Old 05-20-2003, 09:35 PM   #1
bdoss123
Member#: 19958
Default Legacy GT - Mod(able)? Same stuff as 2.5 RS?
I'm debating getting a Legacy GT, can these engines be modded in the same way that the 2.5RS can? Are they worth messing with, or is the car to heavy for a 4 Cyl to produce decent performance?
Thanks for any info,
BD
bdoss123 is offline   Reply With Quote
Old 05-20-2003, 09:52 PM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Default yep
Yep they are perfectly moddable. The weight could be an issue but once the extra space is in use you won't have a second thought on your choice.
Russell
Oh yeah, all parts and mods done to the 2.5 rs can be done to the Legacy. Exact same engine
Russell Rogers is offline   Reply With Quote
Old 05-20-2003, 09:57 PM   #3
iON Performance Inc
Vendor
Member#: 7673
bdoss123 - which year of Legacy GT?
The DOHC EJ25 parts from the RS will work with the DOHC EJ25 parts of the GT. And same w/ the SOHC stuff.
The cat-back section of the Legacy is different then the RS (due to length of the car as well as hanger positions)
Intake on the MY00-up GT's will be different as well.
N/A Mods like cams will work as well.
Suspension is different. (depending again on years, however spring rates on the GT's are higher)
iON Performance Inc is offline   Reply With Quote
Old 05-21-2003, 11:40 AM   #4
bdoss123
Member#: 19958
I'm looking at a 97, a 98, and a 99.
BD
Old 05-21-2003, 12:17 PM   #5
iON Performance Inc
Vendor
Member#: 7673
bdoss123 - depending on how far you want to take your to in terms of N/A mods we have the following available for the DOHC EJ25.
1) Hi-Compression Pistons -> 11:1 works on 91+ octane fuel
2) N/A Cams
3) DOHC valvetrain (springs and Ti retainers)
4) Modified intake manifolds
5) Headwork (porting etc)
6) Header-back system
7) Intake systems.
Old 05-21-2003, 10:24 PM   #6
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Default hey ION
Can you give a little more info on the intakes and the modified intake manifolds? I am looking into these mods next. I also want a header back system w/header. Some prices and pics would be great.
Russell
Old 05-22-2003, 07:47 PM   #7
iON Performance Inc
Vendor
Member#: 7673
Russell Rogers - basically you can use a MY98RS intake, we just use a shielded filter instead of an open element.
As for the intake manifold, it'll depend on how far N/A you want to go. A simple and relatively inexpensive (in comparison to the full out N/A manifold) would be to take your stock one, have it extrude honed, and have a flow coat on the inside applied along with a silver/chrome ceramic coating on the outside. This is a good time to fit a phenolic spacer in as well.
If you want 1st hand comments from one of the Legacy guys with our header-back system, do a search for CRAZY KEN.
If you'd like drop us an email directly with your objectives and goals you'd like to achieve. Much easier to then get what you need.
Old 05-23-2003, 01:08 AM   #8
dcoty
Member#: 3149
01 V7 GC/R32 sky
iON performance- you have a PM regarding intake manifolds.
Dan
dcoty is offline   Reply With Quote
Old 05-23-2003, 02:54 AM   #9
COwannago
Member#: 6972
I also have considered trading the RS on an older Legacy GT, great styling.
Nick C.
COwannago is offline   Reply With Quote
Old 05-23-2003, 07:08 AM   #10
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Default great cars
Legacy's are great cars. Once you have all the interior space you will never want another car. I love the fact that they still look good, eventhough they are the older bodystyle.
Russell
Old 05-23-2003, 11:26 AM   #11
bdoss123
Member#: 19958
Could anyone tell me about the AUTO Transmission found in the 1997 Legacy GT. I was originally looking at strictly manuals, but a deal just came up on an AUTO. These TRANS really slushy? Reliable? Any info is appreciated.
BDOSS
Old 05-24-2003, 04:32 PM   #12
bdoss123
Member#: 19958
Anyone got more info?
Old 05-25-2003, 02:18 AM   #13
JSiwek
Member#: 14909
I would never get an auto over the 5 speed. It's just so much more fun to drive a stick, and the Legacy can be turned into a very fun and quick car.
I have a '98 Legacy GT sedan, and it's been just completely amazing! I have a lot of suspension mods and LOVE how the car handles... it's very neutral and grips like crazy. On a hard turn, I can go from understeer to oversteer and back simply by feathering the throttle. Suspension stuff I did was Eibach Pro Kit springs, KYB GR2 struts (although the AGX ones made for an RS will fit and work perfectly), adjustable rear sway bar with Whiteline endlinks, and front and rear strut bars. That and good tires make all the difference!
The car can be surprisingly quick, too! I had no problem whatsoever matching my friend's '98 328i bumper-to-bumper all the way up to 75 mph, and I had an extra person in my car Go Fast mods at the time were K&N filter, Fidanza flywheel w/ Clutch Masters Stage 3, Borla headers, Stromung muffler and it rocked!
I love the Legacy, it looks great, drives great, and has split rear seats and tons of people space :-) You wont feel bad about your choice! Oh, and Morette replacement lights look awesome on it!
Jeremy
JSiwek is offline   Reply With Quote
Old 05-25-2003, 06:47 PM   #14
bdoss123
Member#: 19958
I appreciate it. I may go with the auto, not sure yet though. I've driven 5spd for a while now, but sometimes like the conv. of the automatic. The Legacy I am talking about is a 1997 GT, Auto, 65K Miles for 8400. Anything this model year had problems with?
Thanks,
bd
Old 05-26-2003, 11:07 AM   #15
iON Performance Inc
Vendor
Member#: 7673
bdoss123 - the 4EAT is much stronger then the 5MT used by Subaru. So if you're looking to make lots of torque and hp, then the 4EAT would be better. (drag racing situations).
A manual will definately be "sportier"
You'll want to do a full fluid flush and change over when you get your car. If you plan on "spirited" driving, it's recomended to get a tranny cooler as well.
EJ20TT swap into a 97 Legacy GT, would it have the same difficulty as swapping in RS Deucalion Legacy Forum 2 11-09-2009 02:25 AM
ej20tt swap into a 97 Legacy GT, would it have the same difficultys as swapping in RS Deucalion Subaru Conversions 1 11-09-2009 01:19 AM
98 legacy GT 5mt same as 01 rs/wrx execept ratio?! serious Transmission (AT/MT) & Driveline 4 08-12-2009 02:16 PM
MY00 2.5 RS brake assemblies same as Legacy brakes from the same year? Mauricio Brakes, Steering & Suspension 4 06-01-2004 05:55 PM
is the 2.0 pully the same size as 2.5 pierceman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-15-2003 04:57 PM
