Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 05-15-2003, 05:52 PM   #1
suby_dude
Vendor Sales Rating: (105)
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Default Up-Pipe Leak?
it could just be the gasket?
Dyno Engineering's WRX Gasket Kit - $70 FREE Shipping
Complete Set! Includes replacements for the following WRX parts
G5101A, G5201B, G5301C, G5401D, G5501E.
Compare the two:
PRODUCT DESCRIPTION:
This kit contains a set of 5 gaskets that are critical to replace during up-pipe installation to prevent possible exhaust leakage and performance loss. This kit is available at the retail price of $70 and includes up-pipe to turbo, up-pipe to manifold, turbo to down-pipe, manifold to engine, and manifold to crosspipe.
The gaskets were engineered using proven materials designed for high-temperature and high-pressure applications. Using a unique formula of more than 80% chrysotile asbestos fiber in a SBR synthetic rubber, the gaskets have demonstrated reliability at over 1500F and 1000 psi. The material exceeds rigid specifications including military MIL-A-7021C.
hhmmm..... $150 and up for a new uppipe? or $70 on a gasket.... :confused: :confused:
c'mon... these gasksets rock! :disco:
I thought my Vishnu uppipe were leaking... i put these puppies on... solved!
Gasket Kit (5 pcs.) - $70 free shipping - Paypal Now for the Gasket Kit!
Also Available Individually...
Up-Pipe to Manifold Gasket (1 pcs.) - $15 free shipping -
Manifold to Engine Gasket (1 pcs.) - $15 free shipping -
Manifold to Crosspipe Gasket (1 pcs.) - $15 free shipping -
Up-Pipe to Turbo Gasket (1 pcs.) - $20 free shipping -
Down-Pipe to Turbo Gasket (1 pcs.) - $20 free shipping -
VISA & MASTERCARD Orders also accepted!
thx
SD
http://www.subydude.com
[email protected]
510.378.6436
__________________
[CENTER][SIGPIC][/SIGPIC][/CENTER]
[CENTER][B]
| Phone: 510.252.1111[/b][/CENTER]
suby_dude is offline
Old 05-15-2003, 06:17 PM   #2
wannaimpreza
Member Sales Rating: (2)
Member#: 14264
'03 wrx
wrblue
can i get just the lower uppipe gasket
uppipe to manifold
wannaimpreza is offline
Old 05-15-2003, 06:21 PM   #3
suby_dude
Member#: 17397
WRB, White
uppipe to manifold
yes.
that's $15 shipped.
Paypal Here
sd
__________________
[CENTER][B]
Old 05-18-2003, 01:11 AM   #4
suby_dude
Member#: 17397
WRB, White
ttt
__________________
[CENTER][B]
Old 05-18-2003, 10:22 AM   #5
sil0nt
Member Sales Rating: (6)
Member#: 30584
05 STi Black
07 S4 Avant Black
Are all of these gaskets needed for an uppipe install? I would think that just the manifold->uppipe and uppipe->turbo would be needed.
Also, how are these gaskets different than the ones I can buy from my dealer.
sil0nt is offline
Old 05-18-2003, 10:42 AM   #6
suby_dude
Member#: 17397
WRB, White
all the gasket above is KIT when you do an uppipe install... it would be ideal to use all of them.
from the pix above you can see that these gaskets are quite a bit thicker than the OEM ones. its to give a little room for error for using aftermarket pipes. crush type washers (oem ones) even fail on stock pipes.
__________________
[CENTER][B]
Old 05-18-2003, 02:47 PM   #7
SilverBoosted
Member Sales Rating: (1)
Member#: 7764
11 Edge Sport
Kona Blue Metallic
Ordered mine hope to have them mon/tues.... will see if it eliminates my up/downpipe leaks next weekend...
.....thanks subydude
SilverBoosted is offline
Old 05-20-2003, 12:03 PM   #8
suby_dude
Member#: 17397
WRB, White
yes
please keep us updated.
SD
__________________
[CENTER][B]
Old 05-20-2003, 07:45 PM   #9
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
Just got them today...they look pretty hefty and hopefully will cure my leak problems.....thanks subydude you rock!!!!!....Now if only you had those subydude stickers in silver or black...
Old 05-20-2003, 07:51 PM   #10
suby_dude
Member#: 17397
WRB, White
oh
i have it in silver, black, blue, white and yellow.
which one did you get?
SD
__________________
[CENTER][B]
Old 05-21-2003, 03:58 AM   #11
JohnW
Member#: 14583
2002 WRX Wagon
When you do the uppipe install, you have to disassemble the turbo to downpipe in order to get to the bolts to remove the uppipe from the turbo. In addition, you need to remove the manifold to engine and manifold to crosspipe in order for the uppipe to drop down away from the turbo. Hence, it is recommended that you replace all of these gaskets.
The difference between these gaskets and the ones you buy from the dealer (OEM) is in the materal. Instead of 3 thin sheets of metal with a small crush ring for sealing, these gaskets use a material specifically design for sealing in high temperature and high pressure environments. The NHRA Pioneer Avenger Drag Race car used gaskets made of this material.
One area in which there is no difference with the OEM gaskets is fitment. No expense were spared to ensure that the die cuts are to the exact OEM specifications and quality control ensures that every gasket is a perfect fit!
Because of SBR binder in the gasket material, the one temporary downside is a slight burning rubber odor during the first few hours of operation. This will completely disappear so don't worry.
If you have any questions, please feel free to send me an email or contact subydude!
John
JohnW is offline
Old 05-21-2003, 09:12 AM   #12
Hank3
Member Sales Rating: (22)
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
How much for yellow subydude stickers?
Hank3 is offline
Old 05-21-2003, 09:42 AM   #13
MrSwede
Member#: 9487
2002 Impreza WRX
Silver Surfer
Are these gaskets reusable?
MrSwede is offline
Old 05-21-2003, 08:03 PM   #14
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
Originally posted by suby_dude
oh
SD
I got the yellow ones......me wants black/silver...pretty please....
Old 05-22-2003, 02:19 AM   #15
JohnW
Member#: 14583
2002 WRX Wagon
It is usually not recommended to reuse gaskets because gaskets are usually cheaper to replace then the labor to reinstall with new gaskets if you run into trouble.
That said, these gaskets are "more reuseable" than the OEM metal crush gaskets because the "Recovery ASTM F36" is greater than 50%. The higher the recovery, the better the seal retention. The OEM metal crash gasket has a recovery of 0%.
JohnW is offline
Old 05-22-2003, 08:00 AM   #16
chunkylover53
Member#: 36831
Got mine today - thanks suby_dude
chunkylover53 is offline
Old 05-22-2003, 10:24 AM   #17
suby_dude
Member#: 17397
WRB, White
nothing for you.
just send me an email.
SD
__________________
[CENTER][B]
Old 05-22-2003, 10:41 AM   #18
DanD
Member#: 17330
2002 WRX Wagon
so R U plan on having these in the next month?? OR once U sell them all, U won't be getting anymore? Thanx, Dan
DanD is offline
Old 05-22-2003, 10:45 AM   #19
suby_dude
Member#: 17397
WRB, White
Dan,
we are planning on having this on regular production.
SD
__________________
[CENTER][B]
Old 05-22-2003, 10:53 AM   #20
wlelandj
Member#: 15127
Thumbs up
Just ordered mine I think I'm finally going to get an uppipe. I can't belive I've held out this long. I figure the cost of the uppipe will pay for itself in the cost to fun to drive ratio long before I have enough money to do any of the major hp upgrades.
Thanks suby_dude!
-Leland
wlelandj is offline
Old 05-22-2003, 10:56 AM   #21
suby_dude
Member#: 17397
WRB, White
Thanks suby_dude!
-Leland
got it leland.
thanks.
should be there no later than monday.... maybe even sat.
SD
__________________
[CENTER][B]
Old 05-22-2003, 11:19 AM   #22
Hank3
Member#: 16157
'03 Mazda P5 <><
nothing for you.
SD
Thanks man!!! E-mail'd ya
Hank3 is offline
Old 05-22-2003, 11:40 PM   #23
ImprezaWRXDriver
Member#: 7152
2002 Impreza WRX
Traditional Blue and Gold
Free bump for tha Dude. Great guy to get stuff from.
ImprezaWRXDriver is offline
Old 05-23-2003, 12:33 PM   #24
MK19
Member#: 21977
Bear s like food
bump for the man, er I mean dude
MK19 is offline
Old 05-23-2003, 07:33 PM   #25
Hazdaz
Member#: 14611
NO credit card orders??
Hazdaz is offline
Up-pipe leak? Details? Chewy-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-15-2002 09:41 AM
up-pipe leak when warm? JohnW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-28-2002 03:37 PM
up-pipe leak at boost. should I get it fixed? JohnW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-21-2002 11:03 PM
Up Pipe Leaks, how to fix them!! (long) lestion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-15-2002 11:03 PM
