Old 05-17-2003, 05:50 PM   #1
Impreza2000
Member#: 36971
2000 RS
silverthorn
Default temp sen assy. (temperature sensor assembly?)
Ive been having a few minor problems with various areas of my 00 RS. One is the electric fans are always on and the temp guage is always at ice cold. I talked to several people and decided to replace the sensor. I have the part in my hand and I cant figure out where it goes. I know its in back under intake manifold but I just dont see it. Can somebody please explain where it is at...
Impreza2000 is offline   Reply With Quote
Old 05-17-2003, 07:51 PM   #2
Austin
Member#: 7089
2016 STi
Behind the alternator, under the intake manifold, in an aluminum coolant runnner than runs over the top of the block.
Austin is offline   Reply With Quote
Old 05-17-2003, 08:05 PM   #3
Impreza2000
Member#: 36971
2000 RS
silverthorn
Default Thanks
Thanks, I still dont see it but I am going to remove the alternator and I will probably see it then. Can you take the sensor out without removing the manifold?
Old 05-17-2003, 10:13 PM   #4
Austin
Member#: 7089
2016 STi
Yes, you can get to it easily enough with the alternator off.
You'll probably want to drain some coolant to avoid spilling it. There's a petcock at the bottom passenger side of the radiator to drain coolant. I'd say you only need to drain a quart or so - the coolant temp sensor is nearly the highest point in the system.
STi gauge cluster temperature sensor nekard Electrical & Lighting 19 06-08-2011 01:50 AM
Air Intake Temperature Sensor? ATX25RS Normally Aspirated Powertrain 3 09-07-2002 04:52 AM
Intake Air Temperature Sensor PimpinRex Newbies & FAQs 2 08-14-2002 05:25 PM
Fuel temp Sens, & lean/rich ? GLwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-07-2002 09:49 PM
Anybody know about CEL P0546 Exhaust gas temperature sensor circult high input? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-25-2002 01:39 PM
