Old 05-22-2003, 08:33 AM   #1
subie_nh
Member#: 25555
02 2.5rs
Exclamation HELP!! e-brake, ABS, Batt light on over 30mph??
I have an 02 rs with 45k on thte dial. I commute 200miles a day. On the way home yesterday as I accelerated my Ebrake, Batt, and ABS light all came on and remained on until I slowed down below 30mph reaching a toll booth. Up until that point i have had a few CELs all relating to misfires in cylinder 4. At the time all the lights came on.. the CEL was not on, and has not come on since. The only mods to the car is a Cobb CAI, and a 4awg grounding mod. Are my sensors just going wackey, and a simple ECU reset will fix it.. OR should I be concerned. Your timely suggestions are greatly appreciated!
Much TIA
Cheers,
subie_nh is offline   Reply With Quote
Old 05-22-2003, 08:35 AM   #2
subie_nh
Member#: 25555
02 2.5rs
Oh and all the lights (batt, ebrake, abs) have yet to turn off over the speed of 30mph. ?? Safe to drive it? I bought it brand new 10 months ago??
Old 05-22-2003, 09:06 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Sounds like an issue with the charging system, ie alternator.
Which will most likely require the replacement of the battery as well.
Legacy777 is offline   Reply With Quote
Old 05-22-2003, 10:57 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like your alternator is dead or your belt is super loose and just slipping on the pulley above a good engine speed. check your belts, if you can't find the source then i'd say you have a bad alternator.
jeremy
Old 05-22-2003, 11:12 AM   #5
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
it might be something w/ your grounding mod shorting out. Check those connections and make sure nothing came loose.
Rebellion is offline   Reply With Quote
Old 05-22-2003, 09:39 PM   #6
subie_nh
Member#: 25555
02 2.5rs
Ok more news. Actually when I accelerate past 1,000 rpm the ebrake and batt light go on. then once I hit the 2.75k rpm the ABS light comes on. I can hold the rpms and bounce the needle and watch the lights flicker. I forgot to mention above that I have a remote starter installed and wondered if that could have something to do with it? I checked the grounding mod and all looks well. Altenator doesnt seem to be running overtime either?
TIA
Cheers,
Old 05-23-2003, 08:35 AM   #7
Legacy777
Member#: 4800
You had two people suggest the alternator, and not to sound arrogant, but I have a pretty good idea I know what I'm talking about, and from all the posts I've seen from Jeremy, he knows his shiat too.
So I would at the very least take your car down to your local autoparts store, have they check alternator and charging system. Most will do this for free. If it's your alternator.....get a new alternator, and problem is solved.
If not, you've proved both of us wrong, and we can try to think of other possibilities.
Old 05-23-2003, 10:45 AM   #8
subie_nh
Member#: 25555
02 2.5rs
i appreciate your suggestion of checking the altenator. I am rather handy with a multimeter and have tested all grounds on the grounding mod and the altenator and stock battery. Next im going to check over the remote starter install. Any other ideas. the recharging system checks out fine..pulling 14.1 at the altenator and 13.9 at the batt.??
Old 05-23-2003, 12:13 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
okay now did you check the charging system voltage as the car is revving up?? the lights are coming on cause the voltage is dropping, you alternator it shot or the nut on the charging post is loose/missing.
jeremy
Old 05-23-2003, 02:19 PM   #10
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
I just had the same thing happen to me. I needed a new alternator. A nice little Dynabatt went in with it.
scoobiejosh is offline   Reply With Quote
Old 05-24-2003, 11:33 AM   #11
subie_nh
Member#: 25555
02 2.5rs
update: Just has the charging system load tested at autozone and both the altenator and battery checked out wil flying colors.. Im thinking its the remote starter. Gonna tackle that today.. more results to come... thanks all for the info
Old 05-25-2003, 08:49 AM   #12
subie_nh
Member#: 25555
02 2.5rs
OK wipers began to slow down..so I took the alternator out and had it bench tested. The alternator is bad. Im not impressed with my subie.. a shot alternator after just 11 months? where should I look for and alternator? waranty is way gone..
Old 05-25-2003, 12:32 PM   #13
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
can I just add....
HOLY MOLY 200miles to commute everyday!?!?!?!?!?!
suuuuuucks.
Cujo31 is offline   Reply With Quote
brake and battery light on, but no issues sachilles Normally Aspirated Powertrain 9 07-24-2008 11:35 PM
brake and battery lights on Sir Punk Electrical & Lighting 18 06-06-2008 12:21 AM
power steering??? ebrake and batt. light on! whats going on? :( kirkeemonster Service & Maintenance 19 11-04-2007 04:25 PM
brake and battery light on with AC? sc00by25rs Service & Maintenance 4 06-02-2005 12:09 PM
Abs warning light on- need input wrxman555 Brakes, Steering & Suspension 9 04-12-2001 09:39 PM
