Mid Atlantic Impreza Club
Old 05-22-2003, 01:42 PM   #1
slammedWRX
Member#: 12350
2002 WRX SEDAN
BLACK
Default Vishnu XEDE or UTEC
Which one should i get and which is more user friendly and also im debating which injectors i should get the STI injectors or the Ultimate racing 600 cc injectors please give me some ideas
slammedWRX is offline   Reply With Quote
Old 05-22-2003, 03:35 PM   #2
Lit4
Member#: 23758
SOLD MY03 REX SILV
miss the dang SCOOBYSPORT
Default Get Cobb's access ecu
It does the same job and is cheaper. The UTEC also modifies signals to and from the computer(basicly this comes down to it is working against the computer) The accessecu is a reflash, so it's the same smart ecu in control of everything. For $100 extra bucks it's user programable to.
Lit4 is offline   Reply With Quote
Old 05-22-2003, 03:56 PM   #3
plunk10
Member#: 32342
13 BubblePrius
When I ask a question like this, people always suggest the following.
In my opinion, I like the UTEC, because it does not splice into your factory harness, and its removable if you need warranty work done to your car.
Plus, I don't have 2 cars, so I can't send my ECU to CA to get a reflash from cobb.
I'm still bone stock however.
plunk10 is offline   Reply With Quote
Old 05-22-2003, 05:03 PM   #4
Lit4
Member#: 23758
SOLD MY03 REX SILV
I might have an accessecu available soon for trade to some1 with a MY03 ecu.
Old 05-22-2003, 05:59 PM   #5
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
not to make it tough.....but:
Westmister Speed now carries MRT's ECUTEK which sounds pretty nice but i am still researching the situation. Any-one have any advice on this?
GregsblueRex is offline   Reply With Quote
Old 05-22-2003, 07:10 PM   #6
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
The UTEC of course. This is completely unbiased.
Just to clarify some misinformation: There is no fighting over control while running the UTEC as it actually drives your car and at no point ever does the factory ecu drive the car while using a UTEC.
If you plan on mixing and matching parts or will continue to modify your vehicle, the UTEC is the way to go. If you have very basic plans a reflash would be good but we are not selling our reflashed ecu's yet.
Thanks,
Phil
TurboXS.
motoxphil is offline   Reply With Quote
Old 05-22-2003, 09:25 PM   #7
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I say the UTEC because it lets you keep upgrading and look at al the features you get.
dj_noose is offline   Reply With Quote
Old 05-22-2003, 11:17 PM   #8
Lit4
Member#: 23758
SOLD MY03 REX SILV
"Just to clarify some misinformation: There is no fighting over control while running the UTEC as it actually drives your car and at no point ever does the factory ecu drive the car while using a UTEC."
Sorry if I was misleading. What I was trying to say was that the Factory ecu isn't in complete control. From what I understand the factory is exceptionally smart and makes changes day to day in the respects to any changes it sees. Some of the obvious would be fuel and weather. I was under the assumption that if the UTEC is in control, the Exceptionally smart brain that came with the car no longer has this ability. I've heard people say that under the UTEC's control, their car has actually run poorly with something as simple as a 10 degree weather change. They said they constantly had to switch between maps for reasons like this. I'm no expert, but again I've heard the factory ecu easily handles things like this. Why give that up for engine managment? Does the UTEC do this? The accessecu costs alot less, you keep the factory ecu and for $100 you can get this little handheld scanner that you can modify the map yourself for when you upgrade mods. I know you at TurboXS are in the market to sell these things, sorry if it appears as if I am bashing the UTEC. Just that I've had a UTEC in the past. In my opinion the accessecu is alot smoother and runs alot better. Why would one not want the factory ecu to be in control. All you simply have to do is modify the ecu to accept the mods done to your car, not give up the control to another piece of equipment. No expert just stating opinion. How does the UTEC control the parameters in the same way the factory ecu would?
....stirring up a storm
For Sale Vishnu Xede for WRX/or STi + 2 WRX xede harnesses djruslan Private 'For Sale' Classifieds 0 11-17-2005 03:51 PM
vishnu xede or cobb accessport? SilverCWestWRX Engine Management & Tuning 10 02-21-2005 12:53 PM
Xede or UTEC for '05 STi? 04STiguy Engine Management & Tuning 3 06-23-2004 06:45 AM
Xede Or Utec stiffler Engine Management & Tuning 1 02-24-2004 03:06 AM
Xede or UTEC? Jduke Engine Management & Tuning 12 03-23-2003 04:24 PM
