Old 05-20-2003, 08:37 AM   #1
orndog
Member#: 34670
2013 No gears!
Saltine American
Default ? needed to put WRX struts on OBS
I have an 03 OBS that I am looking to put WRX wagon struts and springs under. Can anybody give me, or direct me to, a list of everything that is needed? I keep reading references to 'top hats' and such...
orndog is offline   Reply With Quote
Old 05-21-2003, 07:22 AM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
anybody?
Old 05-21-2003, 09:57 AM   #3
peepshow
Member#: 1777
2005 LGT
#92 FZippy
All you need are the springs and struts, you can re-use your existing top hats.
- Trent
peepshow is offline   Reply With Quote
Old 05-21-2003, 01:11 PM   #4
orndog
Member#: 34670
2013 No gears!
Saltine American
Thanks! I might just do this, I need better handling.
Old 05-21-2003, 02:07 PM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
You don't have to re-use the existing top hats. You can use the WRX top hats, they should be the same. Many people will sell the top hats with the rest of the suspension, which makes it easy, since it's all one unit.
Sedan struts may give you a little more positive camber than wagon struts. I don't know the exact difference, but if it's around 1 degree or so, it's probably a good thing, handling wise. Just be aware that there is a difference.
I'd also double check that the struts are actually different. I know that between the RS, TS and WRX they're all the same. Does the OBS sit higher? Maybe the struts are longer?
Concillian is offline   Reply With Quote
Old 05-21-2003, 07:54 PM   #6
orndog
Member#: 34670
2013 No gears!
Saltine American
The OBS does sit higher, but I don't know if the struts are different part numbers or not.
Old 05-21-2003, 08:02 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If it sits higher, then it is likely that the struts are different. Struts are designed for a specific ride height range, any significant change in height would likely warrant a different strut, at least in an OE situation.
So there probably would be a benefit in WRX struts. But I would want to double check for sure before I went and spent a bunch of money.
Old 05-21-2003, 08:04 PM   #8
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
More positive camber is a good thing? With STi Sedan takeoffs on my wagon I can only get about -.4 camber in front and -.8 in the rear. The rear isn't too bad but Noltec caster/camber plates are going in the front so I can get more negative camber.
driggity is offline   Reply With Quote
Old 05-21-2003, 08:05 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Sorry, I didn't clarify...
more positive camber in the rear
Which starts at about -1.5 and gets more negative as you lower.
I didn't realize the fronts were different too. If you can get -0.4 as max negative in the front, I can see that being a detriment.
-0.8 in the rear is good though. For wagon owners doing a something like a koni swap, it would probably behoove them to get some rear sedan bodies instead of using wagon bodies in order to get the more positive camber in the rear.
Where to get what is needed to put foglights in 04-05 RS??? Bamboorex Electrical & Lighting 8 11-01-2009 07:16 AM
what is needed to put a 04-07 5-speed into a bugeye? wrxguy02 Transmission (AT/MT) & Driveline 4 05-17-2008 09:47 PM
What do i need to put STi TMIC on o6 WRX? UndertoW101 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-12-2006 02:59 PM
so what is needed to run 20 psi on a daily driver turbocolin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-04-2005 10:47 PM
What do I need to put fog lights on my L? Jaredm83 Electrical & Lighting 0 07-14-2004 04:17 PM
