Old 05-19-2003, 12:21 PM   #1
Monas
Member#: 31418
1999 2.5RS
Default Quick question about leak down test
ok i am going to be doing a compresion test on my engine this weekend. i was wondering how to do a leak down test? i have a compresion test meter, and was wondering the steps to perform a proper leakdown test.
if anyone can give me some help on this i would be very greatful.
Thanks
Monas
Monas is offline   Reply With Quote
Old 05-20-2003, 08:01 AM   #2
Monas
Member#: 31418
1999 2.5RS
does anyone want to offer up any help on this
are the two tests one in the same?
Old 05-20-2003, 08:40 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
This has info which should help you
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Leak down test is probably going to be a little more difficult for you to do yourself since you need some more specialized tools & compressed air.
Legacy777 is offline   Reply With Quote
Old 05-20-2003, 10:37 AM   #4
Monas
Member#: 31418
1999 2.5RS
Legacy777 thanks, i was looking all over and couldnt find anything on it. I appreciate the help
Now to call around and see what mechanic in my area knows how to do this
Monas
Old 05-20-2003, 12:28 PM   #5
Legacy777
Member#: 4800
welcome
Old 05-21-2003, 02:22 AM   #6
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
I am just wondering if the "egine restorer & lubricant" additive helps to restore the compressin rate? My car has around 133,000km on it now, and I am planning to keep my car for two more years so I want to know how to extend the life of the eninge? Thanks.
impreza2002 is offline   Reply With Quote
Old 05-21-2003, 02:34 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
do NOT use any of that crap in your car!! those things are a hoak, you are better off doing a couple extra oil changes(better results). Chances are you haven't lost any compression.
jeremy
Old 05-21-2003, 08:19 AM   #8
Legacy777
Member#: 4800
Your engine is a young pup. You don't even have 100,000 miles on it.
I've got 170,000+ miles on mine, which works out to be around 274,000 km.
trust me, you'll have other sensor and misc issues before you need to worry about restoring compression to your motor. Assuming you properly maintain it of course.
Recommonded Shop for Compression Test and Leak down test? stook2003 Vancouver Impreza Club Forum -- VIC 0 07-02-2007 04:20 PM
Leak Down Test g0tb00st Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-12-2006 11:31 AM
Misinformation about leak down testís diagnosing problems with smoking after a long i MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-25-2005 01:36 AM
garages around DC to do a leak down test? bouchon Mid Atlantic Impreza Club -- MAIC 0 09-11-2003 03:49 PM
Compression Test vs. Leak Down Test dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-17-2002 11:42 AM
