Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 05-15-2003, 07:36 AM   #1
orndog
Member#: 34670
2013 No gears!
Saltine American
Default PDM-Racing intake
So I installed it and a K&N filter. I left the negative cable off the battery during the whole installation. When I first started it up, it gasped a bit, then settled into a nice idle. It sounds really nice. However, below 2500 RPM, it feels like I've lost my balls! I thought designs that preserved the stock intake box kept low-end torque? This pipe is just like the Ganzflow. Anybody else have this prob?
orndog is offline   Reply With Quote
Old 05-15-2003, 11:10 AM   #2
live311
Member#: 10801
2008 Outback
make sure your airbox is completely closed. You may not have sealed it properly when you put the filter in. If that's not it, just drive like a maniac for a couple hundred miles until your ECU relearsn everything. That should take care of it.
live311 is offline   Reply With Quote
Old 05-15-2003, 11:44 AM   #3
codger
Member#: 13486
06 Legacy GT wagon
I found it an improvement on the low end. Less jerky in stop and go traffic, like when you take your foot off the gas idling along in first, and your passenger's head bobs forward. Much smoother now. And typically I spend very little time below 2500. Launch at 1500, shift anywhere from 3000 to 5000, generally keep it in range 2500 to 3500.
Jim
codger is offline   Reply With Quote
Old 05-15-2003, 04:09 PM   #4
orndog
Member#: 34670
2013 No gears!
Saltine American
"server too busy"
sheesh, lost everything I typed.
Anyway, thanks for the advice, I'm going to go flog her a bit
I know the filter box is sealed, I removed it to install the K&N. Also, I notice it's smoother too, but I think it's because I have no throttle response down low.
Old 05-16-2003, 12:21 AM   #5
codger
Member#: 13486
06 Legacy GT wagon
I hated that low RPM throttle response - especially first gear on bumpy broken roads. The bumps would get me bouncing in the seat, my foot lifting off the pedal a bit, and then the car jerks and bucks. Much much better now.
Old 05-16-2003, 11:50 AM   #6
obsrules
Member#: 16400
2002 Outback Sport
Savannah Green
I have had my PDM installed on my 2002 OBS A/T for about 5 months now. Recently, when I first start my car in the morning and start to move, the car severely hesitates and feels like it might stall and then it jerks and all my throttle response comes back. It only happens when the car isn't warmed up and it only started a week ago. Is this more of a symptom of clogged CAI/filter or possibly transmission? Thanks.
obsrules is offline   Reply With Quote
Old 05-16-2003, 02:19 PM   #7
goobie
Member#: 8273
2006 WRX Wagon
Default ECU need to learn how to use new air flow
Since you disconnected the battery, I thinking the ECU has been reset. Did you follow the "NASIOC generally accepted procedures" for re-programming the ECU? If not, give this a try.
1. Disconnect Battery again for 20-30 minutes
2. Wash Car, Clean garage (do whatever for those 20-30 minutes)
3. Hook battery back up and (get ready for alarm to go off, if you have one)
4. Start car, DO NOT TOUCH THE GAS!. The car might die on the first start, if so, restart.
5. Let car idle for 15-20 mins (or until electric cooling fans kick-in)
6. Shut the car down.
7. Restart, go for a "spirited" drive brinning the engine to redline serveral times.
The ECU should learn how to effectivly use that added airflow quickly this way.
Chad
goobie is offline   Reply With Quote
Old 05-16-2003, 05:57 PM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
Default Re: ECU need to learn how to use new air flow
Chad
And if it doesn't, I sure had fun trying!!!
Old 05-16-2003, 09:02 PM   #9
goobie
Member#: 8273
2006 WRX Wagon
Yeah it's bit of a hassle but it works!
Do a search on "ECU Reset" for more info.
Cheers,
Chad
Old 05-17-2003, 12:18 PM   #10
orndog
Member#: 34670
2013 No gears!
Saltine American
If I had a garage - or didn't live in West Tennessee (will it EVER stop raining?), I would try this. *sigh*
You're right, though, a run to the redline is much smoother now.
why is the pdm racing intake for 2000 and up? svek Normally Aspirated Powertrain 4 04-09-2005 09:08 AM
FS: PDM racing intake w/ K& N for RS/TS 03 Canuck TS Private 'For Sale' Classifieds 0 02-09-2005 07:49 AM
WTB: PDM racing style cold air intake for 2000 2.5RS anonymous_wolf Vancouver Impreza Club Forum -- VIC 17 09-15-2004 11:08 PM
PDM Racing Intake, Whiteline front links, Sedan OEM front sway Blue Ridge OBS Private 'For Sale' Classifieds 2 04-27-2004 02:02 AM
FS: PDM Racing Intake pipe dcgear Vancouver Impreza Club Forum -- VIC 9 01-11-2003 10:06 PM
