Old 05-19-2003, 01:35 PM   #1
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
Default factory alarm misbehaving
So the other day I bleep my alarm to arm it, and it only makes one chirp, instead of two. I also notice that the little red flashing light is blinking in a two-flash sequence. It doesn't seem to be arming anymore. I can arm it with the button, and see the red light flashing, and unlock/open the door manually and not get a siren, and the car starts right up. Also, even if I don't arm it, the red light flashes as soon as the car is off.
I've tried to press that little button under the steering column to see if I can reset it or whatever, and nothing changes. I've also tested the siren by pressing both buttons, and that works fine.
The only thing I can guess is that the dealer messed it up when doing the 60k service?
subarucyclist is offline   Reply With Quote
Old 05-19-2003, 01:59 PM   #2
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
It kinda sounds like it was set to valet mode somehow. Do a search on that maybe. I'm not really sure how it would have gotten that way... if the battery was disconnected during your service that may have caused it (I'm not sure if that would cause it though).
bigdweeb is offline   Reply With Quote
Old 05-19-2003, 04:33 PM   #3
Supraru
Member#: 23313
99' 2.5Rs
black
Try this, there is a button that comes out of the bottom of the plastic directly under the steering colum I believe that's the vallet button. Try hitting that and see if it still does it. If that dosn't work open the door, lock it then unlock it then press the blinking button that could work too. If that dosn't work I'd take it to the dealer.
Supraru is offline   Reply With Quote
Old 05-19-2003, 05:01 PM   #4
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Sounds like your alarm is in valet mode. Check your Subaru owners' manual, it tells how to fix this.
-s-
scotty305 is offline   Reply With Quote
Factory Keyless VS Factory Alarm. 06 WRX dmxsoulja3 Car Audio, Video & Security 15 02-22-2007 02:44 AM
04 STi factory alarm to 05 Factory alarm blinguskahn Car Audio, Video & Security 2 08-05-2004 03:52 PM
Non factory or factory alarm oney01 Car Audio, Video & Security 3 09-15-2002 07:43 AM
Viper alarm w/ factory alarm WRXThis Car Audio, Video & Security 1 06-28-2001 02:07 PM
('93-'01) Question About WRX Fog Lights and Factory Alarm jzinckgra Impreza Forum 6 04-27-2001 12:46 AM
