Old 05-21-2003, 04:50 PM   #1
wombatsauce
Member#: 31550
WorldRallyDirt
Default Subaru Top Engine Cleaner or Seafoam use questions
Hello,
My car is knock/ping prone and I was told to 'seafoam' my engine to get rid of carbon deposits that are most likely the cause of my inexplicable detonation. I was a little leary of doing this to my 7500mile engine, but I saw this bottle of Subaru Top Engine Cleaner at the dealer when I went in for my 7500 m service, and it's basically the same as Seafoam - with the same directions for use. A tech told me that's a common thing and it would be a good idea to use it.
Anyone done this? Anyone tried Seafoam on a WRX? Is there any obvious things I should/shouldn't do with this - or anything specific to the WRX I should know before trying?
Please let me know. If anyone has used either product in a WRX and has some info about before/after, please let me know. Just want my car to run right, and I don't want to do anything wrong to it..
Thanks!
-Jacob
wombatsauce is offline   Reply With Quote
Old 05-21-2003, 07:05 PM   #2
mlambert
Member#: 13831
We were just talking about seafoam last night, what a coincidence. Austin uses it.
mlambert is offline   Reply With Quote
Old 05-21-2003, 07:07 PM   #3
wombatsauce
Member#: 31550
WorldRallyDirt
Default Awesome..
Not sure who Austin is.. Can you put him in touch with me or show him the thread? I would appreciate some advice..
BTW - I did this with the Subaru bottle, and the car seems to run much better so.. I think this may be a good thing. Still would love to hear something from someone who has done this tho..
Thanks!!
-Jacob
Old 05-21-2003, 07:14 PM   #4
mlambert
Member#: 13831
Just send a pm to austin, hes very helpful.
Old 05-21-2003, 08:09 PM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
i thought cleaning out carbon deposits was done on much older cars. you're car seems to new to have any noticable amount of carbon deposit
so how much does this bottle cost and how do u go bout using it?
vile is online now   Reply With Quote
Old 05-21-2003, 08:15 PM   #6
mlambert
Member#: 13831
Our cars run very rich, carbon builds up quick.
http://www.seafoamsales.com
Old 03-12-2004, 12:00 PM   #7
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Anyone have any experience doing this?
I picked up some GM Top Engine cleaner (same stuff) and I was wondering if I should pour it directly in to the Throttle Body or if I should find a vacuum line to siphon it out of the bottle....
crash is offline   Reply With Quote
Old 03-12-2004, 12:48 PM   #8
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
I've used Seafoam on numerous cars and it has made a significant difference on all of them, its a great product. Mopar Combustion Chamber cleaner (MCC) is similar and is what all the DSM guys use, also with great success.
Using a good catch can setup will avoid this BTW.
Compressed is online now   Reply With Quote
Old 09-05-2006, 04:24 PM   #9
hoffmanEstates
Member#: 122043
04 wagonier
psm
I second that SEAfoam works miracles even when u pour it into ur crankcase let it idle donot drive the vechicel!! and dump the oil helps alot out there also DEEPCREEP good way to clean throttle boddy/fmic awesome product
hoffmanEstates is offline   Reply With Quote
Old 09-06-2006, 12:24 AM   #10
scooby1220
Member#: 125129
2004 WRX VF34'd
Seafoam, its been used in everything I own at one point or another.
scooby1220 is offline   Reply With Quote
Old 09-06-2006, 06:35 PM   #11
MiracleMan
Member#: 99318
205 wrx
crystal gray
I too am trying to find out some information on where to apply this, I am not engine savie as far as terminology but very maticulous with instructions. Does anyone have any images on where to let the car "suck" some up? I have an 05 wrx and a can of this seafoam
MiracleMan is offline   Reply With Quote
Old 09-06-2006, 09:01 PM   #12
DVN428
Member#: 26226
2004 Impreza WRX
WR Blue
I usually suck up the seafoam through the divertor hose off the bipass valve. Its the same line you would use for the boost gauge.
DVN428 is offline   Reply With Quote
Old 12-12-2006, 03:39 PM   #13
shemoves
Member#: 80663
2005 STi
Can I just unplug the BPV line and pour in small amounts of Seafoam? (Not sure if allowing the car to run with the BPV line unattached can hurt the car).
shemoves is offline   Reply With Quote
Old 04-13-2009, 10:42 PM   #14
05wrx09
Member#: 204111
2005 WRX
Did you end up doing just that? I too have an 05 and a can of this Seafoam and want to know exactly where to put it...
05wrx09 is offline   Reply With Quote
Old 04-16-2009, 04:47 PM   #15
mindovaanything
Member#: 198523
02 WRX
MBP
bump for answers? anything to do before or after seafoam? I was told to change the oil & oil filter after seafoam which is upsetting because i just bought seafoam yesterday and changed my oil but didn't do the seafoam yet so should i wait until the next oil change or just do it now?
mindovaanything is offline   Reply With Quote
Old 04-16-2009, 05:18 PM   #16
05wrx09
Member#: 204111
2005 WRX
Wait until your next oil change. If you want, put half the bottle in the gas tank and maybe the other half suck it up into the vacuum hose of the bypass valve it works great
Old 04-18-2009, 06:07 AM   #17
prometheum
Member#: 92003
04 bicycle!
if you've got cats it might not be a bad idea to disconnect them. but seeing how you've only got 7500 miles on the car i wouldn't bother. also seafoam while the engine is warm/hot
prometheum is offline   Reply With Quote
Old 04-18-2009, 10:33 PM   #18
shemoves
Member#: 80663
2005 STi
Yes, just pulled the line off the BPV and sucked it in there. Just make sure to only injest very small amounts at a time...start with litterally a drop and increase a bit as the car allows. The car will stumble, then recover, then you add a bit more. It is a very slow process, but you only use 1/3 to 1/4 of the can IIRC. Just follow the instructions on the back of the can, remembering to add very small amounts at a time (I think I may have used the cap as my sucking container).
Another thing...the car will smoke (out of the tailpipe) like your garage is on fire, no joke. There are stories of neigbors calling the fire department during seafoam treatments. Keep that in mind; maybe do it at night.
Old 04-18-2009, 11:36 PM   #19
05wrx09
Member#: 204111
2005 WRX
Yea, I ended up doing it and it was great! Smoked like crazy and I think the butt dyno reported more throttle response afterwards
Old 05-12-2009, 12:10 AM   #20
05wrx09
Member#: 204111
2005 WRX
Anyone try putting any of this stuff into the turbo inlet hose to help clean the hose and the turbo compressor wheel by change? I've heard of some doing that, I just wasn't sure where to put it or anything.
Subaru Upper Engine Cleaner - Where to Buy? WRXerist Service & Maintenance 14 11-19-2009 06:41 PM
Reccomend me something similar to GM top engine cleaner? Aaron'z 2.5RS Service & Maintenance 2 03-31-2007 12:27 AM
Which engine cleaner to use? Starkiller Interior & Exterior Modification 2 12-01-2005 08:22 PM
Brake Cleaner - Do you use chlorinated or non-chlorinated? krzyray Service & Maintenance 2 04-19-2004 02:14 AM
Change Fuel Injector or just Use Cleaner??? BrysImpreza Normally Aspirated Powertrain 4 03-28-2001 11:11 AM
