Old 05-20-2003, 11:49 PM   #1
samh22a
Member#: 30710
04 STI
Default TT with aftermarket alarm + remote starter ??
Ok, quick question :
I got my alarm installed today and everything is fine, except for one thing.
I can't use my Blitz TT cause if I do, I won't be able to start my car with the remote starter.
If I use the built-in turbo-time in my alarm, everything is ok !
Any Idea ??
samh22a is offline   Reply With Quote
Old 05-21-2003, 06:49 AM   #2
jaypride
Member#: 33424
2004 STI
Blue/Gold
Does it really matter which one you use? Do you even drive your car hard enough to need one?
jaypride is offline   Reply With Quote
Old 05-21-2003, 08:43 AM   #3
samh22a
Member#: 30710
04 STI
i would rather use my Blitz, since the built-in TT is 2 min, not adjustable.
of course I do !!!
Sam
Old 05-21-2003, 09:08 AM   #4
jaypride
Member#: 33424
2004 STI
Blue/Gold
If you have the stock turbo chances are you don't. Especially since it's designed to air cool. Anyway, either bring it back to whoever put in the system and slap them around for screwing it up, or only use the Blitz when you don't plan on using the remote start. Just make sure the alarm actually arms when you are using the Blitz. It could be that the remot start isn't working cuz the alarm never turns on or something stupid like that.
Old 05-21-2003, 11:13 AM   #5
netZ
Member#: 5743
2007 Kia Optima
gold brick
what up...
you need to provide additional information such as:
1) brand type of alarm
2) any other accessories installed along with the alarm
3) type of turbo timer
4) did you use a turbo timer harness?
can't help unless you provide more detailed info...
netZ
netZ is offline   Reply With Quote
Old 05-21-2003, 11:35 AM   #6
samh22a
Member#: 30710
04 STI
1) compustar
2) remote starter ( builtin)
3) BLITZ dual TT
4) nope
Sam
Old 05-21-2003, 12:18 PM   #7
netZ
Member#: 5743
2007 Kia Optima
gold brick
hmm...
"I can't use my Blitz TT cause if I do, I won't be able to start my car with the remote starter."
Is it b/c the compustar requires you to do some procedures to do a remote start for a manual transmission and the turbo timer interferes with that right?
you may need to rewire your compustar as an automatic transmission remote start and hook up the ecu neutral safetywire to the hood input of the alarm system. if your vehicle is in gear the alarm will think the hood is open and prevent you from remote starting your vehicle.
you will also need to wire up 2 relays to disconnect the alarm system's ignition sensing wire so that you can arm the alarm while the turbo timer is counting down.
good luck!
netZ
Originally posted by samh22a
1) compustar
3) BLITZ dual TT
4) nope
Sam
Please recommend good/excellent alarm + remote starter installer in NJ njchen24 Car Audio, Video & Security 3 04-12-2009 07:08 PM
FS: Compustar paging alarm, remote-starter and other security parts. OverRev VIC Private Classifieds 5 11-17-2008 01:41 AM
FS: compustar 2 way paging alarm + remote starter OverRev VIC Private Classifieds 3 07-07-2007 08:16 AM
Apexi TT w/aftermarket alarm help. STi - IMPREZA Electrical & Lighting 0 02-16-2004 03:34 AM
