are ceramic hence their low cost...i know the random tech cats are all metal and that is why they are more expensive...
Basshead is offline   Reply With Quote
Old 05-16-2003, 09:16 AM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Not sure what the core is but from looking through it it appears to be a series metal screens (you can see right trough it which is very cool).
Old 05-16-2003, 12:38 PM   #9
Pat L.I.
Member#: 20498
2006 WRX TR
has anyone had both a random tech cat, and any other brand? im interested in the comparison. I doubt there would be any "noticable" performance difference at all but im still curious. i also need another reason not to spend rediculous amounts of money on the random tech. i was quoted $405 over the phone from a guy at random tech, for the cat that is a direct bolt on to the 2.5rs.
Pat
Pat L.I. is offline   Reply With Quote
Old 05-16-2003, 01:19 PM   #10
RChampion
Member#: 21481
99 2.5RS
14 Impreza STI
what kind of length should i look at for the catco cheap ones? I guess if it was too long or too short the muffler shop could take care of it though...
Old 05-16-2003, 01:22 PM   #11
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
IIRC mine is the 14" dual O2 sensor model... gave me a little flexibility with my completely custom exhuast setup.
Old 05-16-2003, 09:33 PM   #12
obyone
Member#: 16523
Default Re: high flow cat vs $$
A stock cat restricts your HP output proportionally to how many other mods you have.
obyone is offline   Reply With Quote
