Old 05-16-2003, 11:39 PM   #1
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Default Do I need to change oil sooner after engine rebuild?
I replaced 8 bent valves on my 02 WRX at 7000 miles. When reassembling the heads I used some sticky red stuff from NAPA on the cam shafts and any other points that were lacking in oil.
I was just wondering if I needed to change oil sooner? Will that stuff do anything to the oil filter?
Thanks -Scott
cky211 is offline   Reply With Quote
Old 05-17-2003, 12:20 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I assume the sticky red stuff was assembly lube, and not rtv
If I were you, I would do the first change early - say 500 or 1000 miles - but that would be because you had the engine open, and some debris could have gotten in there - the assembly lube will not be an issue - it will mix in with the oil just fine.
Old 05-17-2003, 01:52 AM   #3
cky211
Member#: 31129
02 WRX MPB
YES assembly lube that is what I used.
OK thanks for the tip!
-Scott
Old 05-17-2003, 04:33 AM   #4
bbbwrx
Member#: 32734
7000 miles what did you do???
bbbwrx is offline   Reply With Quote
Old 05-17-2003, 02:45 PM   #5
thng
Member#: 8062
I was going to ask as well about how you bent the valves then I remembered how I bent all the valves in my alfa one day long ago. It was stupid and didn't need to re-live it. Would like to know how the heads turns out after some miles.
thng is offline   Reply With Quote
Old 05-17-2003, 06:03 PM   #6
cky211
Member#: 31129
02 WRX MPB
I bought the car at auction. When a wrx gets hit in the front hard enough the timing belt comes off. It is an interference engine which means with no timing belt the pistons can hit the valves and bend them.
I now have 500 miles on it since the rebuild and it runs GREAT!
-Scott
Doing an AT fluid swap in a few days...do i NEED to change the filter? kaisersouse Normally Aspirated Powertrain 8 08-30-2005 11:14 PM
Need to change oil? 98SS Service & Maintenance 9 01-14-2005 06:08 PM
Going from a TXS st1 w/TDO4 to VF29 do I need to change the map for now? Camperguy Engine Management & Tuning 7 08-06-2003 11:20 AM
('93-'01) 13k miles-what fluids besides oil do I need to change? Robmat Impreza Forum 2 06-22-2001 07:59 PM
what oils do I need to change?? spunky Newbies & FAQs 2 10-26-2000 12:18 AM
