#1 |
Member#: 32566
NESIC
Vehicle:1999 911 C2 XBL GT: Fenrick |
Anyone happen to know what the inner diameter of the vacuum hose running to the stock BOV is?
I'm going to tap it for a gauge tomorrow and I guess I'm too lazy to go and check for myself tonigh. Since I was on the board anyway... I figured I would ask. Thanks! Rich
#2 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
1/4"
#3 |
Member#: 32566
NESIC
Thanks!
#4 |
Member#: 32566
NESIC
Drees,
What kind of connectors did you use to tap the line and where did you get them? I've had a hell of a time finding anything (brass or plastic) to tap a 1/4" line with a 1/8" t. Thanks! Rich |
#5 | |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
#6 | |
Member#: 25905
SCIC
I could have run the 1/8" nylon hose all the way, but it seems too easy to kink so I just used a few inches of it sticking out the back of the gauge and where I joined the vacuum hose with the adapter. BTW, www.mcmaster.com sells a 1/4"-1/4"-1/8" stainless steel T so you don't have to use an adapter if you didn't want to. If I ever decided to re-run the line I would go that route. |
#7 |
Member#: 32566
NESIC
Again, Thanks.
I just bought an adapter... similar to what you described... kind of figured it out from the picture. I might look into that mcmaster T though. Thanks. Rich |
| Thread Tools | |
| Display Modes | |
| What is the optimum wheel size for an impreza? | kwan_1104 | Newbies & FAQs | 23 | 12-24-2006 07:36 PM |
| What is the proper speaker size for doors and rear decklid? | adrive43 | Car Audio, Video & Security | 13 | 07-21-2005 03:07 PM |
| What is the thread type size for engine block plug? | F15DOC | Factory 2.0L Turbo Powertrain | 8 | 07-13-2005 11:19 AM |
| What is the wheel lug size for WRX? | makofoto | Tire & Wheel | 2 | 02-24-2004 01:02 PM |
| what is the best gap size for spark plugs? | Homemade WRX | Factory 2.0L Turbo Powertrain | 6 | 11-13-2003 08:06 PM |
