Old 05-19-2003, 10:30 PM   #1
RS ING
Member#: 2928
Default Well My Strumong exhaust rotted out after....
only 2 years it would not pass inspection I'm kind of pissed that Cobb Tuning would put something so crappy on their cars. Well I haven't Called Cobb yet but I doubt they help me much. But come on it rotted out front and back after only 2 years and I live in a good climate (Virginia Beach as only had 3 snow storms in that time and I always keep the car clean top and bottom.
Well since I needed a good exhaust system and quick I ended up installing a WRX axle back muffler that I got for free. I had to clock the flange and install a new hanger. The nice thing is that I was able to clamp everything in place so I could put the replacment in the back of my Corrado and take it to the exhaust shop to get welded. I then installed it in 10 minutes.
here are pics of the wrx muffler on my RS:
Here are pics of the Modified WRX muffler next to the new Strumong muffler for the RS:
RS ING is offline   Reply With Quote
Old 05-19-2003, 10:41 PM   #2
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
So did my Mild Steel one in two years. It rusted from the inside out. Definatly a design flaw if you ask me. There should be a weep hole in the back where the moisture accumulates. Mine wasn't from short trips either, I drive 35 miles to work one way.
I ended up getting a used ss stromung for a good price. So far so good with it.
Peaty is offline   Reply With Quote
Old 05-19-2003, 10:45 PM   #3
obyone
Member#: 16523
Which is the reason why I always recommend you spend a little more before you buy and get the Stainless Steel version.
obyone is offline   Reply With Quote
Old 05-19-2003, 11:02 PM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I agree 100% but back when I got my Stromung in 99 there were limited choices and Stromung did not make them in SS until around 6M after I got mine
Old 05-20-2003, 05:48 AM   #5
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
RS ING
just to clear things up, you had a mild steel one right?
dRu888 is offline   Reply With Quote
Old 05-20-2003, 08:53 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
You know it carrys a 24 month warranty right?
mine rotted out after 3 years.
Jay
Old 05-22-2003, 05:12 PM   #7
RS ING
Member#: 2928
yes it was a non stainless steel unit. I called Cobb tuning up and Trey told me to send the muffler to them and they would see if its warrentyable. I'll update this post with pics later and with info from Cobb. Thanks. Frank
Old 05-23-2003, 01:12 AM   #8
dcoty
Member#: 3149
01 V7 GC/R32 sky
mine rotted in 2 years as well, not surpirsed though, monreal uses lots of salt int he winter...I saw it comming though. I have a SS strommung now and I am sure it will last much longer.
I also give a guick spray to the undercarriage of my car occasionally to get salt off in the winter.
Sorry to hear about it, but we all learned the lesson the hard way here...i should have spent the extra $ for SS.
Dan
dcoty is offline   Reply With Quote
Old 05-23-2003, 01:27 AM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Actually salt has nothing to do w/ it. It's rusting out from the inside. When you start a cold car a ton of condensate water is dumped into the muffler. It seems that the back bottom rear sections on the inside accumulate water and just sits there. Short trips would only make the matter worse. They should have designed it w/ a weep hole in the back or something. They rarely use salt here and mine went in two years. I understand they the warranty is only two years but having it go that soon is not really reasonable. Just cause the drive train one is up in 60K I didn't expect my Scooby to stop running.
Old 06-17-2003, 07:27 PM   #10
RS ING
Member#: 2928
Well Cobb tuning took care of me and I'm very satisfied with their customer service Now if anybody is looking to buy a WRX Muffler that is modified so it will bolt on to a 2001 RS click here:
http://forums.nasioc.com/forums/show...hreadid=378460
Old 06-22-2003, 03:27 AM   #11
Lord Farquar
Member#: 34851
2001 GM6
i had the same thing happen to me! haven't fixed it though, getting a lot of backfire from the welding break, same spot as you Peaty. why would cobb/stromung do such a thing ?
Lord Farquar is offline   Reply With Quote
Old 06-22-2003, 08:53 PM   #12
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
Everyone I know with the mild steel version has had it rust through in the same location. My 2 year old SS stromung is still going strong.
Dolphin Overton is offline   Reply With Quote
Old 06-23-2003, 06:15 AM   #13
RawCode
Member#: 3115
2002 Impreza 2.5RS
Cobb did not do anything wrong here. They sold you a mild steel muffler. If you do a search around here you will find out that untreated mild steel rusts like crazy. Even treated mild steel some times rusts.
The only sure way to make sure that you have a long lasting muffler is to either get alumnized steel or stainless.
RawCode
RawCode is offline   Reply With Quote
After 1 to 2 year of researching on forums i finally got in my WRX MrPr0fessional05 Newbies & FAQs 7 09-15-2005 12:56 PM
Leaving Big Four after only one year MeddlingKids Off-Topic 9 09-07-2004 11:30 AM
My Stromung exhaust is loud slamck Technical Forum Archive 15 08-31-2000 12:15 AM
pictures of my Stromung exhaust bryanw General Forum Archive 2 05-10-2000 10:08 PM
