Old 05-16-2003, 03:28 PM   #1
that1guy
Member#: 26169
98 BLI
RBP
Default borla gen 4 header
So I just installed these headers in a few days ago, and I used all the original bolts... most of it was rusted to hell, but I had it soak in some rust eater and that cleaned them up pretty good.
The problem is, the header seemed to be too short to reach the 1st cat. So we had to shift the header over a little, but one of the studs popped out before we started the shift. So once we got the header on the 1st cat the stud wouldn't go back into it's place. It was about 1/4in off. So we decided to just leave it off.
Do you guys know of anyways that I could possibly fix this problem? Since for the first 20 minutes of driving or so the car makes a "SHHHH" sound, obviously from a leak. Would this leak be doing damage? Is that even a leak since I've driven the car maybe only 20 miles at most? I have no CEL, so it can't be that bad right?
that1guy is offline   Reply With Quote
Old 05-16-2003, 06:41 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Give it a little time the header & exhaust should loosen up and fit better.
Try putting the bolt back in later. Use a prybar or something to get things lined up if need be.
Legacy777 is offline   Reply With Quote
Old 05-17-2003, 03:20 PM   #3
that1guy
Member#: 26169
98 BLI
RBP
good idea... i think im gonna try unbolting the whole header and see if i can just shift it over a little...
FS: Borla Gen 4 Headers, stock O2 sensors munkis Tri-State Area Forum 0 02-09-2003 10:43 AM
Borla Gen 4 header results Scott F. Williams Normally Aspirated Powertrain 21 12-28-2002 12:15 AM
borla gen 3 headers imprezey Newbies & FAQs 10 06-18-2002 11:23 AM
FS: Borla Gen 3 Header Marc Sawaya New England Impreza Club Forum -- NESIC 0 03-27-2001 09:37 PM
Borla Gen III header!! Group buy.. imprezawd Mid Atlantic Impreza Club -- MAIC 0 02-23-2001 03:01 PM
