Old 05-15-2003, 04:00 PM   #1
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Default Window clunk (it's not what you think)
The driver window on my 99 RS 2.5 clunks at the bottom of its travel Until yesterday it was a bit noisy at the top of its travel too. Searching here revealed that window motor bolts tend to work loose in the door causing this noise. So I pulled the door panel off (remarkably easy to do, I thought) and started to tighten bolts, none significantly loose. I started examining the window mechanism and figured out how to adjust the top of the travel. This allowed me to minimized the noise that I got when putting the window up. I have not been able to determine how to adjust the bottom stop. The carrier in the front (not quite) vertical guide rail is whacking the bottom of the inside of my door. I don't see any obvious way to adjust the downward travel limit. There is a screw on the top of the window motor. It looks like with the window down, and a sufficiently long scrwedriver I could turn this screw, but I have no idea if that would do me any good. I'm hoping to get advice from a soob-guru as to what my next step should be. In the meantime I put some fatmat (dynamat extreme knockoff) on the door where the carrier hits, this has reduced the noise somewhat, but is obviously not a real fix.
Sorry for the long post, I just wanted to be sure that I covered everything.
-Tony
nunyo is offline   Reply With Quote
Old 05-16-2003, 03:34 PM   #2
silvertoy
Member#: 23580
2003 WRX Wagon
both of the front windows on my '03 WRX clunk when they hit the last inch of travel. I thought it had something to do with my speaker install and the window bolts hitting the XTC baffles at the bottom... But if there's more to it, I'm very interested...
silvertoy is offline   Reply With Quote
Old 05-30-2003, 01:43 PM   #3
speedbuggy67
Member#: 9041
blaze yellow 1-450
My windows on my 02 wrx clunked like mad and i was living with it. i just had my mirros fully painted and i dropped a bolt down the door so i took the panel off and poof only 3 bolts were ther and one fell out i tightened all 4 then and no more probs. Hope this helps. PM me for more info.
Scott
speedbuggy67 is offline   Reply With Quote
First Amendment in jeopardy (rant - not what you think) ItalianGuy Off-Topic 19 01-20-2010 12:42 AM
Help me find my trunk lock...it's not what you think BoostbyU06 North West Impreza Club Forum -- NWIC 21 08-25-2009 01:56 PM
pedamundo - it's not what you think Wagon Of Fury Off-Topic 7 06-15-2009 05:33 PM
A question about headlight bulbs (and not what you think) tooocool49723 Electrical & Lighting 2 01-14-2005 11:55 PM
Ok it's an exhaust question, but it's not what you think. obyone Normally Aspirated Powertrain 14 06-04-2002 01:55 PM
