05-16-2003, 02:55 PM | #1 |
Member#: 25658
Vehicle:2003 Impreza WRX Sdn Midnight Black Pearl |
Instructions on replacing Transmission Fluid
Hi, I'm rather a newbie when it comes to auto mechanics and stuff. But I was wondering if somebody out there had links to a good instructions for changing the transmission fluid on a WRX.
My car only has 7000 miles on it, but I was hoping that doing this fluid change would help smooth out the shifty, since it's still quite notchy. Thanks for your help!
05-16-2003, 03:32 PM | #2 |
Member#: 12619
Vehicle:02 WRX Wagon #47 SM w/RA gears |
For the manual tranny, by the turbo in the back is the tranny dipstick. Pull it up so it doesn't make a seal. On the bottom of the tranny there's a huge 21mm bolt. Pop that off and the fluid comes pouring out. Clean the bolt off of metal shavings, screw it back in. You have to pour the new gear oil in through the tranny dipstick tube. Get a funnel with a tube and pour in 3.8 quarts. Check with the dispstick to make sure. That's pretty much it.
edit: It's a 21mm bolt, not a 22! Last edited by mtb_dude; 05-16-2003 at 04:18 PM. |
05-16-2003, 04:43 PM | #3 |
Member#: 30887
Vehicle:2003 wrx |
05-16-2003, 07:01 PM | #4 |
Member#: 25658
Thanks
Cool, thanks for your help!
05-16-2003, 10:04 PM | #5 |
Member#: 30887
Vehicle:2003 wrx |
np
help in deciding on replacement transmission | atlblu | Transmission (AT/MT) & Driveline | 2 | 08-13-2009 04:46 PM |
Transmission Fluid Replace? | PrimeSTI | Transmission (AT/MT) & Driveline | 1 | 08-12-2009 04:47 PM |
Any instructions on how to change power steering fluid? | SC2000 | Service & Maintenance | 7 | 03-07-2008 09:11 AM |
Would transmission fluid be changed when rear output shaft bearing is replaced? | nich0lai | Transmission (AT/MT) & Driveline | 5 | 08-20-2006 12:43 AM |
Brake system fluid... Instructions for replacing. | MrP0nch0 | Brakes, Steering & Suspension | 5 | 06-14-2001 09:50 PM |
