Old 05-20-2003, 10:05 PM   #1
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default Best rust removal/ remover??
I have a a couple on intake pipes and exhaust pipes that need to be treated for rust. Basically the inner sides of the intake piping has accumulated a good 1-2mm's of rust and I need to get it off and re-coat the inside. I have been suggested to sand blast, others ball blast, and then others to just replace with aluminum piping. Thing is it is a custom FMIC piping and to replicate it may take some money. The exhaust pipes have external surface rust. Does any one know of good ways to remove rust such as solvents, sand paper and such other methods?
thank you.
Cusco is offline   Reply With Quote
Old 05-21-2003, 01:45 AM   #2
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Sand it down, put naval jelly on it and paint it. If you happen to have easy access to a sand or bead blaster, that will definently do the job. But it doesn't sound like a lot of rust not really worth it IMHO. Sanding does a pretty good job.
slim speedy is offline   Reply With Quote
Old 05-21-2003, 01:51 AM   #3
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default thanks
I have access to a sand blaster if I had to but I will try the sanding to see if it will get rid of most of it. I also heard that Krylon Piant has a primer spray that turns rust into a primer through a chemical reaction. Know anything about this? "Naval Jelly?" Is that a certain type of jelly or rust inhibitor and is that the brand name?
Old 05-21-2003, 03:14 AM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Naval jelly is a generic term for phosphoric acid, I believe. You have to be careful not to leave it on too long
Best way to remove rust from a muffler? DJS_02_WRX Car Care & Detailing 21 10-04-2009 05:00 PM
Rust repair remove kit timmui Canada Region Forum 0 01-09-2005 11:10 PM
Best way to remove pinstriping? Gabriel Interior & Exterior Modification 5 09-24-2001 11:05 AM
Best way to remove 97 door panel? HIHO Legacy Forum 3 08-20-2001 08:12 PM
Best way to remove window stickers? Jonathan_Yi General Forum Archive 9 08-04-2000 01:38 PM
