Old 05-20-2003, 04:04 PM   #1
HighTachPrez
Member#: 15247
99 2.5 RS
Default Oil on spark plug wires normal
or so the Subaru dealership says.
I've had trouble overheating and finally decided to do a compression check to see if its the head gasket... well upon taking out wire #1 there was oil all over the boot. The same goes for 2-4 also. I get a call back from Subaru saying the only thing wrong with my car is the radiator that has a tiny hole in it. I can see that as being the reason for overheating... but is having oil on the spark plug boots normal?? Normal as in every boxer engine that Subaru produces (which he says). Also my car has 55,000 miles on her.
I think not, but i'm getting further opinions
HighTachPrez is offline   Reply With Quote
Old 05-21-2003, 02:36 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
no, the spark plug tube bonnets need to be replaced, this is a common problems on honda's where we use small o-rings to seal the tubes off and they eventually dry out and leak. replace em and replace the wires.
jeremy
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
STi, small amount of oil on spark plug BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2005 02:31 AM
Oil on spark plug boots (even after new valve cover gaskets) FujiHeavyFreak Service & Maintenance 2 08-14-2005 12:30 PM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
What oil, and spark plug/wires should I use? darkmattr Newbies & FAQs 7 07-17-2002 12:18 PM
